Motor speed limits
@SnowDrifter M203 could be what you search for, https://duet3d.dozuki.com/Wiki/Gcode#Section_M203_Set_maximum_feedrate
The feedrates are axis values. -
A coreXY machine doesn't obey traditional by-axis speeds
This post is deleted! -
@SnowDrifter What is the purpose of this thread? Are you asking a question, making a statement, asking for advice, or requesting a change or additional feature?
Ultimately, the maximum motor speed will be determined by the torque curve of the motor(s). The maximum acceleration is a function of that torque divided by the mass to be moved and the maximum speed can therefore be calculated as sqrt(2x acceleration x distance/2). Most machines will never attain the maximum motor speed unless the axes travel distances are large enough to accommodate the acceleration and deceleration phases. In general terms, it is the rate of acceleration that the machine can withstand which will determine the maximum speed that can be attained. But that only applies to non-print moves. Print moves will be limited by the speed at which filament can be melted and extruded and those moves will be far below the motor speed limits.
@deckingman said in Motor speed limits:
It's a feature request. I want to limit individual motor speeds as the traditional X and Y speeds don't apply well to a corxy since everything's 'rotated' 45 degrees.
@SnowDrifter said in Motor speed limits:
That's sounds as a well defined request since the motor has it's own rotational speed limit (pulse rate and such) and the ratio of head linear distance to motor's rotational speed varies with the head's position.
I will leave to others to determine if this is a useful feature or not.
Apropos max speed, just stumbled upon this video where the duet is pushed to its speed limit.
@zapta said in Motor speed limits:
Which kind of indicates that having a limits for motor speed is somewhat irrelevant IMO.
Here is another view of same printer. It seems to move from island to island in zero time. As if the moves were edited out.
@zapta That is seriously fast travel speed - love it!
I wonder if this is the same person... @PAULDGROOT
