Duet 2 Wifi to Duet 3 --> config and some general questions
I Ordered right now a Duet3, as my MGN Cube (CoreXy) with Moon motors is really noise... (Duet Wifi is a Clone)
And i hope that the Duet3 will solve this!How "easy" i can take my actual config?
Anything i have to take care?
I did not found any "upgrade" document.One other question:
Raspberry Pi or not?
I want to use the PanelDue 4,3 from my actual setup. I read already about the "file limitation" in combination with a Pi.
I guess that Wifi would be included in the "Pi".
But which advantage I would get in parallel??Shortly summarized the setup:
CoreXY
BLTouch
PanelDue
NeoPixel over Arduino Sniffer
1x HotendThank you!
@empi00 I’m also in the process of changing my mgn cube over to a duet 3. I am still working on some mechanical upgrades, but once I get those finished I’m happy to compare notes with you on the firmware setup!
@empi00 said in Duet 2 Wifi to Duet 3 --> config and some general questions:
<..snip..>
But which advantage I would get in parallel??Easier to expand the functionality of the software, if you don't need that you won't have much advantage with the Pi as it currently stands.
@bearer my duet wifi is running already on RepRap 3.
So my question was more, moving from a Duet Wifi FW3 to a Duet 3.Have some extrusion problems etc, but that is a different topic and will end up maybe in a seperate thread, if I can not solve it.
gotcha, then just the pin names, the Duet3 are all generic like out0 etc. so e0heat becomes out1 etc.
ref https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_Pin_names has a list for all the boards to compare.
The stepper drivers are still named 0...5 so if you wire them according to their old numbers then no change to the config - except you can add stealth chop settings.
