    Macro not sent from PanelDue (but works ok from Web interface)
    PanelDue
    • FelixHundefined
      FelixH
      Hi all,
      For quite some time I have been having some problems with my Workbee CNC machine in which one macro does not work. The macro is a very simple command that moves the tool to the WCS #1 origin (only on the X and Y) axis:
      G28 Z
      G54 G1 X0 Y0 F1500
      I control my machine via the PanelDue Display and I use the Web Interface only to upload Gcodes and other housekeeping stuff. For some estrange reason, the macro would not work. I had to restart the Duet and then I could send the command. Today however I noticed that if I execute the macro from the web interface, it works just fine and as expected. No problem whatsoever.
      On my machine I have a CNC pendant like the ones developed here:
      https://forum.duet3d.com/topic/11389/cnc-style-pendant
      I don't know if it has something to do with it, but I felt it was important to mention.
      Sending the equivalent Gcode from the PanelDue's terminal also doesn't work.
      Running Ooznest's modified Firmware (I think it's only interface??).
      I have many other Macros (https://github.com/FelixHauser/macros-Workbee) but all the others work as expected (setting WCS mostly, turning Router ON and OFF, etc.)
      Any help is appreciated and welcome !
        Interesting. Firmware versions? Duet board? PanelDue version?
        FelixHundefined 1 Reply Last reply Reply Quote 0
        • FelixHundefined
          FelixH @Phaedrux
          @Phaedrux oh yeah... sorry
          • Firmware should be 2.something. It is Ooznest 1.07 (https://learn.ooznest.co.uk/Wiki/WorkBee_Firmware_Releases)
          • Duet 2 Wifi
          • PanelDue Firmware is 1.23, I believe
          • FelixHundefined
            FelixH
            well, I just made a short test in which I unplugged the Pendant and plugged the PanelDue as usual. The Macro in this configuration works just fine. So, apparently, it is a problem with the Pendant. I will post the problem over the Pendant post.
            • FelixHundefined
              FelixH
              well, if anyone is following this thread, I just want to mention that it has been solved.
              The issue was the name of the macro together with the firmware version of the Paneldue. I changed the name of the macro to be just text and it worked fine. And just for the sake of it, I updated the firmware to the latest version. Everything works just fine now.
