Unsolved Duet maestro stops in the middle of the print and resets.
Ok, thanks for chasing down that hunch. Please continue to provide an M122 after it resets.
@TRex, with reference to https://duet3d.dozuki.com/Wiki/Duet_2_Maestro_Wiring_Diagram, do you have anything connected to the 13x1 header strip labelled EXPANSiON on the Maestro? In particular, a wire connected to the RESET pin on that connector?
@dc42 No, nothing on any of the pins
@dc42 Do you have any other ideas?
@Phaedrux @dc42 The DIAG LED is on all the time if that could help.
I'm so fustrated with this printer that I've almost given up, finally had it up and running and printing fine for a while, and then the duet starts with this problem, the one component I thought I wouldn't have any problems with.
In contrast to my ender3 with no problems at all at a 1/10 of the costNew M122, when printing for a while:
Correction: The DIAG LED turns on (and stays on until reset) when I home z (BLTouch), just when the motors starts it seams like. I have 3 Z-motors, 2 of them on the expanion module.
But if I drive z without homing, it stays off. I'll try a print without homing z to see what happens.
diag on after using bl-touch is normal.
@bearer Tnx. Then that's not the problem.
It didn't help to print with BLtouch disconnected either so.
M122 right after reset:
It's also resets when it's in idle
Hi, sorry to see it's still acting up. How old is the board and where did you purchase it?
@Phaedrux I bought it from filafarm.de in March 2019
In that case it is well outside of the warranty period, and while we can't offer warranty replacement on this unit we can offer a possible refurbished unit on exchange. Please contact Roland on sales@Duet3d.com to inquire. Include a link to this thread.
@Phaedrux Thanks. I'll do that.
