    When will there be a Duet 3 config file?
    987
      A Former User
      yes, ref the link above
      • kdsands88undefined
        kdsands88
        No, reference above is not the answer.
        Build two CNC machine, do multi-rotors. I know what slaving two stepper motors/drivers is.
        Again, I input to the Z and Z motor and E0 motor outputs the same steps. They are slaved together.
        How do I do this from the config wizard?
        Again,lulsbot has two z-axis.
        https://www.lulzbot.com/
          I don't understand what you mean. Can you post your config.g and describe what you're trying to achieve?
          M584 X0 Y1 Z2:4 E3; two Z motors connected to driver outputs Z and E1
            kdsands88
            I am trying to generate a config file from this website:
            https://configtool.reprapfirmware.org/Start
            I do not have a config file yet.
              A Former User @kdsands88
              @kdsands88 said in When will there be a Duet 3 config file?:
              you still cannot do it in the config wizzard, but you can add the second motor to any axis by understanding how M584 works (after having generated config with just 1 motor)
                kdsands88
                OK, I understand I cannot slave two motors in the config wizard.
                So, I ask my question again
                Question: how do I generate these files manually?
                  Start with the config generator and then edit the file manually. That will be the normal mode of operation going forward.
                    kdsands88
                    Why is "That will be the normal mode of operation going forward."
                    This is not acceptable.
                    So, Duet3D does not support their products?
                    Again, made two CNC from https://linuxcnc.org/ and never had this kind of problems before.
                    1 Reply Last reply Reply Quote -1
                      kdsands88
                      Answer:
                      https://forum.duet3d.com/topic/10133/m584-format-question-please
                      For the Duet 3 formatting:
                      M584 X0.0 Y0.1 Z0.2:0.3 E0.4 ; set drive mapping -- Setup slave motor Z-axis to driver 2 and 3
                      Why can't this be done in the config wizard? I do not know.
                        A Former User
                        The 0. part of X0.0 is redundant when you only have the one Duet3 board without expansions, remove that and you're back to what was posted to you earlier.
                        Maybe put some more effort into educating yourself and less in trying to project some sort of misguided superiority?
                          Sorry to fail to meet your expectations. The config tool is always evolving. Along with the transition to rrf3 and the dropping of rrf2 will allow for much more flexibility. Until then this is the current state. However editing the config in real time using the web interface on the duet is a major feature and advantage.
                            kdsands88
                            First, I am not superior.
                            Could I get FastBot to work? No.
                            Could I get Replicape - Kamikaze or Replicape - Umikaze? No.
                            I am just frustrate with companies pushing product that they do not supported.
                            Again, CNClinux.org has been doing this for over 20 years. This is not something new.
                            Phaedruxundefined A Former User? 2 Replies Last reply Reply Quote 0
                              Phaedrux Moderator @kdsands88
                              I'm not sure what you mean by do not support. You're here getting support.
                              • zaptaundefined
                                zapta
                                Here is an official getting started doc https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3 . "It is a work in progress and we are actively expanding it and producing more guides.". I would suggest to start their and post any question you may have.
                                There is a significant number of people here that made it to work though it's relatively new so probably not as mature as Duet2.
                                  @kdsands88
                                  Spoiled child syndrome much.
                                  You very much come across as "I'm going to scream and scream until I get what I want.
                                  I would advise that you go buy a smoothie board and then rock up to the smoothie forum and ask Arthur Wolff a question with the attitude you are displaying here.
                                  Come back and let us know how that goes for you.
                                    Alright lets not let this get out of hand please.
                                      A Former User @Phaedrux
                                      @Phaedrux
                                      The results of parents not spanking their children are now being felt around the world......
                                      zaptaundefined 1 Reply Last reply Reply Quote 1
                                        Be that as it may, if we have nothing nice to say, say nothing at all, would abide well here.
                                          @Phaedrux
                                          Ignorance is bliss and no matter how unpalatable the truth can be, it is truth none the less.
                                          • zaptaundefined
                                            zapta @A Former User
                                            @CaLviNx said in When will there be a Duet 3 config file?:
                                            This can be interpreted both ways. 😉
