Unsolved endstop trigger and bangbang questions
no i did not. it seems to be missing from here.
https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_M950_Create_heater_fan_or_GPIO_servo_porti dont quite understand it. i tried J6 but that didnt work. is there a page that shows the pin numbers and names? or do i also need to add C to M950?
; Configuration file for Duet WiFi (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.1.1 on Sun May 31 2020 21:54:40 GMT-0700 (Pacific Daylight Time) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"1M" ; set printer name ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet M587 S"MTS" P"Judy1985" ; Drives M569 P0 S0 ; physical drive 0 goes backwards X M569 P1 S1 ; physical drive 1 goes forwards RY M569 P2 S0 ; physical drive 2 goes backwards RZ M569 P3 S1 ; physical drive 3 goes forwards E M569 P5 S1 ; physical drive 5 goes forwards LY M569 P6 S0 ; physical drive 6 goes backwards LZ M584 X0 Y1:5 Z2:6 E3 ; set drive mapping M350 X16 Y16:16 Z16:16 E16 I1 ; configure microstepping with interpolation M92 X114.29 Y114.29:114.29 Z400.00:400.00 E420.00 ; set steps per mm M566 X300.00 Y100:100 Z12:12 E120.00 ; set maximum instantaneous speed changes (mm/min) M203 X2600.00 Y2600:2600 Z500:500 E1200.00 ; set maximum speeds (mm/min) M201 X100.00 Y50:50 Z20:20 E250.00 ; set accelerations (mm/s^2) M906 X800 Y1100:1100 Z600:600 E800 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X1400 Y800 Z900 S0 ; set axis maxima ; Endstops M574 X1 S1 P"xstop" ; configure active-high endstop for low end on X via pin xstop M574 Y1 S1 P"ystop" ; configure active-high endstop for low end on Y via pin ystop M574 Z1 S2 ; configure Z-probe endstop for low end on Z ; Z-Probe M950 S0 C"duex.e2heat" ; create servo pin 0 for BLTouch M558 P9 C"zprobe.in+zprobe.mod" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds G31 P500 X28.3 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height M557 X15:1350 Y50:750 S75 ; define mesh grid ; Heaters M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 M307 H0 B1 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M307 H0 A46.7 C538.0 D3.3 V24.0 ; bed tuning parameters M143 H0 S120 ; set temperature limit for heater 0 to 120C M308 S1 P"e0temp" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin e0temp M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit ; Fans M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Miscellaneous M911 S22 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss T0 ; select first tool M950 J6 M581 P"duex.e2stop" T0 C0 ;emergency stop
oh i found this, do i just add M950 J1 C"duex.e2stop"?
how many values are there for J?
https://duet3d.dozuki.com/Wiki/Connecting_an_Emergency_Stop -
My understanding is that J is just the index number. The pin being attached to that index is the actual physical pin name being used. "duex.e2heat" for example.
From the M950 wiki entry example:
M950 J1 C"!^e1stop" ; Input 1 uses e1Stop pin, inverted, pullup enabled
Then in the M581 P you'd reference the J number from the M950.
M950 J1 C"e1stop"
M581 P1 T0 C0
J1 = P1
At least I think that's how it's working.
that would make sense, but i tried it and still no dice.
Not sure, but if i remember correctly what i readed other day, you have to enable pull-up for duex endstops. So your M950 should looks like :
M950 J1 C"^duex.e2stop" -
just tried that. still nothing. i wish all the RRF V3 information was more centrally contained.
so is there anything else i can try?
@deltajegga said in endstop trigger and bangbang questions:
Yes. Firstly make sure the switch you've connected is actually working as it should. If you go to the web interface you should find a tab that shows the end stops and their trigger states. I think it's "settings - machine specific" or some such. The end stops are listed in numerical order from 0 so it might not be obvious which is which. But no matter. Activate your switch while observing that page. One of those end stops should change state.
If the switch shows triggered when it isn't and vice versa, then you'll need to invert things so that it detects a falling edge rather than a rising edge (or vice versa). That is done by using either S0 or S1 in your M581 (can't remember which is which - try them both and see which one works).
@deckingman wouldent the led also turn on or off?
a new development, apparently
;M950 J1 C"!^duex.e2stop"
;M581 P1 T0 C0makes it reset when i home the Y axis...
What is the switch and how is it wired?
@Phaedrux just a bare switch wired normally closed. after i commented that bit out, it homed all just fine. also if i just pushed the switch by hand it wouldn't reset, only when i ran home y or home all
Can you post your homing files? I have to admit, I'm having a hard time following along. Do you think you could summarize what exactly you have hooked up and how it's configured?
the X and Y endstops are NC switches wired to the duets endstops outer two pins. the emergency stop switch is a NO red push button, wired to the duexe2stop outer two pins. and the Z is a bltouch.
im in the process of building the printer, so i just recently was able to test the homing. when i did, it homed X just fine, but when i homed Y, i would lose wifi connection. so i commented that estop code out as a random guess and it homed just fine. so i uncommented it again and just pressed the switch by hand in various ways as to trigger a rising or falling signal, but it did not reset. BUT when i ran "home all", it would make it to the homing Y part and reset, or if i just ran home Y.
(i think it has to do with the way and timing of the quick move to endstop and the second pass that made it trigger, idk)
; homeall.g ; called to home all axes ; ; generated by RepRapFirmware Configuration Tool v3.1.1 on Sun May 31 2020 21:54:41 GMT-0700 (Pacific Daylight Time) G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position G1 H1 X-1405 Y-805 F4000 ; move quickly to X and Y axis endstops and stop there (first pass) G1 H2 X5 Y5 F3000 ; go back a few mm G1 H1 X-1405 Y-805 F360 ; move slowly to X and Y axis endstops once more (second pass) G90 ; absolute positioning G1 X50 Y50 F6000 ; go to first bed probe point and home Z G30 ; home Z by probing the bed ; Uncomment the following lines to lift Z after probing ;G91 ; relative positioning ;G1 Z5 F100 ; lift Z relative to current position ;G90 ; absolute positioning
; homex.g ; called to home the X axis ; ; generated by RepRapFirmware Configuration Tool v3.1.1 on Sun May 31 2020 21:54:41 GMT-0700 (Pacific Daylight Time) G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position G1 H1 X-1405 F6000 ; move quickly to X axis endstop and stop there (first pass) G1 H2 X5 F3000 ; go back a few mm G1 H1 X-1405 F360 ; move slowly to X axis endstop once more (second pass) G1 H2 Z-5 F6000 ; lower Z again G90 ; absolute positioning
; homey.g ; called to home the Y axis ; ; generated by RepRapFirmware Configuration Tool v3.1.1 on Sun May 31 2020 21:54:41 GMT-0700 (Pacific Daylight Time) G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position G1 H1 Y-805 F4000 ; move quickly to Y axis endstop and stop there (first pass) G1 H2 Y5 F2000 ; go back a few mm G1 H1 Y-805 F360 ; move slowly to Y axis endstop once more (second pass) G1 H2 Z-5 F6000 ; lower Z again G90 ; absolute positioning
; homez.g ; called to home the Z axis ; ; generated by RepRapFirmware Configuration Tool v3.1.1 on Sun May 31 2020 21:54:41 GMT-0700 (Pacific Daylight Time) G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position G90 ; absolute positioning G1 X50 Y50 F6000 ; go to first probe point used to be -13.3 G30 ; home Z by probing the bed ; Uncomment the following lines to lift Z after probing ;G91 ; relative positioning ;G1 Z5 F100 ; lift Z relative to current position ;G90 ; absolute positioning
; Configuration file for Duet WiFi (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.1.1 on Sun May 31 2020 21:54:40 GMT-0700 (Pacific Daylight Time) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"1M" ; set printer name ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet M587 S"MTS" P"Judy1985" ; Drives M569 P0 S0 ; physical drive 0 goes backwards X M569 P1 S1 ; physical drive 1 goes forwards RY M569 P2 S0 ; physical drive 2 goes backwards RZ M569 P3 S1 ; physical drive 3 goes forwards E M569 P5 S1 ; physical drive 5 goes forwards LY M569 P6 S0 ; physical drive 6 goes backwards LZ M584 X0 Y1:5 Z2:6 E3 ; set drive mapping M350 X16 Y16:16 Z16:16 E16 I1 ; configure microstepping with interpolation M92 X114.29 Y114.29:114.29 Z400.00:400.00 E420.00 ; set steps per mm M566 X300.00 Y100:100 Z12:12 E120.00 ; set maximum instantaneous speed changes (mm/min) M203 X2600.00 Y2600:2600 Z500:500 E1200.00 ; set maximum speeds (mm/min) M201 X100.00 Y50:50 Z20:20 E250.00 ; set accelerations (mm/s^2) M906 X800 Y1100:1100 Z600:600 E800 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X1400 Y800 Z900 S0 ; set axis maxima ; Endstops M574 X1 S1 P"xstop" ; configure active-high endstop for low end on X via pin xstop M574 Y1 S1 P"ystop" ; configure active-high endstop for low end on Y via pin ystop M574 Z1 S2 ; configure Z-probe endstop for low end on Z ; Z-Probe M950 S0 C"duex.e2heat" ; create servo pin 0 for BLTouch M558 P9 C"zprobe.in+zprobe.mod" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds G31 P500 X28.3 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height M557 X15:1350 Y50:750 S75 ; define mesh grid ; Heaters M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 M307 H0 B1 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M307 H0 A46.7 C538.0 D3.3 V24.0 ; bed tuning parameters M143 H0 S120 ; set temperature limit for heater 0 to 120C M308 S1 P"e0temp" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin e0temp M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit ; Fans M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Miscellaneous M911 S22 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss T0 ; select first tool ;M950 J1 C"!^duex.e2stop" ;M581 P1 T0 C0
@deltajegga Can you include your current config.g?
its still the same as up top except the last lines are
;M581 P1 T0 C0 -
Can you send M115 and verify that you're actually running 3.1.1?
Also, can you send M98 Pconfig.g and report any errors?
Also the content of M122 report please. -
If you are running 3.1.1 your M581 does require an S parameter.
https://duet3d.dozuki.com/Wiki/Gcode#Section_M581_RepRapFirmware_3_01RC2_and_later
M115
FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.1.1 ELECTRONICS: Duet WiFi 1.02 or later + DueX5 FIRMWARE_DATE: 2020-05-19b2no errors on M98 other than my hotend sensor its not installed yet nor is the extruder motor.
M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later + DueX5
Board ID: 08DLM-996RU-N8PS4-7J1F6-3SD6K-TUAZN
Used output buffers: 3 of 24 (11 max)
Static ram: 27980
Dynamic ram: 94324 of which 96 recycled
Exception stack ram used: 264
Never used ram: 8408
Tasks: NETWORK(ready,368) HEAT(blocked,848) DUEX(suspended,160) MAIN(running,1656) IDLE(ready,80)
Owned mutexes: WiFi(NETWORK)
Last reset 00:03:01 ago, cause: power up
Last software reset at 2020-06-20 13:22, reason: User, spinning module GCodes, available RAM 8252 bytes (slot 2)
Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
Error status: 0
MCU temperature: min 28.2, current 35.2, max 35.3
Supply voltage: min 23.9, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
Driver 5: standstill, SG min/max not available
Driver 6: standstill, SG min/max not available
Driver 7: standstill, SG min/max not available
Date/time: 2020-06-23 22:07:08
Cache data hit count 316873259
Slowest loop: 11.95ms; fastest: 0.12ms
=== Storage ===
Free file entries: 10
SD card longest read time 3.8ms, write time 6.0ms, max retries 0
Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
=== MainDDARing ===
Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
=== AuxDDARing ===
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
Daemon is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 22.99ms; fastest: 0.00ms
Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
HTTP sessions: 1 of 8- WiFi -
Network state is active
WiFi firmware version 1.23
WiFi MAC address bc:dd:c2:2d:67:63
WiFi Vcc 3.42, reset reason Unknown
WiFi flash size 4194304, free heap 19864
WiFi IP address 192.168.1.161
WiFi signal strength -53dBm, reconnections 0, sleep mode modem
Socket states: 0 4 0 0 0 0 0 0
=== DueX ===
Read count 3, 0.99 reads/min
- WiFi -
i tried
M581 P1 T0 C0 S1still a no go. heres a picture, the red switch on top goes from white/green to two white wires down to the duex endstop. it has 3 wires for NC or NO, but i assume that doesn't really matter with the inversion capability. if feel like im missing something obvious.
