Automatically setting M558 Z value
The head reference point 0,0,0 is usually the nozzle tip of the T0 and every other offset is from that. It just keeps things simple. So I guess I don't really understand your question.
If you give stall detection another try and it works for you, you might even be able to use it as your main probe and eliminate the probe offset entirely.
@Phaedrux I managed to get the stall detection working. I just reduced the motor current to 25% and then set the sensitivity to 10 and that seems to work nicely.
but the M500 P10:31 does save the probe offset but only the Z part, the X and Y it set both to 0 rather than what they are supposed to be set at(X55 and Y48). is there a way to change that?
I'm not sure. Have you tried just using M500 P31? I thought you were trying to save the height offset. The X Y offset isn't changing so you can just set it in your normal G31. Not sure why you'd want to save a tool offset as well.
@Phaedrux nope but I’ll give that a try.
@Phaedrux I seem to be having an issue with the M500 P31 command while executed inside of a macro.
;Macro for Z probless testing ;G28 X Y Z ;Home all individually M561 ; do not use mesh tranform M400 ;Configure to probe bed with BLTouch M558 P9 C"^io4.in" H60 F200 T12000 ; set Z probe type to BL touch and the dive height + speeds G1 X-55 Y-48 F12000 ; Move BLTouch to center of the bed M18 E0:1 ; Disable stepper drivers for extruders G30 ; Probe bed and set position to probe offset G1 X0 Y0 F12000 ; Move tool head to center of bed ;G1 Z100 F600 ; Move Z-axis to 100mm G1 Z10 F350 ; Move Z-axis slowly to 10mm ; configure the sensorless homeing here M400 ; make sure everything has stopped before we make changes M574 Z1 S3 ; set Z endstop to use motor stall M915 Z S10 F1 H200 R1 ; Configure stall detection M913 Z25 ; reduce motor current to 25% to prevent belts slipping ; Start to move Z axis to test the stall detection G1 H1 Z-2 F300 ; move the bed up until it hits something then stop and set to limit minimum G92 Z0 ; Set current postion to Z0 rather than axis minimum G91 ; Set to relative movement G1 Z5 F650 ; Move bed down a few mm so that we can centre the head G90 ; back to absolute positioning ; Configure stall detection as a bed probe ;M400 ; compete all moves before makeing changes ;M558 P10 X0 Y0 Z0 F200 T12000 H3 ; Configure Z probe as stall detection with Z offset of 0 ;G1 X0 Y0 F12000 ; Move to center of the bed ;G30 ; Probe the bed in the center with stall detection and set position to Z offset ;G1 Z10 F300 ; Move the bed down to 10mm ; Set back the probe to BLTouch M400 M558 P9 C"^io4.in" H3 F200 T12000 ; set Z probe type to BL touch and the dive height + speeds G1 X-55 Y-48 F12000 ; Move BLTouch to center of the bed M18 E0:1 ; Disable stepper drivers for extruders G30 S-3 ; Probe the bed and report the height at which the probe was triggered ; Restore the use of the maximum limit switch on Z. M400 ; make sure everything has stopped before we reset the motor currents M913 Z100 ; motor currents back to normal M574 Z2 S1 P"io2.in" ; configure active-high endstop for high end on Z via pin io2.in use a NC switch G1 Z10 F250 ; Move Z axis to 10mm M400 ; Wait until all code is executed G31 X-55 Y-48 ; Reset probe offsets G31 ; Recall Probe parameters M500 P10:31 ; Save parameters to Config-overide.g
If I check the config-overide.g after this has executed the
; Z probe parameters G31 P500 X0.0 Y0.0 Z0.70
which is not correct.
If i run the M500 P31 after the macro has finished executing then I get; Z probe parameters G31 P500 X-55.0 Y-48.0 Z2.68
Which is correct. Am I chasing a dead end trying to run M500 from inside a macro as it is not possible, or have I missed something in my macro.
Firmware version?
@Phaedrux 3.1.1. I upgraded at your recommendation on the BLTouch issue I was having which turned out to be interference from the extruder steppers being active.
Ah yes. We'll have to see what @DC42 has to say about the difference between in the macro and out of the macro execution of M500 P31.
@Phaedrux I've also setup my bed.g to call that macro as part of the bed calibration so that it is super easy to call with the G32. I end off the bed.g with an M500 G31 to see if that helps. But right now I have a failed print laying on the bed and I don't feel like driving across down for an hour to clear it off. So I won't be able to do anymore testing where the nozzle has to touch the bed for a day or so.
@Phaedrux well I was able to get the bed cleared off and run my G32 (bed.g) which I added a link to my macro and after the macro I added the M500 P31 in the bed.g and that saved the offsets correctly. So that gets me a work around.
