    Kickstarter steppers
    • BlueDustundefined
      BlueDust
      Are these really as good as they say they are?
      What about when compared to E3d steppers?
      Can the Duet2/drivers understand the position data and know what to do with it?
      https://www.kickstarter.com/projects/249504031/ananasstepper-30-a-servo-stepper-for-multi-axis-control
      I can see these being very good for the Duet3 as they support CAN.
      Fun, that 3 letter word with "u" in the middle.
        I've asked whether they support CAN-FD and not just CAN. If they do, then with appropriate firmware they could be driven by Duet 3 over CAN,
        MaxGyverundefined 1 Reply Last reply Reply Quote 4
        • bbergerundefined
          bberger
          Are there any real benefits of using smart steppers on a Duet Delta?
          Just curious if it's worth going 1.8deg smart steppers with Polulu drivers over 0.9deg dumb ones on TMCs (noise, quality) wise?
          • Danalundefined
            Danal @bberger
            @bberger said in Kickstarter steppers:
            IMHO, No. At least not through a step/dir interface. If or when they are controlled by Duet via a bus, then, maybe.
            • bbergerundefined
              bberger
              Thought as much. Those smart steppers via Step/Dir don't really make sense to me. Imho the print is kinda ruined anyways if the extruder and the other axes don't know about the error and correct accordingly..
              • MaxGyverundefined
                MaxGyver @dc42
                Hey, did you receive any response concerning the question if the Ananas-Stepper does support CAN-FD?
                I am very interested in using them for a large format printer build with the Duet3.
                Cheers Max
                  No, I didn't receive a response.
                  We now have a closed-loop driver under development.
