    web died after successful print
    1.2k
    • arhiundefined
      arhi @JoergS5
      @JoergS5 said in web died after successful print:
      One possibility is to set a higher debug level for analyzing, but I have not done it yet, so I cannot help how to do it in detail. One can set debug levels for specific modules.
      It's not a problem to add additional debug levels but the problem is that I can't reproduce this easily. last two times it happened I added debug + usb but could not reproduce the problem.
      JoergS5undefined 2 Replies Last reply Reply Quote 0
      • JoergS5undefined
        JoergS5 @arhi
        @arhi you could try a keep alive program (etc....)
        (wrong thought Maybe the httpsessions were full (8 of 8 used) removed)
        • JoergS5undefined
          JoergS5 @arhi
          @arhi what is interesting is that the data cache hit count. Cache data hit count 4294967295 is exactly 32 bit unsigned, maybe reached an upper limit.
          • arhiundefined
            arhi @JoergS5
            @arhi you could try a keep alive program to check whether it is a disconnect problem after long inactivity.
            It is not. The long inactivity was before the print, web opened ok and during the print there was activity and it stopped working immediately after the print finished. So no "timeout" to speak of.
            You could check M122 before crash, maybe the httpsessions were full (8 of 8 used).
            If I can reproduce the problem on demand it would make sense but I can't. All three times it happened the printer was not in use for 3-4 days.
            Where do you see 8 out of 8 ?!?!
            HTTP sessions: 0 of 8
            Do you use additional programs to access the Duet, like monitoring programs, which may use connections?
            No program other than web accessed duet in the times the problem happened (normally I do but the rpi4 that host those programs is of-line these days so, no)
            JoergS5undefined botundefined 2 Replies Last reply Reply Quote 0
            • JoergS5undefined
              JoergS5 @arhi
              @arhi said in web died after successful print:
              Please ignore, this was wrong.
              One thing to check is wipe.g
              • botundefined
                bot @arhi
                No program other than web accessed duet in the times the problem happened [...]
                This got me thinking. What if there is some ping or other mechanism sent to the Duet automatically by some system on your network.
                I wonder if mDNS is playing a role. It was disabled on legacy Duets for similar reason.
                From the RRF2 Whats_new doc:
                • Disabled mdns in legacy Duets because of code quality issues causing reboots, https://forum.duet3d.com/topic/8352/duet-0-6-randomly-reboots/5
                *not actually a robot
                • arhiundefined
                  arhi @JoergS5
                  @JoergS5 the wipe has nothing to do with it but here it is
                  if !move.axes[0].homed || !move.axes[1].homed
                    echo "X and Y axes not homed, aborting the wipe"
                    M99
                  if state.currentTool < 0
                    echo "No tool loaded, aborting the wipe"
                    M99
                  if heat.heaters[tools[state.currentTool].heaters[0]].current < 200
                    echo "Extruder too cold, no point wiping, aborting the wipe"
                    M99
                  ; Drop all motor currents down
                  M400
                  M913 X30 Y30 Z25
                  M83
                  ; -135,       -116,             115,   125,
                  ;     ,104....++++++++++++++++++++++....
                  ;     ,63 ..|.++++++++++++++++++++++....
                  ;     ,30 ..|.++++++++++++++++++++++....
                  ;    ,-112....++++++++++++++++++++++....
                  ;    ,-121..............................
                  G0 X-115 Y65  F9000
                  while true
                    G0 X-135 Y{65 - iterations * 3} F7000
                    G0 X-115 Y{65 - iterations * 4} F5000
                    if iterations == 6
                      G1 E-3 F3000
                    if iterations == 8
                      break
                  M98 P"park.g"
                  ; Return all motor currents to 100%
                  M400
                  M913 X100 Y100 Z100
                  and the park is
                  ; drop motor curents
                  M913 X30 Y30 Z25
                  ; go to park position
                  G0 X-135 Y40
                  ; restore motor curents
                  M913 X100 Y100 Z100
                  as I said, the code itself works ok.. and after everything is finished paneldue and usb work ok, just web is dead
                  • arhiundefined
                    arhi @bot
                    @bot said in web died after successful print:
                    But web itself is pinging it non stop (fetching the model json, displaying temperature etc etc)
                    dunno, I don't use mDNS as I had issues with it on windows so my router is configured to add entry to local dns to .local.lan or .local.wifi for all dhcp leases so I use ender5.local.lan to access it so local dns, not using mdns at all
                    yeah but no reboot here, the duet runs ok, this time the web died after the print but usb/paneldue worked ok, last time web died in the middle of the print but print finished ok, paneldue was ok, I just could not connect using web.... I was running later on with debug on for few modules but could not reproduce the problem, today it happened again, the only similarity, the printer was idle for few days (not printing, but I did access it via web to check in some config details etc.. and basically the tab with dwc was open most of the time)
                    • JoergS5undefined
                      JoergS5 @arhi
                      @arhi Error 10 Could be that you have a recursion somewhere.
                      Error 10 is an addition of 0x02 and 0x08 according to
                      https://duet3d.dozuki.com/Wiki/Error_codes_and_software_reset_codes
                      • arhiundefined
                        arhi @JoergS5
                        @arhi Could be that you have a recursion somewhere
                        In that case, it would die much faster; but no, no recursion here. I do call same file from multiple places but never recursive
                        • JoergS5undefined
                          JoergS5 @arhi
                          (deleted, not relevant)
                          • arhiundefined
                            arhi @JoergS5
                            @arhi but some overflow is the reset reason of your last reset. Maybe the cash overflow above, or another overflow. For overflow reasons, I only found the recursion as a cause, but maybe you're first for your overflow reason.
                            Well, the board did not reset! As I wrote, only the HTTP module or NET module died (did not restart, stayed dead), everything else continued to work ok as nothing happens, continued printing, parsing g-code...
                            • JoergS5undefined
                              JoergS5 @arhi
                              @arhi The M122 reset reason is the reason of the reset 131 hours ago. The error 10 could be related to this access error.
                              • arhiundefined
                                arhi @JoergS5
                                @JoergS5 yup, that M122 happened before the ~130 hours of inactivity
                                • JoergS5undefined
                                  JoergS5 @arhi
                                  This post is deleted!
                                  • arhiundefined
                                    arhi
                                    here it comes again, ~12 hours of inactivity, dead 5 minutes after the print finished ?!?!
                                    • JoergS5undefined
                                      JoergS5 @arhi
                                      @arhi what is the M122 please?
                                      • arhiundefined
                                        arhi @JoergS5
                                        @JoergS5 I didn't do M122 I just rebooted it, turned on debugging on net, web and few others turned on logging on serial port and let it run so it catches log if it happens again as even dc42 did not find anything useful in the m122 last time so .. collecting debug data now
                                        • JoergS5undefined
                                          JoergS5 @arhi
                                          @arhi ok, hope you find something. Good luck!
                                          • arhiundefined
                                            arhi @JoergS5
                                            😄 I'm not turning the darn debug off till the darn thing dies again so we'll see ..
