    Duet 2 Ethernet and SBC
    Beta Firmware
    29
    302
    34.4k
      A Former User @wilriker
      @wilriker said in Duet 2 Ethernet and SBC:
      IAP is fixed now also on master branch.
      btw i think there was a slight hickup with it refusing M997 S0 - but can't reproduce it after it did update with both DWC asking to update and M997 without S0.
      • wilrikerundefined
        wilriker @A Former User
        @bearer Since there is only one type of firmware to update it is unnecessary to provide a Snnn parameter to M997 in the first place but I agree that it should not result in either a warning or worse an error. If you can reproduce it, please post here.
        Manuel
        My Tool Collection
        • wilrikerundefined
          wilriker @smoki3
          @smoki3 said in Duet 2 Ethernet and SBC:
          If I try to flash the firmware over DWC I also get checksum error
          If everything is working as expected you should not get any checksum errors at all. If you get them more than once something is still wrong.
          Have you made sure that both the Duet 2 and the Raspberry Pi share a common ground connection?
          Manuel
          My Tool Collection
          smoki3undefined 1 Reply Last reply Reply Quote 0
          • smoki3undefined
            smoki3 @A Former User
            @bearer said in Duet 2 Ethernet and SBC:
            8000000
            This doesn't help
            • smoki3undefined
              smoki3 @wilriker
              Yes both are connected directly to ground
              • smoki3undefined
                smoki3
                I tried now different cables, direct wiring without PCB and 470ohm resistors.
                But always the same issue.
                Also tried now without resistors, same issue
                  A Former User @T3P3Tony
                  @T3P3Tony said in Duet 2 Ethernet and SBC:
                  We are considering a small hardware board to provide the physical interfacing and signal buffering.
                  if the series resistance is deemed all that is needed, then a few crimps and a printed part goes a long way:
                  Btw, is there a part# for the nylon stand offs? gonna try a pogo-pin version for the Wifi
                  • gtj0undefined
                    gtj0
                    Jeez. I take some time off and this happens. 🙂
                    • smoki3undefined
                      smoki3
                      @wilriker
                      Today I am back from holidays. I tried to investigate a bit more but it does not help. I disassembled the Duet 2 Ethernet from my printer so I have no other cables in the near of the board. I also made a new cable out of a shielded ethernet cable to avoid any EMC troubles. But still the same. If I try to flash the firmware for example I get many checksum errors.
                      @bearer
                      are you now able to flash the firmware over DWC? I always get checksum error.
                        A Former User @smoki3
                        with both the Wifi and Ethernet (Duets) yes
                        • smoki3undefined
                          @bearer so I mean with the SBC connected
                          Which raspberry do you use?
                            A Former User
                            yes yes, update wifi and ethernet boards with RRF3.2 over SPI from the SBC, Once I shortened the wires and had my novice crimp the resistors instead of trying to solder its all good at 8Mhz.
                            edit: one 4B 4GB, 3B+ and some 2B tested.
                            • smoki3undefined
                              @bearer How short are your cables?
                                A Former User
                                I'd say the first was about 40cm with questionable soldering, No Bueno... after revisiting it with crimps I'd say 20cm/26AWG(maybe it was 28?) and 15cm/30AWG loose wires, not in a ribbon. 470R resistor crimped in somewhere along the MISO, MOSI and SCK lines.
                                • smoki3undefined
                                  @bearer
                                  wired.... I don't understand why it is not working for me. My cables are less than 10cm, tried different resistors from 100 Ohm up to 500 Ohm. I soldered but this should normally better than just crimping. Also tried loose wires.
                                    A Former User
                                    It would surprise me if it was a signal integrity issue if it works for other operations than flashing, but at this point I'd get the scope out and take a look.
                                    • smoki3undefined
                                      @bearer no other things also doesnt work. Get checksum errors while homing for example
                                        A Former User
                                        Oh, I read the previous posts as if homing worked.
                                        Can you run simple commands like M115 and M122?
                                        • smoki3undefined
                                          @bearer
                                          So now I came a step closer. I disconnected the Duet2 from the VIN (24V Meanwell Power Supply) and power it over the USB Port from the raspberry pi. Now I can flash the firmware without any checksum issue.
                                          @wilriker does this help?
                                            What SPI speed have you configured in DSF?
