    Duet 2 Wifi voltage problem is it the hardware?
    412
    • tkdirpundefined
      tkdirp
      I believe I sorted out the software...
      When I connected to the power supply, this happens
      IMG_2106.jpgand I can't get the web control to work
      but when I connect the power supply and the computer all the voltages seemed to be getting received and the web control works.
        A Former User
        same as:
        @bearer said in No power using 24v psu:
        Check your fuse, make sure the int_5v jumper is in place and inspect the board for damage (or upload a picture). Something is preventing the onboard 5v circuit from working.
        • tkdirpundefined
          tkdirp
            A Former User
            is this just debris or a hole in the chip?
            (its the prime suspect for your problem in general)
              A Former User
              and i meant this fuse
              • tkdirpundefined
                tkdirp
                Oh... so the most likely problem is the chip?
                  A Former User @tkdirp
                  @tkdirp said in Duet 2 Wifi voltage problem is it the hardware?:
                  that is the chip that make the 5v and in turn 3.3v so if it has a hole in it, yes.
                  tkdirpundefined 1 Reply Last reply Reply Quote 0
                  • tkdirpundefined
                    tkdirp @A Former User
                    @bearer how do I solve this issue?
                      I'd wait for the Duet people to drop in and ask a few questions around the circumstances and take it from there.
                      You can continue setting up the build and configuring providing 5v via usb, just beware of https://duet3d.dozuki.com/Wiki/USB_ground_loops
                      To save yourself some time, add when/where it was purchased as its one of the things the Duet people will ask anyways.
                      • tkdirpundefined
                        tkdirp
                        24v Duet 2 wifi bord
                        because of school and iterating the motion platform design I had not much time to work on the software side of things.
                        • tkdirpundefined
                          tkdirp
                          So @dc42, what can I do in this circumstance with the hardware?
                            Is it correct to say you've had the board for a year now but only recently installed it?
                            • tkdirpundefined
                              tkdirp @Phaedrux
                              @Phaedrux Yes, that is the case
                                While we can't offer warranty replacement on this unit we can offer a possible refurbished unit on exchange. Please contact Roland on sales@Duet3d.com to inquire. Include a link to this thread.
