    Fan0 does not work, Fan1 and 2 work
    • DrewCipherundefined
      DrewCipher
      FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.1.1 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2020-05-19b2
      config.bak.g
      All fan entries are default from the RRF Configurator
      Fans 1 & 2 work as expected but fan 0 does not work at all
      Fan VIN jumper set to VIN, Mosfets look ok
        A Former User @DrewCipher
        @DrewCipher said in Fan0 does not work, Fan1 and 2 work:
        Mosfets look ok
        can be tested with a multimeter
        ref:
        • https://www.utm.edu/staff/leeb/mostest.htm (or google mosfet test multimeter and pretty much pick any link or video)
        • https://assets.nexperia.com/documents/data-sheet/PMV40UN2.pdf
        edit:
        is it configured as a thermostatic fan perhaps? post config it it doesn't turn on when hotend is heated.
          M950 F0 C"fan0" Q500                               ; create fan 0 on pin fan0 and set its frequency
          M106 P0 S0 H-1                                     ; set fan 0 value. Thermostatic control is turned off
          M950 F1 C"fan1" Q500                               ; create fan 1 on pin fan1 and set its frequency
          M106 P1 S1 H1 T45                                  ; set fan 1 value. Thermostatic control is turned on
          M950 F2 C"fan2" Q500                               ; create fan 2 on pin fan2 and set its frequency
          M106 P2 S0 H-1                                     ; set fan 2 value. Thermostatic control is turned off
          M563 P0 D0 H1 F0                                   ; define tool 0
          What do you have plugged where?
          Does the fan itself work if plugged into an always on port?
          How are you trying to control fan 0?
            DrewCipher
            Fan0 is parts cooling 4010,
            Fan1 is Tool,
            Fan2 is parts cooling 5015.
            All physical fans work when plugged into always on
            I have measured Fan0 output with multimeter and shows 24+v when fan @0% and 20v+- when fan@any other value.
            I will test based on the recommended links
            Config is attached to OP
            Fan0 and Fan2 are configured to be parts cooling and not Thermostatically controlled.
              Phaedrux Moderator @Phaedrux
              @Phaedrux said in Fan0 does not work, Fan1 and 2 work:
              ; Tools M563 P0 D0 H1 F0 ; define tool 0
              Change F0 to F0:2 if you're using F0 and 2 as the part cooling fans.
