    Ender 5 Duet Wifi 2 and BLTouch 3.1
    785
      @TheBiologist said in Ender 5 Duet Wifi 2 and BLTouch 3.1:
      M950 S0 C"duex.pwm1" ; create servo pin 0 for BLTouch
      M558 P9 C"!zprobe.in+zprobe.mod" H5 F0 T6000 ; set Z probe type to bltouch and the dive height + speeds
      How do you have the BLtouch connected? Do you have a duex?
      Depending on where you have the servo control wire connected, you may need to change the pin name used by M950. I think there is a bug in the configurator that is showing the wrong pin choices for the PWM servo control.
      If you're connected to expansion header 3 like shown in the connecting a bltouch doc it should be like this:
      M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
      M558 P9 C"!zprobe.in" H5 F0 T6000 ; set Z probe type to bltouch and the dive height + speeds
      DIY-O-Sphereundefined TheBiologistundefined 2 Replies Last reply Reply Quote 0
      • DIY-O-Sphereundefined
        DIY-O-Sphere @Phaedrux
        @Phaedrux said in Ender 5 Duet Wifi 2 and BLTouch 3.1:
        M558 P9 C"^zprobe.in" H5 F0 T6000
        (UTC+1)
          Phaedrux Moderator @DIY-O-Sphere
          @DIY-O-Sphere Good eye!
          • TheBiologistundefined
            TheBiologist
            Awesome I will try that. Thanks for the quick reply
              TheBiologist @Phaedrux
              @Phaedrux yes I have it wired like in the photo. I made the suggested changes but bltouch still does not power cycle instead is flashing red at a slow steady rate. When I tried to rest the bltouch i get Error: M280: Invalid servo index 0 in M280 command.
                Please send M115 to verify what firmware version you are actually using.
                Then send M98 P"config.g" in the console and report the results.
                TheBiologistundefined 1 Reply Last reply Reply Quote 0
                  @Phaedrux
                  m115
                  FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.02(RTOS) ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2018-12-24b1
                  M98 P"config.g"
                  HTTP is enabled on port 80
                  FTP is disabled
                  TELNET is disabled
                  Warning: M950 command is not supported
                  Warning: M308 command is not supported
                  DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
                    DIY-O-Sphere @TheBiologist
                    Your config is for RRF3, but your firmware is RRF2
                    You have to update the firmware.
                    First to 3.0 after that go to 3.1.1
                    (UTC+1)
                      TheBiologist @DIY-O-Sphere
                      @DIY-O-Sphere ok I have now successfully updated to 3.1.1. I am still not getting the bltouch to work. It still will not self test on power up. It drops the pin and then starts blinking red light. I have checked the wires and all connections are good. This is a legit BLTouch with their wiring.
                        TheBiologist
                        M98 P"config.g"
                        M98 P"config.g"
                        FTP is disabled
                        TELNET is disabled
                        Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C
                        Error: Pin 'fan1' is not free
                        Error: Fan number 2 not found
                        m115
                        FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.1.1 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2020-05-19b2
                          TheBiologist
                          Fixed the fan error. Not sure what to do with the heater error or that the z probe is reading 1000 like it is being triggered.
                            Phaedrux Moderator @TheBiologist
                            What happens if you connect only 5v and ground? That should cause it to self test. If it's still failing on self test check the pin. You can remove the grub screw on the top of the body and remove the pin. Maybe it's bent or dirty.
                            If it's still failing self test try and send the error reset command and then try and deploy and retract again.
                            What do you have in your config.g and deploy and retract now?
                              This is just telling you what it thinks your bed temp could reach if it fails on. To get rid of the warning choose a lower powered heater. Otherwise, just be aware. Don't leave it unattended. Have a fire extinguisher handy. Smoke alarm. Thermal cut out fuse.
                                Did you change your ! to a ^ in the M558 as pointed out by @DIY-O-Sphere ?
                                If you did change that and it's still showing 1000 all the time, that could mean the probe is damaged, or there is a problem with your white signal wire.
                                  @Phaedrux The probe cycles twice and then starts blinking red.
                                  ; generated by RepRapFirmware Configuration Tool v3.1.3 on Mon Jul 06 2020 13:33:30 GMT-0500 (Central Daylight Time)
                                  M550 P"Ender 5" ; set printer name
                                  M552 S1 ; enable network
                                  M586 P0 S1 ; enable HTTP
                                  M586 P1 S0 ; disable FTP
                                  M586 P2 S0 ; disable Telnet
                                  M569 P2 S0 ; physical drive 2 goes backwards
                                  M350 X16 Y16 Z16 E16 I0 ; configure microstepping without interpolation
                                  M92 X80.00 Y80.00 Z400.00 E96.15 ; set steps per mm
                                  M566 X600.00 Y600.00 Z60.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
                                  M203 X30000.00 Y30000.00 Z600.00 E600.00 ; set maximum speeds (mm/min)
                                  M201 X500.00 Y500.00 Z200.00 E4000.00 ; set accelerations (mm/s^2)
                                  M906 X850 Y800 Z700 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
                                  M84 S30 ; Set idle timeout
                                  M208 X220 Y220 Z300 S0 ; set axis maxima
                                  M558 P9 C"^zprobe.in" H5 F0 T6000 ; set Z probe type to bltouch and the dive height + speeds
                                  G31 P0 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
                                  M557 X15:195 Y15:195 S20 ; define mesh grid
                                  M106 P0 S1 H0 T45 ; set fan 0 value. Thermostatic control is turned on
                                  M106 P1 S1 H0 T45 ; set fan 1 value. Thermostatic control is turned on
                                  M950 F2 C"fan2" Q500 ; create fan 2 on pin fan1 and set its frequency
                                  M106 P2 S0.3 H-1 ; set fan 2 value. Thermostatic control is turned off
                                  Deploy and retract
                                  M280 P0 S10 ; deploy BLTouch
                                  M280 P0 S90 ; retract BLTouch
                                    @Phaedrux it is just the factory ender 5 bed heater. Is that normal?
                                      Don't set it to P0. That meas triggered at not triggered. Use G31 P25
                                      You need a feed rate set too. Use F60.
                                        yeah it's not uncommon to see the warning. It's a motorized hot plate with wifi afterall.
                                          @Phaedrux Thanks for the help! SO far so good. I will try leveling the bed tomorrow.
                                            @Phaedrux So turned on the printer first thing this morning to try and calibrate the bltouch and went right back to the same issues. I am begining to suspect bad wire in the cable so I have ordered another. Not sure what else it could be. It was working just fine last night. Tested it unmounted, turned it off and mounted it, and then turned it back on this morning.
