    Duet3 + supervolcano + 24v/12v+MOSFET??
    • duttiundefined
      dutti
      Hey,
      I want to connect the E3d supervolcano. I have here a 12 v or 24 v version.
      Are there any explanations to wire up the MOSFET correctly?
      Thanks to all
      Nxt-1undefined 1 Reply Last reply Reply Quote 0
        If your system is 24V then you don't need to use the mosfet, but be sure to use ferrules where the heater wires connect to the terminal block.
        • Nxt-1undefined
          Nxt-1 @dutti
          @barbarossa-cologne As far as I know, the 24V does not come with a mosfet, mine did not at least. I have used my 24V successfully with a Duet Wifi and wired it just like any old regular heater.
          Hope this helps
          -Nxt
          Duet3D and delta printer enthousiast. Buildlog
          Looking for Duet3D configuration support, check out Nxt-3D
          • duttiundefined
            dutti
            I have a version with 12v and mosfet and another 24v without mosfet.
            So I can decide which I use
            ok. thanks for the fast answer.
              dc42 administrators @dutti
              @barbarossa-cologne said in Duet3 + supervolcano + 24v/12v+MOSFET??:
              Only if you can still also choose whether to power your Duet from 12V or 24V.
              • duttiundefined
                dutti
                I have a power supply with 24v. So I´ll take the 24v version on out1.
                Sounds right?
                thanks
                  Sounds right?
                  thanks
                  Yes.
