Duet3d 3 custom Delta printer inconsistant motor problems.
877
    Oliver3d @JoergS5
    @JoergS5
    This is the m122 result:
    M122
    RepRapFirmware for Duet 3 MB6HC version 3.1.1 running on Duet 3 MB6HC v0.6 or 1.0 (standalone mode)
    Board ID: 08DJM-956L2-G43S4-6JTDJ-3SJ6L-9866G
    Used output buffers: 1 of 40 (11 max)
    Static ram: 154604
    Dynamic ram: 161696 of which 52 recycled
    Exception stack ram used: 464
    Never used ram: 76400
    Tasks: NETWORK(ready,364) ETHERNET(blocked,436) HEAT(blocked,1200) CanReceiv(suspended,3820) CanSender(suspended,1432) CanClock(blocked,1424) TMC(blocked,68) MAIN(running,4512) IDLE(ready,76)
    Owned mutexes:
    Last reset 00:03:07 ago, cause: software
    Last software reset at 2020-06-25 16:05, reason: User, spinning module GCodes, available RAM 76336 bytes (slot 1)
    Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task MAIN
    Error status: 0
    MCU temperature: min 41.1, current 41.4, max 41.6
    Supply voltage: min 12.7, current 13.2, max 13.6, under voltage events: 0, over voltage events: 0, power good: yes
    12V rail voltage: min 12.0, current 12.2, max 12.5, under voltage events: 0
    Driver 0: standstill, reads 65489, writes 11 timeouts 0, SG min/max 0/0
    Driver 1: standstill, reads 65487, writes 14 timeouts 0, SG min/max 0/0
    Driver 2: standstill, reads 65491, writes 11 timeouts 0, SG min/max 0/0
    Driver 3: standstill, reads 65483, writes 19 timeouts 0, SG min/max 0/1023
    Driver 4: standstill, reads 65484, writes 19 timeouts 0, SG min/max 0/1023
    Driver 5: standstill, reads 65484, writes 19 timeouts 0, SG min/max 0/1023
    Date/time: 2020-06-25 16:08:16
    Slowest loop: 5.23ms; fastest: 0.21ms
    === Storage ===
    Free file entries: 10
    SD card longest read time 3.2ms, write time 0.0ms, max retries 0
    Hiccups: 0(0), FreeDm: 375, MinFreeDm: 372, MaxWait: 39233ms
    === MainDDARing ===
    Scheduled moves: 9, completed moves: 9, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
    === AuxDDARing ===
    Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
    Segments left: 0
    Movement lock held by null
    HTTP is idle in state(s) 0
    Telnet is idle in state(s) 0
    File is idle in state(s) 0
    USB is idle in state(s) 0
    Aux is idle in state(s) 0
    Trigger is idle in state(s) 0
    Queue is idle in state(s) 0
    LCD is idle in state(s) 0
    SBC is idle in state(s) 0
    Daemon is idle in state(s) 0
    Aux2 is idle in state(s) 0
    Code queue is empty.
    === Network ===
    Slowest loop: 5.57ms; fastest: 0.03ms
    HTTP sessions: 1 of 8
    • Ethernet -
      State: active
      Error counts: 0 0 0 0 0
      === CAN ===
      Messages sent 750, longest wait 0ms for type 0
      === Linux interface ===
      State: 0, failed transfers: 0
      Last transfer: 187220ms ago
      RX/TX seq numbers: 0/1
      SPI underruns 0, overruns 0
      Number of disconnects: 0
      Buffer RX/TX: 0/0-0
      What motor current are you setting?
      You may get better results from 24v power.
      undefined 1 Reply Last reply 25 Jun 2020, 23:35 Reply Quote 0
        Oliver3d @Phaedrux
        @Phaedrux
        I reduce the motor current down to 2400mA
        I tried changing to 24V on the supply voltage but it has do effect on the EMF numbers
          Oliver3d
          I changed the Max Speed on X and Y axis's to 200mm/s and left the Z axis at 50/mm/s and this seems to work better. I was mostly having problems when moving in the Z axis.
          I have noticed that even when set to 200mm/s it is only able to reach 100mm/s actual speed.
          ; generated by RepRapFirmware Configuration Tool v3.1.3 on Thu Jun 25 2020 16:04:10 GMT-0700 (Pacific Daylight Time)
          M550 P"OLIVER3DPRINTER" ; set printer name
          M665 R224.78 L573.5 B200 H650 ; Set delta radius, diagonal rod length, printable radius and homed height
          M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them
          M586 P0 S1 ; enable HTTP
          M586 P1 S0 ; disable FTP
          M586 P2 S0 ; disable Telnet
          M569 P0.5 S0 ; physical drive 0.5 goes backwards
          M569 P0.3 S0 ; physical drive 0.3 goes backwards
          M569 P0.4 S0 ; physical drive 0.4 goes backwards
          M584 X0.5 Y0.3 Z0.4 E0.1 ; set drive mapping
          M350 X8 Y8 Z8 E16 I1 ; configure microstepping with interpolation
          M92 X320.00 Y320.00 Z320.00 E663.00 ; set steps per mm
          M566 X3000.00 Y3000.00 Z1800.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
          M203 X12000.00 Y12000.00 Z3000.00 E1200.00 ; set maximum speeds (mm/min)
          M201 X1000.00 Y1000.00 Z500.00 E1000.00 ; set accelerations (mm/s^2)
          M906 X2500 Y2500 Z2500 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M208 Z0 S1 ; set minimum Z
          M574 X2 S1 P"io1.in" ; configure active-high endstop for high end on X via pin io1.in
          M574 Y2 S1 P"io3.in" ; configure active-high endstop for high end on Y via pin io3.in
          M574 Z2 S1 P"io4.in" ; configure active-high endstop for high end on Z via pin io4.in
          M558 P3 R0.4 C"io5.in+io6.out" H0 F1200 T2400 ; set Z probe type to effector and the dive height + speeds
          M558 H30 ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
          G31 P850 X0 Y0 Z-0.01 ; set Z probe trigger value, offset and trigger height
          M557 R200 S50 ; define mesh grid
          M308 S0 P"temp0" Y"pt1000" R2200 ; configure sensor 0 as PT1000 on pin temp0
          M308 S1 P"temp1" Y"pt1000" R2200 ; configure sensor 1 as PT1000 on pin temp1
          M950 F0 C"out3" Q500 ; create fan 0 on pin out3 and set its frequency
          M950 F1 C"out4" Q500 ; create fan 1 on pin out4 and set its frequency
          ; Custom settings
          M575 P1 B57600 S1
          undefined 1 Reply Last reply 26 Jun 2020, 06:55 Reply Quote 0
            JoergS5 @Oliver3d
            @Oliver3d said in Duet3d 3 custom Delta printer inconsistant motor problems.:
            This may be valid (but please see below), because the speed depends on what you print. If you print short distances with changing directions, the acceleration and deceleration distances are a high percentage of total distance, so in average you have much lower speed than maximum speed.
            Delta printers have to segment even straight lines, because a straight line is a coordinated nonlinear movement of all three axis. This is specific to Delta printers. E . g. there is no Z axis which stands still if you print a layer, all three steppers move all the time. The 3D printer has to calculate a lot, it is good that you use a powerful Duet 3 for a big Delta.
            But for a delta printer 200 mm/s are still low, they are especially known for high speeds, so I am sure you can further optimize. But better one step after the other, you have achieved some improvements already. (and I would make a backup of the current configuration 😉 )
            But in most cases it is not the XYZ speed the limit, but extrusion speed of the hotend/filament.
            I just see you have a weakness in configuration:
            There is no difference between XY and Z at a Delta printer, they work together as described above, so you should set them the same value (M203, M201 also). This will speed up your printer.
            undefined 1 Reply Last reply 26 Jun 2020, 22:30 Reply Quote 2
              Phaedrux Moderator @JoergS5
              @JoergS5 said in Duet3d 3 custom Delta printer inconsistant motor problems.:
              Bingo!
                Oliver3d
                Up until yesterday afternoon I was using equal speeds on all 3 axis's but mostly having problems with the motors stalling when I tried to move in the Z axis.
                I noticed that when you send a command to the printer to move in X or Y axis the print head moves in a straight line, i.e. moving 3 motors simultaneously, not motor X or motor Y as you would expect in a Cartesian style machine.
                So moving the print head 100mm/s doesn't mean any of the motors are moving at 100mm/s.
                With the speeds set as they are now when I move the print head up and down (Z Axis) then 40mm/s seems to be the limit for all 3 motors. But when I move the head left/right or front/back (X and Y axis) the I can increase the mm/s because the motors stay below the 40mm/s even if the head is moving at 100mm/s
                Something else I've noticed is even if I set the X and Y mm/s at 200mm/s to will only achieve 100mm/s, and this seems like its being limited in the software rather then a hardware issue. I may try programing a different pitch for the ballscrews to test this theory
                I still feel that I should be able to get much faster speeds and this may come down to changing the pitch on the ball screws or adding a belt drive to speed up the maximum RPM the motors can putout.
                undefined 2 Replies Last reply 27 Jun 2020, 08:53 Reply Quote 0
                  JoergS5 @Oliver3d
                  @Oliver3d
                  According to config and discussion before, you have a Delta printer. This is not a Cartesian style machine. Every X, Y and Z movement is built from the 3 motors simultanesously.
                  You should be aware that there are two different meanings of X (and Y, Z):
                  • real world coordinates X, Y, Z, the common meaning of coordinates
                  • X, Y, Z for the stepper movements. I would prefer to name them A, B, C.
                  So your A, B, C movements result in a X, Y, Z movement.
                  Cartesian: A=>X, B=>Y, C=>Z
                  CoreXY: A and B => X, A and B => Y, C=>Z *)
                  Delta: A, B, and C => X, A, B and C => Y, A, B and C => Z *)
                  *) A, B, C connected by some formulae (eg. CoreXY (A+B)/2=>X )
                  Especially at Delta the A,B,C=>X (and Y,Z) are complicated trigonometric functions, so calculation is complex, a powerful processor is advantageous.
                  In G-Code the two meanings are mixed unhappily, some examples:
                  • normal G1 X Y Z => X, Y, Z movements, realworld
                  • G1 H2 X Y Z => A, B, C movements of single motors
                  • G31 X Y Z => X, Y, Z distances
                  • M92, M203, M566, M201, M906 X, Y, Z => A, B, C related
                  • M574 X, Y, Z => A, B, C related
                  So anytime you see an X, Y, Z in G-Code, you have to ask first which of the two possibilities it is.
                  undefined 1 Reply Last reply 27 Jun 2020, 16:55 Reply Quote 0
                    JoergS5 @Oliver3d
                    It may be easier and cheaper to assemble a gear between stepper and ball bear, but this comes at a cost, a diminished torque. I would calculate with the EMF calculator first, whether you have the optimal stepper and replace them. This may be the easiest solution.
                    There is another option for the stepper: a servo like iHSV JMC based, there are some discussions on the forum. You need an additional card for Duet 3 however to drive it. The iHSV is motor driver and servo in one unit. The advantage would be that the torque doesn't diminish at high speed.
                    But please allow me to repeat the hint above: the limiting factor is often extrusion speed of the hotend, not the stepper speeds for the axes. Better calculate the maximum extrusion speed first. Otherwise you waste money for a high speed which cannot be used.
                      Oliver3d @JoergS5
                      @JoergS5
                      Sorry I didn't explain myself very well.
                      What I was trying to explain in my earlier post is that I have the motor speeds set as at different speeds because when moving in Z axis at 40mm/s motors A, B and C all move at 40mm/s, this seems to be the fastest I can get it to move in this axis as I think I'm maxing out the RPM's. (420 motor RPM / 60 = 7 Rev Per Second X 5mm pitch on the ballscrew = 35mm/s). So in RRF config I have the Z axis set at 40mm/s
                      But for the X and Y axis I have it set at 200mm/s because this seems to set the real world X and Y speed not the motors A and B feed speeds.
                      This confused me for a while but labeling the motors A, B, and C makes things a bit clearer in my head anyway.
                      Unfortunately this still doesn't explain why if I have the X and Y speeds set to 200mm/s I'm only getting 100mm/s, and this speed stops exactly at 100mm/s so I suspect its a software issue rather than hardware.
                      I would rather be limited by extrusion speed, but know I have the potential to go faster if needed that the other way around, I am building a tool changer in to the design so future hot-ends, lasers or "pick and place" tools could require more speed. I think with the size of motors I new have installed torque shouldn't be a problem.
                      undefined 1 Reply Last reply 27 Jun 2020, 17:14 Reply Quote 0
                        JoergS5 @Oliver3d
                        @Oliver3d you are right with your ball screw calculation. That is the main reason why most users use belts for X and Y (or XZY for Deltas). For Belt with 20 teeth pulley you get 40 mm for a stepper full rotation, for your ball screw you get 5 mm. To compensate, you need a gear between stepper and ball screw or a faster stepper (or higher pitch, as you said). The maximum speed for a normal Nema 17 is told to be around 1000 rpm, so about 16 rounds per second. So you could achieve about 80 mm/s without a gear *). The iHSV I mentioned has maximum 3000 rpm and there is a model for 4000 rpm which was tested and reported in this forum.
                        *) this is not totally correct, because the Delta uses three arms for the movement, hotend speed will be higher.
                        If your X Y axis (or A and B steppers) have the same setup as your ball screw axis, you would not achieve 200 mm/s there also. You can try 200 mm/s for all three axis and make a M122 report whether it shows errors due to lost steps.
                          Oliver3d
                          So after spending most of the weekend finishing up the missing parts and tweaking the config file, I finally was able to start a print.
                          Things seemed to be going well for the first 3 layers, I had lowered the feeds to 75mm/s from 100mm/s, because at that speed one of the motors had stalled a couple of times but after stalling restarting the system seemed to fix the problem.
                          During the 3rd layer the head dived in to the print bed and broke the heat break. I'm guessing one of the motors stalled again.
                          I checked the temperature of the motors and they didn't seem to hot and all the mechanical parts are fine.
                          After the crash I hit emergency stop and then ran M122 for this report
                          M122
                          Used output buffers: 3 of 40 (6 max)
                          Static ram: 154604
                          Dynamic ram: 161924 of which 32 recycled
                          Exception stack ram used: 272
                          Never used ram: 76384
                          Tasks: NETWORK(ready,620) ETHERNET(blocked,432) HEAT(blocked,1176) CanReceiv(suspended,3820) CanSender(suspended,1488) CanClock(blocked,1424) TMC(blocked,204) MAIN(running,4528) IDLE(ready,76)
                          Owned mutexes:
                          Last reset 00:03:26 ago, cause: software
                          Last software reset at 2020-06-28 21:07, reason: User, spinning module GCodes, available RAM 76136 bytes (slot 0)
                          Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x04437000 BFAR 0x00000000 SP 0xffffffff Task MAIN
                          Error status: 0
                          MCU temperature: min 42.6, current 42.7, max 43.5
                          Supply voltage: min 13.1, current 13.1, max 13.3, under voltage events: 0, over voltage events: 0, power good: yes
                          12V rail voltage: min 12.1, current 12.2, max 12.2, under voltage events: 0
                          Driver 0: standstill, reads 33464, writes 11 timeouts 0, SG min/max 0/0
                          Driver 1: standstill, reads 33464, writes 11 timeouts 0, SG min/max 0/0
                          Driver 2: standstill, reads 33462, writes 14 timeouts 0, SG min/max 0/0
                          Driver 3: standstill, reads 33462, writes 14 timeouts 0, SG min/max 0/0
                          Driver 4: standstill, reads 33464, writes 14 timeouts 0, SG min/max 0/0
                          Driver 5: standstill, reads 33464, writes 14 timeouts 0, SG min/max 0/0
                          Date/time: 2020-06-28 21:10:38
                          Slowest loop: 4.69ms; fastest: 0.22ms
                          === Storage ===
                          SD card longest read time 3.1ms, write time 0.0ms, max retries 0
                          === MainDDARing ===
                          === AuxDDARing ===
                          Segments left: 0
                          === Network ===
                          Slowest loop: 7.96ms; fastest: 0.03ms
                          • Ethernet -
                            State: active
                            === CAN ===
                            Messages sent 825, longest wait 0ms for type 0
                            Last transfer: 206508ms ago
                            Buffer RX/TX: 0/0-0
                          ; generated by RepRapFirmware Configuration Tool v3.1.3 on Sun Jun 28 2020 20:22:16 GMT-0700 (Pacific Daylight Time)
                          M665 R224.78 L573.5 B200 H500 ; Set delta radius, diagonal rod length, printable radius and homed height
                          M569 P0.2 S0 ; physical drive 0.2 goes backwards
                          M584 X0.5 Y0.3 Z0.4 E0.2 ; set drive mapping
                          M92 X640.00 Y640.00 Z640.00 E812.17 ; set steps per mm
                          M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
                          M203 X4500.00 Y4500.00 Z1800.00 E1200.00 ; set maximum speeds (mm/min)
                          M201 X500.00 Y500.00 Z300.00 E1000.00 ; set accelerations (mm/s^2)
                          M906 X2400 Y2400 Z2400 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
                          M558 P3 R0.4 C"io5.in+io6.out" H0 F1200 T1800 ; set Z probe type to effector and the dive height + speeds
                          M308 S0 P"temp0" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 0 as thermistor on pin temp0
                          M950 H0 C"out1" T0 ; create bed heater output on out1 and map it to sensor 0
                          M143 H0 S250 ; set temperature limit for heater 0 to 250C
                          M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
                          M950 H1 C"out2" T1 ; create nozzle heater output on out2 and map it to sensor 1
                          M950 F0 C"out4" Q500 ; create fan 0 on pin out4 and set its frequency
                          M950 F1 C"out3" Q500 ; create fan 1 on pin out3 and set its frequency
                          M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off
                          M563 P1 S"TITAN AQUA" D0 H1 F1 ; define tool 1
                          ; Custom settings
                          M575 P1 B57600 S1
                          Appreciate any thoughts as to why I'm having these problems
                          undefined 1 Reply Last reply 29 Jun 2020, 06:56 Reply Quote 0
                            JoergS5 @Oliver3d
                            @Oliver3d the spinning modules occured two times (known to me) in those threads, may help you:
                            https://forum.duet3d.com/topic/3211/software-reset-stuck-in-spin-loop-spinning-module-printmonitor
                            and
                            https://forum.duet3d.com/topic/5674/damned-crash-stuck-in-spin-loop
                            Please search for "spinning module", there are several forum threads with possible reasons discussed.
                            Checking SD card would be one action you can do.
                              Oliver3d
                              So after a few more days tweaking Ive got everything working slowly so I am 99% sure the main problem was that I was reaching maximum RPM on the motors.
                              I cleaned out all the files from the SD Card and did a completely new install and calibration that also may have helped
                              I now have a 32v Power supply coming that should help with getting the EMF numbers in the green and I'm designing a belt drive to speed up the ballcrews.
                              So with this combination I should be able to speed things up a little.
                              In the mean time I'm going to start work on the tool changer and spool mounts etc.
                              Once again thank you for the on going assistance.
                              undefined 1 Reply Last reply 4 Jul 2020, 07:11 Reply Quote 0
                                JoergS5 @Oliver3d
                                @Oliver3d I wish you good luck. It would be interesting what speed and precision you achieve. It would be nice if you can tell the restults.
                                Regarding Belt drives, ball screws etc. I learned a lot from the CNC expert Möderl (EMS), you may find ideas on his pages. Unfortunatey it's only in german.
                                • undefined JoergS5 referenced this topic 23 Jan 2024, 07:04
                                16 out of 21
