    Added Duex5 - Really need some help
    1.2k
    • GeorgeMundefined
      GeorgeM
      I disconnected the duex again. The error went away. I reconnected it. The error is back.
      Do we need to get David aware of this in order to OK a replacement? Not sure of what the procedure is except I remember another thread where a customer said he needed David ok to get a part replaced.
      George
        Phaedrux Moderator @GeorgeM
        @GeorgeM said in Added Duex5 - Really need some help:
        Isn't the BLTouch acting like an endstop?
        No, it's acting like a probe.
        So, since I have the Z defined to include two drivers, the Z does not work without the U parameters included.
        That's not how it works.
        M584 X0 Y1 Z2:4 E3 assigns the drivers to their axis. Now when you set values for the axis they apply to all drivers assigned to that axis. So any command for the Z axis applies to both driver 2 and 4.
        https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors
        Please read that link and you'll see what I'm talking about. The only difference between what's described in that link and what you have configured is that you've also added commands for the U axis, which doesn't exist because it was never created with M584.
        I am first to admit that I am a novice at this, but I can confirm what has been working and what hasn't been.
        I'm not a novice, but I'm not omniscient either. Together we can work out what is happening and understand why.
        I am now going to disconnect the duex and see if that eliminates the error.
        For now that is a good idea.
        From what I understand, the adjustment done to either the Z or U axis is done automatically after it is probed on both the right and left side
        Yes, that's what's happening in your bed.g. But there is no U axis.
          I just changed the config.g with all mention of the U parameters deleted.
          Can you share that version of your config?
          • GeorgeMundefined
            GeorgeM
            Ok, I went and changed it line by line. I am able to get rid of all the U parameters except in M92. If I delete them in M92 it will not work.
            ; generated by RepRapFirmware Configuration Tool v3.1.3 on Mon Jun 15 2020 11:14:50 GMT-0600 (Mountain Daylight Time)
            M550 P"My Printer" ; set printer name
            M669 K1 ; select CoreXY mode
            M552 S1 ; enable network
            M586 P0 S1 ; enable HTTP
            M586 P1 S0 ; disable FTP
            M586 P2 S0 ; disable Telnet
            M569 P0 S0 ; physical drive 0 goes backwords - X
            M569 P1 S0 ; physical drive 1 goes backwards - Y
            M569 P2 S0 ; physical drive 2 goes backwards - Z right side
            M569 P3 S1 ; physical drive 3 goes forwards - Exturder
            M569 P4 S0 ; physical drive 4 goes backward - Z left side
            M584 X0 Y1 Z2:4 E3 ;two Z Motors connected to driver outputs Z and E1
            M671 X-20:310 Y0:0 S2 ;Leadscrew at left (connected to Z) and right connected to E1) of X axis
            M92 X101.84 Y104.96 Z402.42 U402.42 E2892.00 ; set steps per mm
            M566 X500.00 Y500.00 Z100.00 E60.00 ; set maximum instantaneous speed changes (mm/min)
            M203 X10000.00 Y10000.00 Z6000.00 E8000.00 ; set maximum speeds (mm/min)
            M201 X800.00 Y800.00 Z30.00 E120.00 ; set accelerations (mm/s^2)
            M906 X1200.00 Y1200.00 Z800.00 E500.00 I30 ; set motor currents (mA) and motor idle factor in per cent
            M84 S30 ; Set idle timeout
            M208 X-25 Y-15 Z0 S1 ; set axis minima
            M208 X330 Y340 Z300 S0 ; set axis maxima
            ;M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
            M950 S0 C"duex.pwm1" ; create servo pin 0 for BLTouch
            M558 P9 C"zprobe.in" H3 F120 T4800 ; set Z probe type to bltouch and the dive height + speeds
            G31 P25 X30 Y-10 Z.48 ; set Z probe trigger value, offset and trigger height
            M557 X15:285 Y15:275 P4:4 ; define mesh grid
            M376 H10
            M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 R4700 ; configure sensor 0 as thermistor on pin bedtemp
            M307 H0 B0 S1.00 ; diable bang-bang mode for the bed heater and set PWM limit
            M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
            M143 H1 S300 ; Set temperature limit for heater 1 to 300C
            M308 S5 P"drivers" Y"drivers" A"Driver" ; set virtual heater for stepper drivers
            M950 F3 C"duex.fan3" Q1000 ; create fan 3 on pin fan3 and set its frequency
            M106 P3 S0 H-1 ; set fan 3 value. Thermostatic control is turned off
            M308 S4 P"mcu-temp" Y"mcu-temp" A"MCU" ; set virtual heater for MCU
            M950 F4 C"!duex.fan4" Q25000 ; Define Fan_4 for use - Duet board cooling - PWM fan
            M106 P4 S4 T45:65 H100:101:102 ; set fan 4 value, turn if the CPU temp (or driver temps) reaches 45C, increase to full speed at 65C
            M563 P0 S"E3D_V6" D0 H1 F0 ; define tool 0
            M563 P2 S"Laser" F3 ` ; define tool 2
            G10 P2 X0 Y0 Z0 ; set tool 2 axis offsets
            ;G10 P2 R0 S0 ; set initial tool 2 active and standby temperatures to 0C
            M501 ; Load saved parameters from non-volatile memory
            • GeorgeMundefined
              GeorgeM
              by the way, Thank you for the time you are spending on this for me.
                What exactly does it do?
                Where are your motors plugged in?
                With the U stuff completely removed and the Duex disconnected what do you get when you send M98 P"config.g"?
                • GeorgeMundefined
                  GeorgeM
                  When I try to home it stays busy and the arrow circles spins and then I get a homing error.
                  Same with either x or y. Same if I comment out the raising of z before I home.
                  Motors are plugged into:
                  X in 0
                  Y in 1
                  Z in 2
                  E in 3 or E0
                  U in 4 or E1
                  Well what do you know. With the duex removed and U removed from M92, it homed correctly.
                  With the duex reconnected and U removed from M92 - no movement and driver 5 error is back.
                  • GeorgeMundefined
                    GeorgeM
                    I need to leave for about 90 minutes
                      The first point I expected. The second point is still perplexing.
                      What happens with duex connected and M92 U removed?
                      GeorgeMundefined 1 Reply Last reply Reply Quote 0
                      • GeorgeMundefined
                        GeorgeM @Phaedrux
                        @Phaedrux said in Added Duex5 - Really need some help:
                        • GeorgeMundefined
                          GeorgeM
                          As a sanity check, I configured X to use driver 5. When doing so I get no movement from X motor.
                            How have you the Duex wired?
                            https://duet3d.dozuki.com/Wiki/Duex2_and_Duex5_Features#Section_Wiring
                            • GeorgeMundefined
                              GeorgeM @Phaedrux
                              Exactly like that.
                                I think you have a failed driver 5 on your Duex. When was it purchased and from where?
                                • GeorgeMundefined
                                  GeorgeM @Phaedrux
                                  June 26 from Filastruder. I contacted Tim there and gave him the link to this thread.
                                    Well at least our endeavour wasn't totally fruitless.
                                    • GeorgeMundefined
                                      GeorgeM
                                      I do appreciate all your attention to this. You were able to get me corrected about the U parameters. That's a win.
                                      I do need to start a new thread about why my laser wont operate from gcode commands.
