    RRF Config Mapping
    1.9k
    • printthatthingundefined
      printthatthing
      Thank you all again. I think I have it running now.
      I had to keep ! for duex.pwm5 else it does not probe.
      config.g
      ; generated by RepRapFirmware Configuration Tool v3.1.3 on Wed Jul 08 2020 21:18:31 GMT+0200 (centraleuropeisk sommartid)
      G90                                            ; send absolute coordinates...
      M83                                            ; ...but relative extruder moves
      M550 P"Formbot Raptor 2"                       ; set printer name
      M552 S1                                        ; enable network
      M586 P0 S1                                     ; enable HTTP
      M586 P1 S0                                     ; disable FTP
      M586 P2 S0                                     ; disable Telnet
      M569 P0 S1                                     ; physical drive 0 goes forwards
      M569 P1 S1                                     ; physical drive 1 goes forwards
      M569 P2 S1                                     ; physical drive 2 goes forwards
      M569 P3 S1                                     ; physical drive 3 goes forwards
      M584 X0 Y1 Z2 E3                               ; set drive mapping
      M350 X16 Y16 Z16 E16 I1                        ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z640.00 E415.00              ; set steps per mm
      M566 X900.00 Y900.00 Z12.00 E120.00            ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E1200.00        ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z20.00 E250.00            ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E800 I30                   ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                        ; Set idle timeout
      M208 X0 Y0 Z0 S1                               ; set axis minima
      M208 X400 Y400 Z350 S0                         ; set axis maxima
      M574 X1 S1 P"!xstop"                           ; configure active-high endstop for low end on X via pin !xstop
      M574 Y1 S1 P"!ystop"                           ; configure active-high endstop for low end on Y via pin !ystop
      M574 Z1 S2                                     ; configure Z-probe endstop for low end on Z
      M950 S0 C"!duex.pwm5"                           ; create servo pin 0 for BLTouch
      M558 P9 C"^zprobe.in" H5 F120 T6000            ; set Z probe type to bltouch and the dive height + speeds
      G31 P25 X-25 Y-5 Z0.489                          ; set Z probe trigger value, offset and trigger height
      M557 X5:380 Y5:380 S20                       ; define mesh grid
      M950 H0 C"bedheat" T0                          ; create bed heater output on bedheat and map it to sensor 0
      M307 H0 B1 S1.00                               ; enable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                        ; map heated bed to heater 0
      M143 H0 S120                                   ; set temperature limit for heater 0 to 120C
      M308 S1 P"e0temp" Y"thermistor" T100000 B4138  ; configure sensor 1 as thermistor on pin e0temp
      M950 H1 C"e0heat" T1                           ; create nozzle heater output on e0heat and map it to sensor 1
      M307 H1 B0 S1.00                               ; disable bang-bang mode for heater  and set PWM limit
      M950 F0 C"fan0" Q500                           ; create fan 0 on pin fan0 and set its frequency
      M106 P0 S0 H-1                                 ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"fan1" Q500                           ; create fan 1 on pin fan1 and set its frequency
      M106 P1 S1 H1 T45                              ; set fan 1 value. Thermostatic control is turned on
      M563 P0 D0 H1 F0                               ; define tool 0
      G10 P0 X0 Y0 Z0                                ; set tool 0 axis offsets
      G10 P0 R0 S0                                   ; set initial tool 0 active and standby temperatures to 0C
      homeall.g
      ; homeall.g
      ; called to home all axes
      ; generated by RepRapFirmware Configuration Tool v3.1.3 on Wed Jul 08 2020 20:58:26 GMT+0200 (centraleuropeisk sommartid)
      G1 H2 Z5 F6000          ; lift Z relative to current position
      G1 H1 X-405 Y-405 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
      G1 H2 X5 Y5 F6000       ; go back a few mm
      G1 H1 X-405 Y-405 F360  ; move slowly to X and Y axis endstops once more (second pass)
      G90                     ; absolute positioning
      G1 X150 Y150 F6000        ; move Z down stopping at the endstop
      G30                     ; home Z by probing the bed
      G1 Z5 F100             ; lift Z relative to current position
      Is the heatmap very bad or ok to use without adjustments?
        As you have no DueX, you are not connecting the servo pin of the BLTouch duex.pwm5, so you should not use that selection in configtool or config.g. Use the name of the actual pin that you have connected it to, which is exp.heater7, and don't invert it. Although as it happens, using duex.pwm5 and inverting it will work.
        printthatthingundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
          printthatthing @dc42
          @dc42 Aha, okay that make sense.
            Phaedrux Moderator @dc42
            @dc42 said in RRF Config Mapping:
            Unfortunately the config tool currently doesn't show the expansion pins right now, just duex pins.
              Phaedrux Moderator @printthatthing
              @printthatthing said in RRF Config Mapping:
              That's a bit of a saddle shape for sure. You may or may not be able to fix that physically. You can test the effect of the compensation by printing a bed test like this: bedlevel_nozzle_0.4_200x200-0.3-0.8.stl
              printthatthingundefined 1 Reply Last reply Reply Quote 0
                printthatthing @Phaedrux
                @Phaedrux Ok thanks.
                  printthatthing
                  Now I'm stuck with error at bed heating.
                  Error: Heater 0 fault: temperature rising much more slowly than the expected 1.7°C/sec
                  Duet 2 Wifi power a solid state relay for a 220v heater.
                  I executed M307 H0 S90
                  M307 H0 results in below.
                  Heater 0 model: gain 340.0, time constant 140.0, dead time 5.5, max PWM 1.00, calibration voltage 0.0, mode bang-bang
                  Then I tried to save the value
                  M307 H0 A340 C140 D5.5 V0 B0
                  But it result in
                  Warning: M307: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C
                    That's expected. The warning is letting you know what the max uncontrolled temp could be.
                      @Phaedrux Ok, but I still not able to heat the bed. It start heating but halt after few seconds. Error: Heater 0 fault: temperature rising much more slowly than the expected 1.7°C/sec
                        Are you sure you saved the PID tuning results with M500? Do you also have an M501 at the end of config.g to load the saved results?
                          @Phaedrux i was missing M501 in config.g
                          Restarted boad but getting same error when trying to heat bed.
                          Tried to run M307 H0 S90 again but it fails with Error: M307: bad model parameters
                          ; config-override.g file generated in response to M500 at 2020-07-10 23:02
                          ; Heater model parameters
                          M307 H0 A340.0 C140.0 D5.5 S1.00 V0.0 B1
                          M307 H1 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                          ; Workplace coordinates
                          G10 L2 P1 X0.00 Y0.00 Z0.00
                          G10 L2 P2 X0.00 Y0.00 Z0.00
                          G10 L2 P3 X0.00 Y0.00 Z0.00
                          G10 L2 P4 X0.00 Y0.00 Z0.00
                          G10 L2 P5 X0.00 Y0.00 Z0.00
                          G10 L2 P6 X0.00 Y0.00 Z0.00
                          G10 L2 P7 X0.00 Y0.00 Z0.00
                          G10 L2 P8 X0.00 Y0.00 Z0.00
                          G10 L2 P9 X0.00 Y0.00 Z0.00
                            In config.g change M307 H0 B1 S1.00 to B0
                            Then delete your config-override.g and run M307 H0 S90 again after a reboot. Then save with M500.
                              Also make sure you're starting from a cold bed state.
                                @Phaedrux said in RRF Config Mapping:
                                Executed M307 H0 S90 after the suggested changes.
                                Update:
                                My bad, it might be M303 H0 S90
                                  Update:
                                  😑 Yes of course.
                                    Update:
                                    😑 Yes of course.
                                    Now it works fine:) Thank you so much for all support.
