Ender 5 Duet Wifi 2 and BLTouch 3.1
785
    TheBiologist @DIY-O-Sphere
    @DIY-O-Sphere ok I have now successfully updated to 3.1.1. I am still not getting the bltouch to work. It still will not self test on power up. It drops the pin and then starts blinking red light. I have checked the wires and all connections are good. This is a legit BLTouch with their wiring.
    undefined 1 Reply Last reply 7 Jul 2020, 02:20 Reply Quote 0
      TheBiologist
      @TheBiologist said in Ender 5 Duet Wifi 2 and BLTouch 3.1:
      M98 P"config.g"
      M98 P"config.g"
      HTTP is enabled on port 80
      FTP is disabled
      TELNET is disabled
      Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C
      Error: Pin 'fan1' is not free
      Error: Fan number 2 not found
      m115
      FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.1.1 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2020-05-19b2
      undefined 1 Reply Last reply 7 Jul 2020, 02:23 Reply Quote 0
        TheBiologist
        Fixed the fan error. Not sure what to do with the heater error or that the z probe is reading 1000 like it is being triggered.
        undefined 1 Reply Last reply 7 Jul 2020, 02:24 Reply Quote 0
          Phaedrux Moderator @TheBiologist
          What happens if you connect only 5v and ground? That should cause it to self test. If it's still failing on self test check the pin. You can remove the grub screw on the top of the body and remove the pin. Maybe it's bent or dirty.
          If it's still failing self test try and send the error reset command and then try and deploy and retract again.
          What do you have in your config.g and deploy and retract now?
          undefined 1 Reply Last reply 7 Jul 2020, 03:39 Reply Quote 0
            This is just telling you what it thinks your bed temp could reach if it fails on. To get rid of the warning choose a lower powered heater. Otherwise, just be aware. Don't leave it unattended. Have a fire extinguisher handy. Smoke alarm. Thermal cut out fuse.
            undefined 1 Reply Last reply 7 Jul 2020, 03:40 Reply Quote 0
              Did you change your ! to a ^ in the M558 as pointed out by @DIY-O-Sphere ?
              If you did change that and it's still showing 1000 all the time, that could mean the probe is damaged, or there is a problem with your white signal wire.
              undefined 1 Reply Last reply 7 Jul 2020, 05:13 Reply Quote 0
                TheBiologist @Phaedrux
                @Phaedrux The probe cycles twice and then starts blinking red.
                ; generated by RepRapFirmware Configuration Tool v3.1.3 on Mon Jul 06 2020 13:33:30 GMT-0500 (Central Daylight Time)
                M550 P"Ender 5" ; set printer name
                M552 S1 ; enable network
                M586 P0 S1 ; enable HTTP
                M586 P1 S0 ; disable FTP
                M586 P2 S0 ; disable Telnet
                M569 P2 S0 ; physical drive 2 goes backwards
                M350 X16 Y16 Z16 E16 I0 ; configure microstepping without interpolation
                M92 X80.00 Y80.00 Z400.00 E96.15 ; set steps per mm
                M566 X600.00 Y600.00 Z60.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
                M203 X30000.00 Y30000.00 Z600.00 E600.00 ; set maximum speeds (mm/min)
                M201 X500.00 Y500.00 Z200.00 E4000.00 ; set accelerations (mm/s^2)
                M906 X850 Y800 Z700 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
                M84 S30 ; Set idle timeout
                M208 X220 Y220 Z300 S0 ; set axis maxima
                M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
                M558 P9 C"^zprobe.in" H5 F0 T6000 ; set Z probe type to bltouch and the dive height + speeds
                G31 P0 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
                M557 X15:195 Y15:195 S20 ; define mesh grid
                M106 P0 S1 H0 T45 ; set fan 0 value. Thermostatic control is turned on
                M106 P1 S1 H0 T45 ; set fan 1 value. Thermostatic control is turned on
                M950 F2 C"fan2" Q500 ; create fan 2 on pin fan1 and set its frequency
                M106 P2 S0.3 H-1 ; set fan 2 value. Thermostatic control is turned off
                Deploy and retract
                M280 P0 S10 ; deploy BLTouch
                M280 P0 S90 ; retract BLTouch
                  @Phaedrux it is just the factory ender 5 bed heater. Is that normal?
                  undefined 1 Reply Last reply 7 Jul 2020, 04:02 Reply Quote 0
                    Don't set it to P0. That meas triggered at not triggered. Use G31 P25
                    You need a feed rate set too. Use F60.
                    undefined 1 Reply Last reply 7 Jul 2020, 15:15 Reply Quote 0
                      yeah it's not uncommon to see the warning. It's a motorized hot plate with wifi afterall.
                        @Phaedrux Thanks for the help! SO far so good. I will try leveling the bed tomorrow.
                          @Phaedrux So turned on the printer first thing this morning to try and calibrate the bltouch and went right back to the same issues. I am begining to suspect bad wire in the cable so I have ordered another. Not sure what else it could be. It was working just fine last night. Tested it unmounted, turned it off and mounted it, and then turned it back on this morning.
                          19 out of 21
