    Tool board configuration
    1.7k
    • madmattcoundefined
      madmattco @Danal
      @Danal That worked for me sir. Cheers
      • Nuramoriundefined
        Nuramori
        I have a BLTouch on my toolboard, if you need some help.
        dintidundefined 1 Reply Last reply Reply Quote 0
        • dintidundefined
          dintid @Nuramori
          @Nuramori Care to share your BLTouch config on Toolboard? I've tried setting it up using the RRF configurator, but I can't pick ioO.out as PWM for BLTouch, when also using Out 0 for heater.. don't know if there is a shared PWM (hope not) or just bad RRF configurator?
          RepRapFirmware supported G-codes: https://duet3d.com/wiki/G-code
          Nuramoriundefined 1 Reply Last reply Reply Quote 0
          • Nuramoriundefined
            Nuramori @dintid
            @dintid
            Iโ€™m happy to, but I wonโ€™t be able to get to it until Iโ€™m back from vacation. Sunday is the likely opportunity.
            • dintidundefined
              dintid @Nuramori
              @Nuramori I got it working.. sort of. !! (Original BLTouch v3.1 on Toolboard v1) All newest firmware (non-rc).
              • It does not selftest on power on of machine.
              • If I unplug BLTouch, power machine on, and plug in BLTouch after machine has started it does self test.
              • I've done a lot of continuity tests, and all wires are connectors are good all around.
              • I've measured on the connectors on Toolboard which reads 5v.. but when connecting BLTouch it briefly drops below 3v, so my issues might be some voltage drop?
              • Once the machine is ready I can run a long self test. It will however blink red afterwards, and I can't do a new self test.
              • The "reset warning and retract probe" does not work in this case.. but if I deploy and retract it stops blinking and I can do a new self test, and it starts over.
              • I can get it to use the "reset warning SW mode".. but can't do anything afterwards.
              • Z probe reads as 0. When I deploy and manually trigger it, it reads 1000 as it should
              • I noticed it is VERY weak, compared to other machine's BLTouch (maybe voltage issue?)
              • I've considered issuing the EEProm command to put it into 5v state, but I'm unsure wheter I risk burning something?
              Sidenote: I'm using a Quality Meanwell HRP psu. I measure output Volt at 24.2 at PSU and on Duet3 terminals,, while Duet3 reports it at 23.7v. Always... I find this somewhat.. odd? Using a decent quality Multiemter.
                dc42 administrators @dintid
                @dintid said in Tool board configuration:
                You could try adding a 100uF capacitor between the BLTouch +5V and ground connections.
                The Duet uses its 3.3V regulator as the voltage reference, so it can be few percent inaccurate. Your multimeter is probably more accurate.
                • Nuramoriundefined
                  Nuramori
                  Out of curiosity, do you have a terminating resistor on your can-fd line?
                  • dintidundefined
                    dintid @Nuramori
                    @Nuramori I don't know what that means? I have the requisite jumpers on my Distribution board.
                    • dintidundefined
                      dintid @dc42
                      @dc42 I only had a 35v 470uf. It didn't make a difference.
                      In your documentation you write that Orange i control wire.. but it's really yellow though?
                      https://duet3d.dozuki.com/Wiki/Duet_3_Tool_Board#Section_Connecting_a_BL_Touch
                        It depends on your colour vision and how you assign colours. I see it as orange.
                        • dintidundefined
                          dintid @dc42
                          @dc42 I'm colorblind but asked my two girls who aren't ๐Ÿ™‚
                          Any ideas to steps I can try to make BLTouch work on the Toolboard? I havn't had time to try it on the mainboard yet.
                            It's odd that it's not working, because BLTouch worked fine connected to the tool board when I took that photo. Are you certain that you have connected the wires correctly? The brown wire goes to ground (2nd terminal from the top) along with the black wire, which isn't clear in that photo.
                            • dintidundefined
                              dintid
                              Yea, I have it wired correctly. Might be faulty probe. It's rare but it happens.
                              I'm about to hook it up to Duet3 MB, and will report back ๐Ÿ™‚
                                Is it genuine BTouch, or a clone?
                                • dintidundefined
                                  dintid @dc42
                                  @dc42 Genuine, I only use genuine.
                                  I just tested with known good probe and it was a faulty probe, sigh. So much time wasted.
                                  Works fine on Toolboard.. tried getting it to work on io5 on Duet3 without luck though for some reason.
