    Conditional gcode help required - New Problem
    Gcode meta commands
    2.2k
      deckingman
      I now have a new problem which is frying my brain somewhat. I have this macro to set the tool temps to zero at the end of a print:
      while iterations < #tools
      if tools[iterations] != null
      echo "Setting temp for tool T", iterations
      G10 P{iterations} S0 R0 ; - set it's active and standby temperature
      It is correctly indented - but this forum removes the indents when I do a copy and paste.
      This macro works like a charm if I simply run it. But when I put inside my "Post-Print" macro I get a bunch of errors - "Error G10: 'iterations' used when not inside a loop". And of course the temperatures don't get changed. But I can run that macro "stand alone", immediately afterwards and it'll work just fine.
      Here is my Post-Print Macro
      ;End print gcode
      G10 ; retract
      G91 ; set relative
      G1 Z5 F240 ; move bed down 5mm
      G90 ; back to absolute
      G1 X165 Y300 F9000 ; move to rear
      M98 P"0:/macros/ToolTemps/ToolTemps0.g" ; set the tool temperatures to 0
      M140 S0 ; turn off bed
      M106 S0 ; turn off part fan
      M291 P"Print finished" R"Post-Print Macro" S1 T10
      What is really frying my brain is that I do something very similar in a Pre-Print macro which calls another almost identical macro to set the tool temps to 210, and that works as expected.
      For the sake of completeness, here is a "Pre-Print" macro which works as expected
      ; Pre-print gcode 45deg bed, 210 hot end
      M291 P"Heating bed to 40 degC " R"Pre-Print PLA" S1 T10
      M190 S40; start heating bed and wait for it to get to 40
      M291 P"Homing all axes" R"Pre-Print PLA" S1 T10
      M140 S45; Now start to heat bed to 45 but don't wait
      M98 P"0:/macros/PrePrintHome.g" ; home all axes (at high temp)
      M98 P"0:/macros/ToolTemps/ToolTemps210.g" ; set the tool temperatures to 210
      G1 X80 Y363 F9000 ; move to rear
      M83;
      M291 P"Waiting for heaters to reach active temperatures" R"Pre-Print Macro" S1 T10
      M116 ; wait for all temps including hot end
      M291 P"Wiping nozzle" R"Pre-Print PLA" S1 T5
      M98 P"0:/macros/Nozzle wipe"
      So, I can't fathom why calling a macro to set the tool temps works from within a "pre-print" macro and also "stand alone" but calling it from within my post-print macro brings up errors.
        @deckingman said in Conditional gcode help required - New Problem:
        If you use code escapes (three back-quote characters at the start and end of the block) then it will preserve the indentation:
        Please either post the contents of the non-working macro in this way, or attach it as a file
        • arhiundefined
          arhi @deckingman
          you can do it like this:
          or withot "type of the code" like this
          and if you want to quote it in-line you do it like this
          • arhiundefined
            arhi
            looking at the code it should work as expected. better upload files directly as this "space formatting" can be the source of the problem
              deckingman
              OK. Thanks all for the info about preserving indentations.
              By a process of elimination I have isolated what causes the error. It is the preceding Z move. That is is to say, if I comment out the two lines below so I have ..........
              G10 ; retract
              ;G91 ; set relative
              ;G1 Z5 F240 ; move bed down 5mm
              ..............Then I get no errors and the macro runs just fine.
              Or if I just re-arrange things so that the macro runs before the Z move, it works fine too. i.e. I now have.................
              ;End print gcode
              G10 ; retract
              G91 ; set relative
              ........and this work fine. So it's either the preceding G91 switching to relative, or the G1 Z5 that breaks the conditional macro.
                A Former User @arhi
                @arhi said in Conditional gcode help required - New Problem:
                you can even escape things with \ like `quote it in-line` becomes quote it in-line 🤓 and then you can go all inception to show \`quote it in-line\` and then you can... 😇
                edit: you can use double (as in two) quotes to avoid escaping single quotes (and three to escape two and so on..)
                ``single `quote` `` becomes single `quote`
                  deckingman
                  I spoke too soon. I just ran a print with the end gcode macro as per my last post above and received the errors "Error G10: 'iterations' used when not inside a loop". I ran that same post-print macro again, and it worked without errors on that second try.
                  So it's seemingly random. Some times it runs without error, other times I get those errors.
                  Here is the macro yet again:
                    Can you confirm that you are running firmware 3.1.1 on the main board?
                      deckingman @dc42
                      @dc42 said in Conditional gcode help required - New Problem:
                      Yup
                      M122
                      RepRapFirmware for Duet 3 MB6HC version 3.1.1 running on Duet 3 MB6HC v0.6 or 1.0 (standalone mode)
                      M122 B1
                      Diagnostics for board 1:
                      Board EXP3HC firmware 3.1.0 (2020-05-15b1)
                      Don't know if it makes any difference but all the extruders are connected to expansion boards 1 and 2 and the hot end heater and thermistor are on expansion board 1.
                        deckingman
                        Does nobody have any idea why that macro sometimes works and at other times throws up errors - "iterations used when not inside a loop". Interestingly, the other very similar macros which set the tool temperatures to high values and which are used at the start of a print always work. It's just this one which sets the temperature to zero at the end of a print.
                        Because it is erratic and unpredictable, I've had to go back to my old way of doing things and use a number of macros, each with a fixed but different number of G10 Pnn S0 R0 commands, rather than use the while loop. Otherwise, more often than not, the tools will all remain at print temperature when a print finishes which is highly undesirable.
                        OwenDundefined 1 Reply Last reply Reply Quote 0
                        • OwenDundefined
                          OwenD @deckingman
                          @deckingman
                          If it works sometimes and not others I suspect an unhandled exception. I.e. the firmware isn't getting what it expected.
                          It may help in diagnosing if you add a delay after the echo and add an "else" section to notify when a null value is being returned by your if statement (also with an echo and delay)
                          I'd also do a "finished" section for good measure.
                          I suspect if you don't have sequential numbering on the tools something may be going awry that you aren't seeing.
                          Those changes should help determine which "iteration" is giving the grief
                            deckingman @OwenD
                            @OwenD Thanks -
                            I don't know if it helps but actually I get one error for every tool that exists. The tools are always sequentially numbered, so for example if I have 11 tools numbered from 0 to 10, then I get 11 error messages.
                            And as I said, running an almost identical macro at the start of a print to set the tool temperatures to (say) 210, always works. But I'll add the delays and an else section and see what happens.
                              Ian, does this issue only occur when you call that macro from within end.g, or can you reproduce it in any other way?
                                deckingman @dc42
                                Unfortunately, it isn't as clear cut as that. I've just spent the last couple of hours trying to provoke it to misbehave. It seems the only time it will misbehave is at the end of a print. But running the post print macro on it's own (which in turn calls the tool temps macro), does not make it misbehave.
                                To recap, the macro which provokes errors (at the end of a print) is this:
                                It is called from within this macro which is called "PostPrint.g":
                                G10 ; retract
                                G91 ; set relative
                                I can run that "PostPrint" macro any time and it runs without errors. Yet when it is called from the end of a print, I get the "iterations used when not inside a loop" errors (11 of them - 1 for each tool)
                                When I get the errors, I can send M98 P"PostPrint.g" and it will run without errors.
                                This is the end of a gcode file that I've just finished
                                G1 X107.377 Y142.526 E0.05564
                                G10 ; retract
                                M107
                                ; Filament-specific end gcode
                                ;END gcode for filament
                                ;end
                                ;end
                                M98 P"0:/macros/PostPrint.g"
                                ; filament used = 17028.6mm (41.0cm3)
                                ; total filament cost = 0.0
                                .........lots more comments after this
                                Could those filament specific comments that the slicer puts in before the M98 macro call screw things up?
                                I've tried running the last gcode commands in order - i.e. G10 followed by M107 followed by the M98 P... but that does not provoke the errors.
                                Weird or what?
                                  A Former User
                                  can you upload a sample print file along with the config? stuck in the countryside for a rainy weekend, never know, might find the time to poke it
                                    deckingman @A Former User
                                    @bearer Thanks. I've sent you a chat message with shareable link to a folder that I have created on my Google Drive, which contains what I think are all the relevant files.
                                      deckingman
                                      OK. So by a process of elimination, I have found the reason (but not the cause) for the errors and a work around. I created a gcode file with simply the start part and the end part of a print file which provokes the problem. That is to say, with all the G1 moves removed. Running that did provoke the problem. Then I progressively removed various commands until I ended with simply this:
                                      M98 P"0:/macros/PrePrintPETG.g"
                                      ;G21 ; set units to millimeters
                                      ;G90 ; use absolute coordinates
                                      ;M83 ; use relative distances for e
                                      M107
                                      ..........and that will provoke the problem when run as a print file. Yet running those commands "stand alone" via the console does not provoke the problem - it has to be done as a print from the sd card.
                                      The work around is to put M400 before that second "post print" macro (or indeed at the start of that macro before the call to the second "tool temps" macro).
                                      If that's how it has to be, that's fine by me, but I suggest it be documented somewhere so as to help others in the future.
                                      HTH
                                        Thanks, that will make it easier for me to track down.
                                          deckingman @dc42
                                          No worries. I have those macros in a folder on my google drive so I can send you a shareable link if you want to replicate things exactly.
                                            Thanks, I've reproduced the fault using those files, and I'm looking into it.
