    pretty sure my mesh isnt working... or isnt working well.
    1.3k
      Your trigger height still shows as 5mm. Have you done the calibration for that too?
      https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Section_Calibrate_the_Z_probe_trigger_height
      joehsmashundefined 2 Replies Last reply Reply Quote 0
      • joehsmashundefined
        joehsmash @Phaedrux
        @Phaedrux it does, because as stated previously i would have to redesign the BL touch mount which i will once i can actually print things,
        i didnt take into account the pin dropping so unretracted its actually around 2 mm off the bed, which is why when you look at the homeall.g i you can see why i raise the z to 10, before i probe.
          joehsmash @Phaedrux
          @Phaedrux also, am printing a bed level test now and its absolute rubbish. worse than before lol...
          the front side now isnt printing at all haha
            calibrating the trigger height won't require you to redesign the mount. It's a procedure to give you an accurate measurement of what your nozzle to bed distance is after probing.
            Have you used G30 S-1 to measure it yet?
              joehsmash @Phaedrux
              @Phaedrux yes a G30 S-1 give me the values of 5.30 consistantly
                joehsmash @Phaedrux
                @Phaedrux how ever isnt the probe tip supposed to be at the same level as the nozzle?
                all though the BL touch probes at 5.30mm when i actually touch the nozzle to the bed or atleast touch it to a 0.13mm feeler gauge the z height is set at 0.69mm when it should be 0.13ish
                  joehsmash
                  so right now, ive used a 0.05 feeler gauge to where it JUST touches the nozzle using 0.01 movements, than i removed the feeler gauge and dropped the nozzle down another 0.05 which should be touching the bed. only it doesnt actually move the nozzle.
                  its curious. i tried to send an M92 Z0 how it said that the command is sent how ever my z is still reporting to be a 0.44. when i send an M999 it resets like it should but it wont let me actually zero it.
                    Did you use M561 to cancel any active bed compensation?
                    https://duet3d.dozuki.com/Wiki/Gcode#Section_M561_Set_Identity_Transform
                    • JoergS5undefined
                      JoergS5 @joehsmash
                      @joehsmash I looked at your print tests and into the config again, the M208 limits are bigger area than the M557 region, so mayby the mesh points don't cover the lines left down side and there is no compensation. I am not sure about it, but maybe you want to test this idea.
                        That's a good point. Might be a good time to revisit your bed limits and then adjust your M557 a bit.
                        joehsmashundefined 1 Reply Last reply Reply Quote 0
                          joehsmash @Phaedrux
                          @JoergS5 & @Phaedrux i believe that was the culprit. i have matched the the mesh coords with the bed coords, also changed the build tak plate and shes smooth as a babys bottom now.
                          • JoergS5undefined
                            JoergS5 @joehsmash
                            @joehsmash thanks for confirmation, that was a tough one! Enjoy printing now
                            joehsmashundefined 1 Reply Last reply Reply Quote 1
                              joehsmash @JoergS5
                              @JoergS5 it was def super weird, i do remember because i had to move the probing to the centre of the bed, i had to be very aware of where the head was, so i shrunk the build volume to confirm, and i guess i never swapped it back.
                              maybe one day ill mess with it to make it bigger
                              thank you though!
                              and to @Phaedrux you guys are the bomb.com
