    Added Duex5 - Really need some help
    1.2k
      Phaedrux Moderator @GeorgeM
      @GeorgeM said in Added Duex5 - Really need some help:
      Could it be reporting on the duex driver even though nothing is attached to it?
      Maybe? I'm not exactly sure how the duex drivers are numbered, but I would think that driver5 would be the E1 driver.
      Question is, do any of your drivers actually get hot? The warning temp would indicate that they are too hot to touch.
      I'm still not clear on how and when you are using the U axis. You don't have a U axis endstop defined, so I don't think you're using it for leveling.
      • GeorgeMundefined
        GeorgeM
        None of the motors or drivers get hot as this this error appears as soon as I turn the machine on. I'm convinced the error is from the duex. Here is the link on driver numbering. https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors#Section_Stepper_Driver_Numbering
        Which tells me I have a bad duex2. If I disconnect the duex the error goes away.
        I am using the U as a second Z motor to get independent leveling using the BLTouch. When I home Z it will home in the middle, then go to the right edge and home, then go to the left edge and home, then either the left or right motor will be adjusted, then it will go to the center and home the last time.
        George
          You do not need a U axis to do that.
          https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors
          Can you post your homing files and bed.g so I can see what you're actually doing? I think you should remove the definitions for all the U axis as I think it may be causing problems.
          • GeorgeMundefined
            GeorgeM
            I cant find the original thread that I followed when I originally set up the independent Z probing that showed using U. I have a print going right now but when it is finished I will comment them out and see what difference it makes.
            bed.g
            ; bed.g
            ; generated by RepRapFirmware Configuration Tool v3.1.3 on Wed Jun 17 2020 09:39:08 GMT-0600 (Mountain Daylight Time)
            G28 Z ; home
            G30 P0 X20 Y150 Z-99999 ; probe near a leadscrew, half way along Y axis
            G30 P1 X285 Y150 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motors
            G90 ; absolute positioning
            G1 X150 Y150 F7000 ; go to center
            G30 ; home z
            homeall.g
            ; homeall.g
            ; called to home all axes
            G91 ; relative positioning
            G1 H1 X-235 F4000 ; move quickly to X axis endstop and stop there (first pass)
            G1 H2 X5 F6000 ; go back a few mm
            G1 H1 X-235 F360 ; move slowly to X axis endstop once more (second pass)
            ;G1 H2 Z-5 F6000 ; lower Z again
            ;G90 ; absolute positioning
            ;G91 ; relative positioning
            ;G1 H2 Z5 F6000 ; lift Z relative to current position
            G1 H1 Y-225 F4000 ; move quickly to Y axis endstop and stop there (first pass)
            G1 H2 Y5 F6000 ; go back a few mm
            G1 H1 Y-225 F360 ; move slowly to Y axis endstop once more (second pass)
            G32
            homex.g
            ; homex.g
            ; called to home the X axis
            G1 H1 X-235 F2600 ; move quickly to X axis endstop and stop there (first pass)
            homey.g
            ; homey.g
            ; called to home the Y axis
            G1 H1 Y-225 F2800 ; move quickly to Y axis endstop and stop there (first pass)
            homez.g
            ; homez.g
            ; called to home the Z axis
            G1 X150 Y150 F6000 ; go to first probe point
              The creation of the U axis is only needed when doing leveling using endstops. The Z axis is split into Z and U and each side is leveled by homing to the endstops. But you are using a probe, so no U endstop, and so no need for a U axis. None of your files even call to move it.
              When using the probe to level as described in that link you only need provide the locations of the lead screws with M671 in config.g, assign your motors to the Z axis, and then in bed.g probe close to the lead screws.
              Your separate issue of the driver overheating warning on the Duex is of greater concern. I would suggest that you connect a motor to each driver on the duex in turn and configure it and test movement to establish whether your duex drivers are all functional.
              • GeorgeMundefined
                GeorgeM
                @Phaedrux said in Added Duex5 - Really need some help:
                Isn't the BLTouch acting like an endstop? I just changed the config.g with all mention of the U parameters deleted. When I rebooted I still had the driver 5 error. Also I got no movement from any axis when trying to home. That is because the homing calls for the Z to be raised first. So, since I have the Z defined to include two drivers, the Z does not work without the U parameters included. I purposely skewed the table to the side a bit and when I restarted with the U parameters included, it homed and leveled the bed perfectly as it has been doing all along. From what I understand, the adjustment done to either the Z or U axis is done automatically after it is probed on both the right and left side. It is not a movement called out in the config.g file, but in fact I can visibly watch one or the other motors adjust after the probe.
                I am first to admit that I am a novice at this, but I can confirm what has been working and what hasn't been.
                I am now going to disconnect the duex and see if that eliminates the error.
                George
                Phaedruxundefined 2 Replies Last reply Reply Quote 0
                • GeorgeMundefined
                  GeorgeM
                  I disconnected the duex again. The error went away. I reconnected it. The error is back.
                  Do we need to get David aware of this in order to OK a replacement? Not sure of what the procedure is except I remember another thread where a customer said he needed David ok to get a part replaced.
                  George
                    No, it's acting like a probe.
                    That's not how it works.
                    M584 X0 Y1 Z2:4 E3 assigns the drivers to their axis. Now when you set values for the axis they apply to all drivers assigned to that axis. So any command for the Z axis applies to both driver 2 and 4.
                    Please read that link and you'll see what I'm talking about. The only difference between what's described in that link and what you have configured is that you've also added commands for the U axis, which doesn't exist because it was never created with M584.
                    I'm not a novice, but I'm not omniscient either. Together we can work out what is happening and understand why.
                    For now that is a good idea.
                    Yes, that's what's happening in your bed.g. But there is no U axis.
                      Can you share that version of your config?
                      • GeorgeMundefined
                        GeorgeM
                        Ok, I went and changed it line by line. I am able to get rid of all the U parameters except in M92. If I delete them in M92 it will not work.
                        ; generated by RepRapFirmware Configuration Tool v3.1.3 on Mon Jun 15 2020 11:14:50 GMT-0600 (Mountain Daylight Time)
                        M550 P"My Printer" ; set printer name
                        M669 K1 ; select CoreXY mode
                        M552 S1 ; enable network
                        M586 P0 S1 ; enable HTTP
                        M586 P1 S0 ; disable FTP
                        M586 P2 S0 ; disable Telnet
                        M569 P0 S0 ; physical drive 0 goes backwords - X
                        M569 P1 S0 ; physical drive 1 goes backwards - Y
                        M569 P2 S0 ; physical drive 2 goes backwards - Z right side
                        M569 P3 S1 ; physical drive 3 goes forwards - Exturder
                        M569 P4 S0 ; physical drive 4 goes backward - Z left side
                        M584 X0 Y1 Z2:4 E3 ;two Z Motors connected to driver outputs Z and E1
                        M671 X-20:310 Y0:0 S2 ;Leadscrew at left (connected to Z) and right connected to E1) of X axis
                        M92 X101.84 Y104.96 Z402.42 U402.42 E2892.00 ; set steps per mm
                        M566 X500.00 Y500.00 Z100.00 E60.00 ; set maximum instantaneous speed changes (mm/min)
                        M203 X10000.00 Y10000.00 Z6000.00 E8000.00 ; set maximum speeds (mm/min)
                        M201 X800.00 Y800.00 Z30.00 E120.00 ; set accelerations (mm/s^2)
                        M906 X1200.00 Y1200.00 Z800.00 E500.00 I30 ; set motor currents (mA) and motor idle factor in per cent
                        M84 S30 ; Set idle timeout
                        M208 X-25 Y-15 Z0 S1 ; set axis minima
                        M208 X330 Y340 Z300 S0 ; set axis maxima
                        ;M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
                        M950 S0 C"duex.pwm1" ; create servo pin 0 for BLTouch
                        M558 P9 C"zprobe.in" H3 F120 T4800 ; set Z probe type to bltouch and the dive height + speeds
                        G31 P25 X30 Y-10 Z.48 ; set Z probe trigger value, offset and trigger height
                        M557 X15:285 Y15:275 P4:4 ; define mesh grid
                        M376 H10
                        M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 R4700 ; configure sensor 0 as thermistor on pin bedtemp
                        M307 H0 B0 S1.00 ; diable bang-bang mode for the bed heater and set PWM limit
                        M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
                        M143 H1 S300 ; Set temperature limit for heater 1 to 300C
                        M308 S5 P"drivers" Y"drivers" A"Driver" ; set virtual heater for stepper drivers
                        M950 F3 C"duex.fan3" Q1000 ; create fan 3 on pin fan3 and set its frequency
                        M106 P3 S0 H-1 ; set fan 3 value. Thermostatic control is turned off
                        M308 S4 P"mcu-temp" Y"mcu-temp" A"MCU" ; set virtual heater for MCU
                        M950 F4 C"!duex.fan4" Q25000 ; Define Fan_4 for use - Duet board cooling - PWM fan
                        M106 P4 S4 T45:65 H100:101:102 ; set fan 4 value, turn if the CPU temp (or driver temps) reaches 45C, increase to full speed at 65C
                        M563 P0 S"E3D_V6" D0 H1 F0 ; define tool 0
                        M563 P2 S"Laser" F3 ` ; define tool 2
                        G10 P2 X0 Y0 Z0 ; set tool 2 axis offsets
                        ;G10 P2 R0 S0 ; set initial tool 2 active and standby temperatures to 0C
                        M501 ; Load saved parameters from non-volatile memory
                        • GeorgeMundefined
                          GeorgeM
                          by the way, Thank you for the time you are spending on this for me.
                            What exactly does it do?
                            Where are your motors plugged in?
                            With the U stuff completely removed and the Duex disconnected what do you get when you send M98 P"config.g"?
                            • GeorgeMundefined
                              GeorgeM
                              When I try to home it stays busy and the arrow circles spins and then I get a homing error.
                              Same with either x or y. Same if I comment out the raising of z before I home.
                              Motors are plugged into:
                              X in 0
                              Y in 1
                              Z in 2
                              E in 3 or E0
                              U in 4 or E1
                              Well what do you know. With the duex removed and U removed from M92, it homed correctly.
                              With the duex reconnected and U removed from M92 - no movement and driver 5 error is back.
                              • GeorgeMundefined
                                GeorgeM
                                I need to leave for about 90 minutes
                                  The first point I expected. The second point is still perplexing.
                                  What happens with duex connected and M92 U removed?
                                  GeorgeMundefined 1 Reply Last reply Reply Quote 0
                                  • GeorgeMundefined
                                    GeorgeM @Phaedrux
                                    • GeorgeMundefined
                                      GeorgeM
                                      As a sanity check, I configured X to use driver 5. When doing so I get no movement from X motor.
                                        How have you the Duex wired?
                                        https://duet3d.dozuki.com/Wiki/Duex2_and_Duex5_Features#Section_Wiring
                                        • GeorgeMundefined
                                          GeorgeM @Phaedrux
                                          Exactly like that.
                                            I think you have a failed driver 5 on your Duex. When was it purchased and from where?
