    Duet 2 Ethernet and SBC
    Beta Firmware
    29
    302
    34.6k
      A Former User @smoki3
      @smoki3 said in Duet 2 Ethernet and SBC:
      are you now able to flash the firmware over DWC?
      with both the Wifi and Ethernet (Duets) yes
      smoki3undefined 1 Reply Last reply Reply Quote 0
      • smoki3undefined
        smoki3 @A Former User
        @bearer so I mean with the SBC connected
        Which raspberry do you use?
          A Former User
          yes yes, update wifi and ethernet boards with RRF3.2 over SPI from the SBC, Once I shortened the wires and had my novice crimp the resistors instead of trying to solder its all good at 8Mhz.
          edit: one 4B 4GB, 3B+ and some 2B tested.
          • smoki3undefined
            @bearer How short are your cables?
              A Former User
              I'd say the first was about 40cm with questionable soldering, No Bueno... after revisiting it with crimps I'd say 20cm/26AWG(maybe it was 28?) and 15cm/30AWG loose wires, not in a ribbon. 470R resistor crimped in somewhere along the MISO, MOSI and SCK lines.
              • smoki3undefined
                @bearer
                wired.... I don't understand why it is not working for me. My cables are less than 10cm, tried different resistors from 100 Ohm up to 500 Ohm. I soldered but this should normally better than just crimping. Also tried loose wires.
                  A Former User
                  It would surprise me if it was a signal integrity issue if it works for other operations than flashing, but at this point I'd get the scope out and take a look.
                  • smoki3undefined
                    @bearer no other things also doesnt work. Get checksum errors while homing for example
                      A Former User
                      Oh, I read the previous posts as if homing worked.
                      Can you run simple commands like M115 and M122?
                      • smoki3undefined
                        @bearer
                        So now I came a step closer. I disconnected the Duet2 from the VIN (24V Meanwell Power Supply) and power it over the USB Port from the raspberry pi. Now I can flash the firmware without any checksum issue.
                        @wilriker does this help?
                          What SPI speed have you configured in DSF?
                          • smoki3undefined
                            smoki3 @dc42
                            @dc42 the standard config 8 MHz
                            • wilrikerundefined
                              wilriker @smoki3
                              @smoki3 Please try lowering it incrementally by dividing by two, i.e. try 4MHz, then 2MHz and so on until you either get to somewhere around 100kHz or find a working speed
                              I will try to reproduce your setup next week. Just to be sure: did you power the RPi from a buck-converter off of the Duet or did you power it separately?
                              Also if you only tried one of these options so far please try the other.
                              I also use loose wires of around 150mm length with Dupont crimps on the ends and several JST connector pairs in between to insert/remove resistors.
                              Manuel
                              My Tool Collection
                              • smoki3undefined
                                smoki3 @wilriker
                                @wilriker I tried a buck converter and a USB power supply - results in the same behavior.
                                As soon I disconnect the power from the duet and just plug in a USB cable it works with out any issues.
                                Lowering the speed doesn't help. Tried it down to 1MHz.
                                Actually I also use Dupont connectors with a cable length about 8cm.
                                • smoki3undefined
                                  smoki3
                                  I now tried to lower the speed down toi 100kHz. But this also doesn't help.
                                  Its really as I said, as soon I plug in VIN to the Duet the SPI Bus is broken
                                  • smoki3undefined
                                    smoki3
                                    Is there a reason why on my duet2 ethernet capacity C99 is not equipped? Is a capacity in the 5V buck converter.
                                    I looked at the schematic normally there should be a 250uF capacity. Could this be a reason?
                                      A Former User
                                      which revision is the board?
                                      • wilrikerundefined
                                        wilriker @smoki3
                                        @smoki3 On my 1.03 board C99 is populated. My meter refused to measure the capacitance but it's certainly higher than "none". 😁
                                        @T3P3Tony might answer this question better if that would pose a problem (I'm primarily a software guy 😂 ).
                                        Manuel
                                        My Tool Collection
                                        • smoki3undefined
                                          @bearer Its a 1.04c
                                          A Former User? 2 Replies Last reply Reply Quote 0
                                            1.04c
                                            iirc its normal then, it was fitted to 1.04, 1.04a and 1.04b but not 1.04c.
                                            also given the cpu and wifi runs off 3.3v with its own smoothing cap i'm not sure it matters, but I can try it next week if I manage to throw together a printed part with pogo pins for the wifi (edit: printed part is modelled for P50 + R50 pins, may need to drill out holes)
