Duet3D connection
@Anna-Rolcova Was anything other than the main power connected to the Duet 3 when it failed?
Just drivers...
and ventilator and endstops.
Would you be able to provide a few close up well lit photos of both sides of the board?
@Phaedrux Yes!
I can also send these photos in high resolution to your mail.
V light indicator doesn't work. -
The board has not been cleaned?
One of the power inductors is clearly not soldered correctly (the big grey box with 6R8 thats at an angle with its pad next to it) - so the board will not work. But no signs of where any smoke would have originated. (maybe its neighbour is looking a bit toasty actually)\
in any case best to wait for the Duet people to take alook.
Thank you for the photos. 6R8 is definitely askew. Please contact your reseller and initiate a warranty return. Sorry for the inconvenience and thank you for your patience.
I strongly suspect that one of the 5V pins was shorted to ground when the smoke was produced, so please check your wiring very carefully,
@Phaedrux We bought the Duet3D directly from you (invoice no. 0043). Is it possible to send a new piece? Could you please contact me via email to resolve? Thank you.
@Anna-Rolcova said in Duet3D connection:
ref https://www.duet3d.com/warranty (and the form linked at the bottom)
As @bearer points out, please fill out the form.
