Duet 2 WiFi not working
Firmware installation
635
    Jesterize
    I upgraded the firmware on both the Duet 2 and the WiFi, but the WiFi keeps coming back with "WiFi module is being started" in YAT with 552 command. These are the steps I have run:
    • Ran M115 to check that the latest firmware is installed.
    • Ran M997 S1 to install the DuetWiFiFirmware.bin file.
    • Ran M552 S0 to put the WiFi module in idle mode
    • Run M552 to check that it is in idle mode but it is still "being started"
    • Ran M587 to add the SSID and password, but it comes back with "M587: Failed to add SSID to remembered list"
    I have tried reverting back to an older firmware version and wifi version. Same exact thing.
    Anything else I should be trying?
      Is this a new board?
        Jesterize
        Newish. From December.
          Was it ever working?
          What firmware version was on before?
          Does the wifi firmware version install?
          Can you provide the results of a M122?
            Jesterize
            • No it was never working. Just got it installed last night.
            • Not certain. Jumped to 3.1.1. Then, reverted back to 2.05.1
            • Again, not certain.
            • As soon as I get home, I will post the results of an M122
              Jesterize
              M122 results
              RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later
              Board ID: 08DGM-9T6BU-FG3SD-6JKD4-3SD6J-KUMHF
              Used output buffers: 1 of 24 (10 max)
              Static ram: 25712
              Dynamic ram: 92704 of which 0 recycled
              Exception stack ram used: 256
              Never used ram: 12400
              Tasks: NETWORK(ready,1876) HEAT(blocked,1232) MAIN(running,3864) IDLE(ready,160)
              Owned mutexes:
              Last reset 00:01:28 ago, cause: power up
              Last software reset time unknown, reason: User, spinning module GCodes, available RAM 11548 bytes (slot 0)
              Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x04433000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
              Error status: 0
              Free file entries: 10
              SD card 0 not detected, interface speed: 30.0MBytes/sec
              MCU temperature: min 29.4, current 29.7, max 29.8
              Supply voltage: min 0.9, current 0.9, max 1.0, under voltage events: 0, over voltage events: 0, power good: no
              Driver 0: ok, SG min/max not available
              Driver 1: ok, SG min/max not available
              Driver 2: ok, SG min/max not available
              Driver 3: ok, SG min/max not available
              Driver 4: ok, SG min/max not available
              Cache data hit count 132384348
              Slowest loop: 99.43ms; fastest: 0.06ms
              Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
              === DDARing ===
              Segments left: 0
              Stack records: 0 allocated, 0 in use
              Movement lock held by null
              http is idle in state(s) 0
              telnet is idle in state(s) 0
              file is idle in state(s) 0
              serial is ready with "M122" in state(s) 0
              aux is idle in state(s) 0
              daemon is idle in state(s) 0
              queue is idle in state(s) 0
              Code queue is empty.
              === Network ===
              Slowest loop: 0.15ms; fastest: 0.00ms
              HTTP sessions: 0 of 8
              • WiFi -
                Network state is starting
                WiFi module is disabled
                ok
              undefined 1 Reply Last reply 26 Jun 2020, 00:18 Reply Quote 0
                Jesterize @Jesterize
                That was after running a M552 S0 command
                  A Former User
                  @Jesterize said in Duet 2 WiFi not working:
                  put a new DuetWiFiServer.bin in /sys on the sd card and try running M997 S1 (or say yes to let DWC upgrade, if uploaded through DWC)
                  connect a usb* cable and connect to the serial console if you cannot see the update status in the DWC console.
                  *) please note https://duet3d.dozuki.com/Wiki/USB_ground_loops
                    Jesterize
                    Thanks bearer. Did that, went through the upload process, restarted it, ran M552 S0 and still getting "WiFi module is being started". Running a M122 still says WiFi module is disabled.
                      A Former User
                      just to confirm; it went through 5%, 10% ... 100% and said it was done?
                      undefined 1 Reply Last reply 26 Jun 2020, 00:59 Reply Quote 0
                        Jesterize @A Former User
                        @bearer Yup
                          Jesterize
                          Funny thing is that if I run a M587 command, I get this: M587: Failed to retrieve network list.
                          Why would it have trouble retrieving a list?
                            A Former User
                            either the (wifi) firmware is corrupted, or something has failed.
                            you might be able to get some answers by enabling wifi debug and issuing the firmware update again (will only work with serial console)
                            M111 P14 S1 and M997 S1
                            should look something like
                            Debugging enabled for modules: WiFi(14)
                            Debugging disabled for modules: Platform(0) Network(1) Webserver(2) GCodes(3) Move(4) Heat(5) DDA(6) Roland(7) Scanner(8) PrintMonitor(9) Storage(10) PortControl(11) DuetExpansion(12) FilamentSensors(13) Display(15) LinuxInterface(16)
                            Trying to connect at 230400 baud:success
                            Erasing 4096 bytes...
                            Erasing 212992 bytes...
                            Uploading file...
                            5% complete
                            10% complete
                            15% complete
                            20% complete
                            25% complete
                            30% complete
                            35% complete
                            40% complete
                            45% complete
                            50% complete
                            55% complete
                            60% complete
                            65% complete
                            70% complete
                            75% complete
                            80% complete
                            85% complete
                            90% complete
                            95% complete
                            Upload successful
                            WiFi:
                            WiFi:ets Jan8 2013,rst cause:2, boot mode:(3,6)
                            WiFi:
                            WiFi: load 0x4010f000, len 1384, room 16
                            WiFi: tail 8
                            WiFi: chksum 0x2d
                            ok
                            WiFi: csum 0x2d
                            WiFi: v3fff168c
                            WiFi: ~ld
                            WiFi module started
                            WiFi: mode : sta(84:f3:eb:42:b0:83)
                            WiFi: add if0
                            WiFi: wifi evt: 8
                            WiFi: scandone
                            WiFi: ../src/SocketServer.cpp(353): found network xxxxxxxxxxx
                            WiFi: sleep enable,type: 2
                            WiFi: wifi evt: 2
                            WiFi: scandone
                            WiFi: state: 0 -> 2 (b0)
                            WiFi: state: 2 -> 3 (0)
                            WiFi: state: 3 -> 5 (10)
                            WiFi: add 0
                            WiFi: aid 10
                            WiFi: cnt
                            WiFi:
                            WiFi: connected with xxxxxxxxxxx, channel 13
                            WiFi: dhcp client start...
                            WiFi: wifi evt: 0
                            WiFi: ip:10.10.0.196,mask:255.255.255.0,gw:10.10.0.3
                            WiFi module is connected to access point xxxxxxxxxxx, IP address 10.10.0.196
                            WiFi: wifi evt: 3
                            WiFi: pm open,type:2 0
                            edit:
                            if WiFi:ets Jan8 2013,rst cause:2, boot mode:(3,6) is different then most likely wifi or processor has failed
                            if WiFi: csum 0x2d and/or WiFi: v3fff168c is different, then most likely wrong firmware version (i.e. not v1.23) or corrupt binary
                            if it hangs after WiFi: ~ld then i'd wager something is broke, probably the wifi module, but could also be the processor.
                              Jesterize
                              Did that and this is what I got:
                              M111 P14 S1
                              M997 S1
                              Trying to connect at 230400 baud: success
                              Uploading file...
                              5% complete
                              10% complete
                              15% complete
                              20% complete
                              25% complete
                              30% complete
                              35% complete
                              40% complete
                              45% complete
                              50% complete
                              55% complete
                              60% complete
                              65% complete
                              70% complete
                              75% complete
                              80% complete
                              85% complete
                              90% complete
                              95% complete
                              Upload successful
                              ok
                                Jesterize
                                Missed the M552 S0. Got this:
                                M552 S0
                                WiFi:
                                WiFi: ets Jan 8 2013,rst cause:2, boot mode:(3,7)
                                WiFi:
                                WiFi: tail 8
                                WiFi: chksum 0x2d
                                WiFi: csum 0x2d
                                WiFi: v3fff168c
                                WiFi: ~ld
                                ok
                                  A Former User
                                  Nothing after ok?
                                  try M552 S-1 followed byM552 S0 it should give you the output from the ESP8266 bootloader at least
                                    Jesterize
                                    It looks like it is hanging on the ~ld. 😞 something is broken
                                      A Former User
                                      Ah, I might have done M552 S0 before M997 come to think of it.
                                      Anyways, it shows the ESP is trying to boot into mode 3,7 instead of 3,6 - I don't recall the specifics around that issue but smarter people than me should have all the necessary information now at least.
                                      undefined 1 Reply Last reply 26 Jun 2020, 02:20 Reply Quote 1
                                        Phaedrux Moderator @A Former User
                                        @bearer said in Duet 2 WiFi not working:
                                        I don't see anybody like that around at the moment. Will have to wait for DC to have a say.
                                        Only things I can think of to try in the meantime:
                                        1. redownload the wifi server bin file, check that the downloaded size matches, rename it and try flashing again
                                        2. Use these commands to try and clear the saved list of SSIDs and then try starting it again.
                                        M552 S0 ; Disable network module
                                        G4 S5 ; wait 5 seconds
                                        M588 S"*" ; Clear all saved wifi networks
                                          Jesterize
                                          After doing all that, I get this "Error: M588: Failed to reset the WiFi module to factory settings"
                                          Thanks for trying guys! Hopefully, DC has some good news. Fingers crossed.
                                          ? 1 Reply Last reply 26 Jun 2020, 17:11 Reply Quote 0
                                          1 out of 24
