    Duet 2 Ethernet and SBC
    Beta Firmware
    29
    302
    35.0k
      A Former User @smoki3
      @smoki3 said in Duet 2 Ethernet and SBC:
      8cm
      should be okay, still try lowering "SpiFrequency": 8000000, to say 2000000 in /opt/dsf/conf/config.json and restart DCS (sudo systemctl restart duetcontrolserver) ?
      smoki3undefined 1 Reply Last reply Reply Quote 0
      • wilrikerundefined
        wilriker
        IAP is fixed now also on master branch.
        Manuel
        My Tool Collection
          A Former User @wilriker
          @wilriker said in Duet 2 Ethernet and SBC:
          btw i think there was a slight hickup with it refusing M997 S0 - but can't reproduce it after it did update with both DWC asking to update and M997 without S0.
          • wilrikerundefined
            wilriker @A Former User
            @bearer Since there is only one type of firmware to update it is unnecessary to provide a Snnn parameter to M997 in the first place but I agree that it should not result in either a warning or worse an error. If you can reproduce it, please post here.
            Manuel
            My Tool Collection
            • wilrikerundefined
              wilriker @smoki3
              If I try to flash the firmware over DWC I also get checksum error
              If everything is working as expected you should not get any checksum errors at all. If you get them more than once something is still wrong.
              Have you made sure that both the Duet 2 and the Raspberry Pi share a common ground connection?
              Manuel
              My Tool Collection
              • smoki3undefined
                smoki3 @A Former User
                @bearer said in Duet 2 Ethernet and SBC:
                8000000
                This doesn't help
                • smoki3undefined
                  smoki3 @wilriker
                  Yes both are connected directly to ground
                  • smoki3undefined
                    smoki3
                    I tried now different cables, direct wiring without PCB and 470ohm resistors.
                    But always the same issue.
                    Also tried now without resistors, same issue
                      A Former User @T3P3Tony
                      @T3P3Tony said in Duet 2 Ethernet and SBC:
                      We are considering a small hardware board to provide the physical interfacing and signal buffering.
                      if the series resistance is deemed all that is needed, then a few crimps and a printed part goes a long way:
                      Btw, is there a part# for the nylon stand offs? gonna try a pogo-pin version for the Wifi
                      • gtj0undefined
                        gtj0
                        Jeez. I take some time off and this happens. 🙂
                        • smoki3undefined
                          smoki3
                          @wilriker
                          Today I am back from holidays. I tried to investigate a bit more but it does not help. I disassembled the Duet 2 Ethernet from my printer so I have no other cables in the near of the board. I also made a new cable out of a shielded ethernet cable to avoid any EMC troubles. But still the same. If I try to flash the firmware for example I get many checksum errors.
                          @bearer
                          are you now able to flash the firmware over DWC? I always get checksum error.
                            with both the Wifi and Ethernet (Duets) yes
                            • smoki3undefined
                              @bearer so I mean with the SBC connected
                              Which raspberry do you use?
                                A Former User
                                yes yes, update wifi and ethernet boards with RRF3.2 over SPI from the SBC, Once I shortened the wires and had my novice crimp the resistors instead of trying to solder its all good at 8Mhz.
                                edit: one 4B 4GB, 3B+ and some 2B tested.
                                • smoki3undefined
                                  @bearer How short are your cables?
                                    A Former User
                                    I'd say the first was about 40cm with questionable soldering, No Bueno... after revisiting it with crimps I'd say 20cm/26AWG(maybe it was 28?) and 15cm/30AWG loose wires, not in a ribbon. 470R resistor crimped in somewhere along the MISO, MOSI and SCK lines.
                                    • smoki3undefined
                                      @bearer
                                      wired.... I don't understand why it is not working for me. My cables are less than 10cm, tried different resistors from 100 Ohm up to 500 Ohm. I soldered but this should normally better than just crimping. Also tried loose wires.
                                        A Former User
                                        It would surprise me if it was a signal integrity issue if it works for other operations than flashing, but at this point I'd get the scope out and take a look.
                                        • smoki3undefined
                                          @bearer no other things also doesnt work. Get checksum errors while homing for example
                                            A Former User
                                            Oh, I read the previous posts as if homing worked.
                                            Can you run simple commands like M115 and M122?
