    Duet 2 or 3 for Corexy
    29
    2.0k
    • MartinNYHCundefined
      MartinNYHC
      Just to make sure that I understand the documentation: when using a Duet 3 with RPI the DWC is running on the RPI? This means, that I can use any Touchscreen supported by the RPI?
      Thanks, Martin
        A Former User @MartinNYHC
        @MartinNYHC correct; I quite like the Raspberry Pi official screen due to its flat flex cable that I found easier to hide than a normal hdmi one, but its not the biggest or highest resolution screen available.
        side note; you could use any touch screen on any pi to access DWC over the network regardless of where DWC was running. but it is correct that it runs on the Pi and as such will work even without networking.
        • nrivieraundefined
          nriviera
          I have a BLV and after my Duet2 died am in the process of changing to a 3.
          My suggestion is if you're not going to do a tool changer or triple-z axis then go with the 2 as the documentation is a bit easier to understand and you don't need the more powerful steppers. The other advantages are is you can get the SD card on the panelDue (and weirdly for me worked better with a long cable than the 4 pin connection). The Pi currently doesn't really give you much advantage over DWC but just boots slower. If you are considering a tool changer or multiple extruder it still works just as well provided you don't go direct drive for your heads.
          On the other hand the 3 makes connecting a direct drive tool changer much easier to wire and swap out, the Pi can use high quality screens and is a touch faster with uploads once booted.
            MartinNYHC
            @nriviera said in Duet 2 or 3 for Corexy:
            Can you please explain?
            Thanks, Martin
            nrivieraundefined 1 Reply Last reply Reply Quote 0
            • Argoundefined
              Argo
              If I were you Iā€˜d wait for the new Duet board.
              The Duet 3 is imo too much even for a CoreXY.
              Duet 2 would be enough but has outdated stepper drivers.
                A Former User
                "Outdated" is a bit relative isn't it? And if you're always waiting for the next best thing it'll be awhile. Having said that I'd be nice to see a rough timeline for the other news; all we know is the 5LC Maestro-ish Duet3 is a few months away.
                Argoundefined 1 Reply Last reply Reply Quote 0
                • Argoundefined
                  Argo @A Former User
                  @bearer
                  In terms of requirements for home 3D printers I'd say the Duet 2 is outdated for a while now.
                  The TMC2209 are the "go to" stepper drivers at the moment for home 3D printers. I'd rather have features like Stealthchop than stepper drivers which can handle 2.6 amps.
                  I was about to buy (import) a Kinetica G2C board which is a RepRap capable board that comes with TMC2209 but I rather wait now for the next Duet release šŸ™‚
                  • nrivieraundefined
                    nriviera @MartinNYHC
                    @MartinNYHC the duet2 uses 2660 vs 5160 on the duet3. The Duet2 can use currents up to 2.8A vs the 4.5a on the 3. Most NEMA 17 steppers are fine but if you wanted to use 23s or have several large ones on the same stepper it might be an issue.
                      A Former User
                      @MartinNYHC
                      fyi https://forum.duet3d.com/topic/17409/duet-3-mini-5-initial-announcement
                        MartinNYHC
                        Thanks for pointing out, but I bought a Duet 3 6HC today šŸ˜‰
                        Now I need to wait for the ordered frame parts. Did I mention that I hate waiting at all? šŸ˜‹
                          @MartinNYHC oh well; at least you wait knowing the board will not be a limiting factor any time soon ^^
                          Waiting was torture even before covid and lockdowns; hang in there!
                          • mrenz999undefined
                            mrenz999 @MartinNYHC
                            @MartinNYHC Take a look at this kit.
                            https://www.alibaba.com/product-detail/GIULY-All-Metal-BLV-mgn-Cube_62451669742.html?spm=a2700.icbuShop.81298.1.77a7737ch3D3qc
