    endstop trigger and bangbang questions
    1.8k
    • deltajeggaundefined
      deltajegga
      hahaha, silly me. i guess it would help if i uncommented them.
      ok i get a value of 0 back.
      and if i send the m950 j1 i get back
      Pin !duex.e2stop, active: false
        Phaedrux Moderator @deltajegga
        @deltajegga said in endstop trigger and bangbang questions:
        M950 J1 C"!^duex.e2stop"
        M581 P1 T0 C0 S1
        And with this? Does it work as expected?
          deltajegga
          no, it still resetes if i home
            I wonder if having the wiring bundled like that is causing the e stop switch pick up the signal from the endstop.
            Usually when I'm making my looms I always twist the wires to try and prevent cross talk. Can you physically separate the wiring for the e stop from the bundle and test again?
              deltajegga
              ok, interesting. so that solved the triggering when it shouldent problem. (i allways thought that only pwm and data lines cared about twisting.)
              but it still wont trigger when i press the button. just a reminder im using a normally open switch.
                Try changing it to normally closed. This should be configurable with the S0 S1 switch, but it's worth a shot.
                I twist or braid everything when using cramped conduits. Just as a matter of habit.
                  deltajegga
                  yeah still nothing.
                    And you're sure the switch really works?
                    Do you have a regular endstop microswitch you can connect in its place to test?
                      deltajegga
                      yeah i tested it with a multimeter at the plug on the duex.
                        droftarts administrators @deltajegga
                        @deltajegga In RRF 3.1.1, the 'C' parameter has changed to 'R'. See https://duet3d.dozuki.com/Wiki/Gcode#Section_M581_RepRapFirmware_3_01RC2_and_later
                        Try changing command to M581 P1 T0 R0 S1
                          deltajegga
                          damn, got my hopes up. i tried that with !, ^, and !^ on the pin name but still nothing. here is a refresh of the config.
                          ; generated by RepRapFirmware Configuration Tool v3.1.1 on Sun May 31 2020 21:54:40 GMT-0700 (Pacific Daylight Time)
                          G90                                                ; send absolute coordinates...
                          M83                                                ; ...but relative extruder moves
                          M550 P"1M"                                         ; set printer name
                          M552 S1                                            ; enable network
                          M586 P0 S1                                         ; enable HTTP
                          M586 P1 S0                                         ; disable FTP
                          M586 P2 S0                                         ; disable Telnet
                          M587 S"MTS" P"Judy1985"
                          M569 P0 S0                              ; physical drive 0 goes backwards  X
                          M569 P1 S0                              ; physical drive 1 goes forwards   RY
                          M569 P2 S0                              ; physical drive 2 goes backwards  RZ
                          M569 P3 S0                              ; physical drive 3 goes forwards   E
                          M569 P5 S1                              ; physical drive 5 goes forwards   LY
                          M569 P6 S0                              ; physical drive 6 goes backwards  LZ
                          M584 X0 Y1:5 Z6:2 E3                                     ; set drive mapping
                          M350 X16 Y16:16 Z16:16 E16 I1                            ; configure microstepping with interpolation
                          M92 X114.29 Y114.29:114.29 Z400.00:400.00 E420.00        ; set steps per mm
                          M566 X300.00 Y300:300 Z12:12 E120.00                     ; set maximum instantaneous speed changes (mm/min)
                          M203 X4000.00 Y4000:4000 Z500:500 E1200.00               ; set maximum speeds (mm/min)
                          M201 X150.00 Y150:150 Z20:20 E250.00                     ; set accelerations (mm/s^2)
                          M906 X800 Y1100:1100 Z600:600 E800 I50                   ; set motor currents (mA) and motor idle factor in per cent
                          M84 S90                                                  ; Set idle timeout
                          M208 X0 Y0 Z0 S1                                   ; set axis min
                          M208 X1400 Y880 Z900 S0                            ; set axis max
                          M574 X1 S1 P"xstop"                                ; configure active-high endstop for low end on X via pin xstop
                          M574 Y1 S1 P"ystop"                                ; configure active-high endstop for low end on Y via pin ystop
                          M574 Z1 S2                                         ; configure Z-probe endstop for low end on Z
                          M950 S0 C"duex.e2heat"                             ; create servo pin 0 for BLTouch
                          M558 P9 C"zprobe.in+zprobe.mod" H10 F400 T8000      ; set Z probe type to bltouch and the dive height + speeds
                          G31 P25 X28.3 Y0 Z1.3                             ; set Z probe trigger value, offset and trigger height    INCREASE Z TO MOVE CLOSER TO BED
                          M557 X50:1380 Y50:870 S100                          ; define mesh grid
                          M308 S0 P"bedtemp" Y"thermistor" T100000 B4138     ; configure sensor 0 as thermistor on pin bedtemp
                          M950 H0 C"bedheat" T0                              ; create bed heater output on bedheat and map it to sensor 0
                          M307 H0 B0 S1.00 A137 D6.4 C1400                   ; enable PID mode for the bed heater and set PWM limit
                          M140 H0                                            ; map heated bed to heater 0
                          M143 H0 S120                                       ; set temperature limit for heater 0 to 120C
                          M308 S1 P"e0temp" Y"thermistor" T100000 B4138      ; configure sensor 1 as thermistor on pin e0temp
                          M950 H1 C"e0heat" T1                               ; create nozzle heater output on e0heat and map it to sensor 1
                          M307 H1 B0 S1.00                                   ; disable bang-bang mode for heater  and set PWM limit
                          M950 F0 C"fan0" Q500                               ; create fan 0 on pin fan0 and set its frequency
                          M106 P0 S0 H-1                                     ; set fan 0 value. Thermostatic control is turned off
                          M563 P0 D0 H1 F0                                   ; define tool 0
                          G10 P0 X0 Y0 Z0                                    ; set tool 0 axis offsets
                          G10 P0 R0 S0                                       ; set initial tool 0 active and standby temperatures to 0C
                          M671 X50:1480 Y400:400 S10                         ; x gantry leveling
                          M911 S22 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
                          T0                                                 ; select first tool
                          M950 J1 C"duex.e2stop"
                          M581 P1 T0 R0 S1                              ;emergency stop
