    Paneldue crashing?
    PanelDue
    1.3k
    • CTRDevelopmentsundefined
      CTRDevelopments
      I am using a paneldue on my DuetWifi. Quite regularly the paneldue seems to stop communicating to the DuetWifi. The unit itself still works insofar as the menus work etc, but it doesnt command the Duet. Also the temperatures displayed freeze at a value (presumably the last received value) as does the time remaining. Seemingly however the 'STOP' button still works. Any thoughts on what I may have done wrong?
        jay_s_uk
        what firmware do you have running on the paneldue?
          CTRDevelopments
          What command will report the paneldue firmware? The DUET is on 2.05 (2019-12-13b1), Wifi 1.23
            jay_s_uk
            Its on the settings screen on the panel
              CTRDevelopments
              thanks
              1.23.2
                jay_s_uk
                I suggest upgrading to 1.24 and seeing whether the issue still manifests itself.
                https://github.com/Duet3D/PanelDueFirmware/releases/tag/1.24
                I would also suggest upgrading the duet firmware to 2.05.1
                https://github.com/Duet3D/RepRapFirmware/releases/tag/2.05.1
                  How are you connecting the Paneldue to the Duet? 4 wire connector or ribbon cable? Have you set a specific baud rate for the panel?
                    CTRDevelopments
                    The printer is in the middle of a 4 day print. I did update the DUET firmware (not paneldue yet as I thought I would try in stages) but that has not had any effect (still crashing)
                    Connecting to the Paneldue with the 4 wire connector, not set a specific baud rate
                    Cheers
                      Update the panel when you get a chance. How long is the 4-wire cable? I have had to replace the 4-wire cable that came with the panel at one point due to a similar connection issue. Replacing the cable solved it for me. It may have been a bad crimp or even wire weak spot. Not sure. I never tried to get too deep once I swapped it out and the new one worked. I did use that same cable on a different Paneldue where it seemed to work fine though, so who knows. cosmic rays.
                        CTRDevelopments
                        I have also noticed that when the paneldue 'freezes' the wifi connection also drops and there is no way to connect to the DUET. IT will finish the print it is on, but if anything pauses (filament run out etc) you cannot restart, or even see the message to work out why it has paused. Hopefully this is a clue
                          A Former User
                          Are you able to safely connect a usb cable and log the console to see if there are any hints, and if not enable some debugging with M111 and repeat?
                          Duet recommends YAT, my preference is RealTerm as i know it will write logs to files and timestamp the entries if you ask nicely. By all means use YAT if you have it installed and it can log and timestamp.
                            CTRDevelopments
                            I can try that. Just started another 24 hour print for a customer, so not too bad to wait. Not used YAT very much at all apart from initial setup, and never used RealTerm, but will give it a go.
                            If I used RealTerm how would i get it to write the log file repeatedly?
                            Cheers
                              A Former User @CTRDevelopments
                              @CTRDevelopments said in Paneldue crashing?:
                              It has a capture tab, just choose filename and timestamp and start it (it will insist on "direct capture" of you enable timestamp i.e. you will not see it while it captures, but you could monitor the output file in another application)
                                CTRDevelopments
                                sorry for late reply
                                Although it didnt hang, I logged WiFi and got (it did seem to dc from the wifi although the wifi has been perfect and this PC is on the same network)
                                1597693361,Leadscrew adjustments made: 0.216 0.148 0.287, points used 9, deviation before 0.278 after 0.196
                                1597693429,Leadscrew adjustments made: 0.012 -0.003 -0.039, points used 9, deviation before 0.187 after 0.186
                                1597693595,WiFi: ../src/Listener.cpp(66): refused conn on port 80 already 4 conns
                                1597693850,72 points probed, min error -0.269, max error 0.419, mean 0.091, deviation 0.158
                                1597693850,Height map saved to file heightmap.csv
                                1597699390,WiFi: ../src/Listener.cpp(66): refused conn on port 80 already 4 conns
                                1597705873,WiFi: ../src/Listener.cpp(66): refused conn on port 80 already 4 conns
                                1597708531,WiFi: ../src/Listener.cpp(66): refused conn on port 80 already 4 conns
                                1597708760,WiFi: bcn_timout,ap_probe_send_start
                                1597711968,WiFi: ../src/Listener.cpp(66): refused conn on port 80 already 4 conns
                                1597714967,WiFi: ../src/Listener.cpp(66): refused conn on port 80 already 4 conns
                                1597715138,WiFi: ../src/Listener.cpp(66): refused conn on port 80 already 4 conns
                                1597722743,WiFi: bcn_timout,ap_probe_send_start
                                1597722746,WiFi reported error: Lost connection, auto reconnecting
                                1597722746,WiFi: ap_probe_send over, rest wifi status to disassoc
                                1597722746,WiFi: state: 5 -> 0 (1)
                                1597722746,WiFi: rm 0
                                1597722746,WiFi: pm close 7
                                1597722746,WiFi: wifi evt: 1
                                1597722746,WiFi: STA disconnect: 200
                                1597722748,WiFi: scandone
                                1597722748,WiFi: state: 0 -> 2 (b0)
                                1597722748,WiFi: state: 2 -> 3 (0)
                                1597722748,WiFi: state: 3 -> 5 (10)
                                1597722748,WiFi: add 0
                                1597722748,WiFi: aid 4
                                1597722748,WiFi: cnt
                                1597722748,WiFi:
                                1597722748,WiFi: connected with CTRDevelopmentsWiFi, channel 6
                                1597722748,WiFi: dhcp client start...
                                1597722748,WiFi: wifi evt: 0
                                1597722753,WiFi: ../src/Listener.cpp(66): refused conn on port 80 already 4 conns
                                1597722758,WiFi: pm open,type:2 0
                                1597722770,WiFi: ../src/Listener.cpp(66): refused conn on port 80 already 4 conns
                                1597722772,WiFi: ../src/Listener.cpp(66): refused conn on port 80 already 4 conns
                                1597722774,WiFi: ../src/Listener.cpp(66): refused conn on port 80 already 4 conns
                                1597722776,WiFi: ../src/Listener.cpp(66): refused conn on port 80 already 4 conns
                                1597722778,WiFi: ../src/Listener.cpp(66): refused conn on port 80 already 4 conns
                                1597722780,WiFi: ../src/Listener.cpp(66): refused conn on port 80 already 4 conns
                                1597722782,WiFi: ../src/Listener.cpp(66): refused conn on port 80 already 4 conns
                                1597722784,WiFi: ../src/Listener.cpp(66): refused conn on port 80 already 4 conns
                                1597722786,WiFi reported error: Timed out while trying to connect to CTRDevelopmentsWiFi
                                1597722786,WiFi: sleep enable,type: 2
                                1597722786,WiFi: sl
                                1597722786,WiFi: scandone
                                1597722786,WiFi: usl
                                1597722786,WiFi: state: 5 -> 0 (0)
                                1597722786,WiFi: rm 0
                                1597722786,WiFi: pm close 7
                                1597722786,WiFi: del if0
                                1597722786,WiFi: mode : null
                                1597722786,WiFi: wifi evt: 1
                                1597722786,WiFi: STA disconnect: 8
                                1597722786,WiFi: wifi evt: 8
                                1597757185,Done printing file
                                1597757185,Finished printing file 0:/gcodes/Electronics Cover.gcode, print time was 17h 46m
                                  do you have multiple clients / processes connecting to the duet?
                                    CTRDevelopments
                                    Not that I know of. All I have is my single PC that I use for uploading. Nothing else is connected. Is there any way to see what those connections are?
                                    • Hornetriderundefined
                                      Hornetrider
                                      Hi there
                                      some time ago I have also expirienced the same behaviour of freezing communication between PanelDue and DuetWifi. And it allways happens when the Wifi Module reports a lost of connection.
                                      After running all latests updates, both on PanelDue and DuetWifi and resetting the Wlan Hotspot (finding a better channel) this issue was gone for a while.
                                      But now this week it started again.
                                      Today I have rebootet my Hotspot, to hopefully find a new and better 2.4GHz channel and therefore creating a stable connection.
                                      In my opinion the freeze of the comm is related to the procedure how the DuetWifi handles the Wifi connection initialisation and time out.
                                      I have also noticed, that right after restart of the DuetWifi and before the Wifi conn is established the communication between the PanelDue ant the DuetWifi is extremly delayed.
                                      For example:
                                      • Switch on DuetWifi
                                      • run Home all (during this period the Wifi Conn is not established as the machine has something different to do...)
                                      • after Home all and without promt of Wifi Conn-> try to activate a Makro or reading out files via PanelDue...extreme delay in 10+ sec
                                      • right after the Wifi has established a stable Connection everything works fine and in usual speed
                                      One more thing. The "Wifi lost conn" occurs shortly after the first connection build up (prompt by Duet) or even during a print.
                                      Only the STOP button on the Paneldue keeps working!
                                      Any ideas?
                                        Hornetrider
                                        Any comments at all?
                                          Phaedrux Moderator @Hornetrider
                                          @Hornetrider said in Paneldue crashing?:
                                          Please create a new thread with your issue. Include your config.g and homeall.g files since you mention those. Include what firmware version on the duet and paneldue. Thanks.
                                            Hornetrider
                                            HI @Phaedrux
                                            why a new thread if everything is explained here?
                                            Please find requested data below.
                                            xxxxxxxxxxxxxxxxx
                                            PanelDUE FW: 1.24
                                            Board: Duet WiFi 1.02 or later
                                            Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.0 (2020-01-03b3)
                                            Duet WiFi Server Version: 1.23
                                            xxxxxxxxxxxxxxxx
                                            Diag:
                                            Send code...
                                            10.9.2020, 20:26:29 M122
                                            RepRapFirmware for Duet 2 WiFi/Ethernet version 3.0 running on Duet WiFi 1.02 or later
                                            Board ID: 08DGM-917DA-G4MS8-6J9DD-3SN6R-1SVB9
                                            Used output buffers: 3 of 24 (21 max)
                                            Static ram: 30516
                                            Dynamic ram: 91948 of which 36 recycled
                                            Exception stack ram used: 560
                                            Never used ram: 8012
                                            Tasks: NETWORK(ready,640) HEAT(blocked,1240) MAIN(running,3740) IDLE(ready,156)
                                            Owned mutexes:
                                            Last reset 84:43:09 ago, cause: software
                                            Last software reset at 2020-09-07 07:42, reason: User, spinning module GCodes, available RAM 8028 bytes (slot 1)
                                            Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
                                            Error status: 10
                                            Free file entries: 10
                                            SD card longest block write time: 390.4ms, max retries 0
                                            MCU temperature: min 32.1, current 34.0, max 36.3
                                            Supply voltage: min 23.9, current 24.2, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
                                            Driver 0: standstill, SG min/max 0/173
                                            Driver 1: standstill, SG min/max 0/155
                                            Driver 2: standstill, SG min/max 0/781
                                            Driver 3: standstill, SG min/max 0/1023
                                            Driver 4: standstill, SG min/max 0/176
                                            Date/time: 2020-09-10 20:26:15
                                            Slowest loop: 84.39ms; fastest: 0.09ms
                                            Hiccups: 0(0), FreeDm: 169, MinFreeDm: 102, MaxWait: 82940312ms
                                            === MainDDARing ===
                                            Scheduled moves: 7, completed moves: 7, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
                                            === AuxDDARing ===
                                            Heater 0 is on, I-accum = 0.2
                                            Heater 1 is on, I-accum = 0.5
                                            Segments left: 0
                                            Movement lock held by null
                                            http is idle in state(s) 0
                                            telnet is idle in state(s) 0
                                            file is idle in state(s) 0
                                            serial is idle in state(s) 0
                                            aux is idle in state(s) 0
                                            daemon is idle in state(s) 0
                                            queue is idle in state(s) 0
                                            Code queue is empty.
                                            === Network ===
                                            Slowest loop: 391.94ms; fastest: 0.00ms
                                            Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                                            HTTP sessions: 1 of 8
                                            • WiFi -
                                              Network state is running
                                              WiFi firmware version 1.23
                                              WiFi MAC address ec:fa:bc:2d:e8:d1
                                              WiFi Vcc 3.39, reset reason Turned on by main processor
                                              WiFi flash size 4194304, free heap 25672
                                              WiFi IP address 192.168.1.110
                                              WiFi signal strength -39dBm, reconnections 0, sleep mode modem
                                              10.9.2020, 20:26:11 Connected to 192.168.1.110
                                            XXXXXXXXXXXXXXXXXX
                                            Config:
                                            M552 S1 ; Enable network and acquire dynamic address via DHCP
                                            M586 P0 S1 ; Enable HTTP
                                            M586 P1 S0 ; Disable FTP
                                            M586 P2 S0 ; Disable Telnet
                                            M569 P0 S0 ; Drive X goes backwards
                                            M569 P1 S1 ; Drive Y1 goes forwards
                                            M569 P2 S0 ; Drive Z goes forwards
                                            M569 P3 S1 ; Drive E0 goes backwards
                                            M569 P4 S0 ; Drive Y2
                                            M584 X0 Y1:4 Z2 E3 ; Apply custom drive mapping
                                            ; Microstepping
                                            M350 X32 Y32 Z16 E16 I1 ; Configure microstepping without interpolation
                                            M92 X160 Y160 Z1600.00 E410 ; @32 X and Y Ratio 24:20 (2020.01.12)Set steps per mm for Bondtech BMG Extruder
                                            ; Speed & Acceleration
                                            M566 X600.00 Y600.00 Z80.00 E1200.00 ; Set maximum instantaneous speed changes (mm/min)
                                            M203 X8000.00 Y8000.00 Z400.00 E6000.00 ; Set maximum speeds (mm/min)
                                            ;M203 X8000.00 Y8000.00 Z400.00 E6000.00 ; Set maximum speeds (mm/min)
                                            M201 X800.00 Y800.00 Z45.00 E3000.00 ; Set accelerations (mm/s^2)
                                            ;M201 X800.00 Y800.00 Z30.00 E3000.00 ; Set accelerations (mm/s^2)
                                            ; Motor Current
                                            M906 X1000.00 Y1000.00 Z900.00 E950 I30 ; Set motor currents (mA) and motor idle factor in per cent
                                            M84 S5 ; Set idle timeout
                                            M208 X295 Y330 Z298 S0 ; Set axis maxima
                                            M574 X1 S1 P"!xstop" ; configure active-high endstop for low end on X via pin xstop
                                            M574 Y1 S1 P"!ystop" ; configure active-high endstop for low end on Y via pin ystop
                                            M574 Z1 S2
                                            ; Z-Probe Inductive
                                            ;M558 P5 H5 F120 T6000 ; Set Z probe type to switch and the dive height + speeds
                                            ;G31 P500 X0 Y0 Z1.42 ; Set Z probe trigger value, offset and trigger height
                                            ;M557 X5:170 Y5:275 S40 ; Define mesh grid
                                            ; BLTouch
                                            ;M307 H4 A-1 C-1 D-1
                                            ;M558 P9 F100 H3 R0.3 T7000 A5 B1 ; Set Z probe type to switch and the dive height + speeds
                                            ;G31 P25 X-40 Y40 Z2.26 ; Set Z probe trigger value, offset and trigger height
                                            ;M557 X5:215 Y5:295 S55 ; Define mesh grid
                                            ; Precision Piezo
                                            M558 P8 C"zprobe.in+zprobe.mod" I1 R0.4 H2 F420 T3000 A5 B0 ; Set Z probe type to switch and the dive height + speeds
                                            G31 P500 X0 Y0 Z-0.5 ; Set Z probe trigger value, offset and trigger height
                                            M557 X5:285 Y5:330 S93 ; Define mesh grid
                                            ; Laser Filament Sensor
                                            ;M591 D0 P5 C3 R130:280 E3.0 S0 ; Duet3D laser sensor for extruder drive 0, connected to endstop input 3 (E0), tolerance 40 to 120%, 3mm comparison length, disabled
                                            ; Rotating Magnet Filament Sensor
                                            M591 D0 P3 C3 R70:130 E3.0 S0 ; Duet3D laser sensor for extruder drive 0, connected to endstop input 3 (E0), tolerance 40 to 120%, 3mm comparison length, disabled
                                            ; Heaters RRF3.0x
                                            ; Heaters RRF2.05
                                            ;M305 P0 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 0
                                            ;M143 H0 S120 ; Set temperature limit for heater 0 to 120C
                                            ;M305 P1 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 1
                                            ;M143 H1 S280 ; Set temperature limit for heater 1 to 280C
                                            ; Board Cooling
                                            M308 S2 Y"drivers" A"DRIVERS" ; configure sensor 2 as temperature warning and overheat flags on the TMC2660 on Duet
                                            M308 S3 Y"mcu-temp" A"MCU" ; configure sensor 3 as thermistor on pin e1temp for left stepper
                                            M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency
                                            M106 P2 H2:3 L0.15 X1 B0.3 T36:45 ; set fan 2 value
                                            ; Fans RRF2.05
                                            ;M106 P0 S0 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
                                            ;M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
                                            ;M106 P2 T36:46 H100:101:102 ; Set Fan speed to cool MCU
                                            M563 P0 D0 H1 ; Define tool 0
                                            ; MCU temp Adjustment
                                            M912 P0 S-9
                                            T0 ; Select first tool
                                            ;load config-override
                                            M501
                                            xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
                                            Homeall:
                                            ; homeall.g
                                            ; called to home all axes
                                            ; generated by RepRapFirmware Configuration Tool v2 on Mon Dec 31 2018 02:05:14 GMT+0100 (Mitteleuropäische Normalzeit)
                                            G91 ; relative positioning
                                            G1 H1 X-300 Y-340 F3000 ; move quickly to X and Y axis endstops and stop there (first pass)
                                            G1 X10 Y10 F6000 ; go back a few mm
                                            G1 H1 X-15 Y-15 F360 ; move slowly to X and Y axis endstops once more (second pass)
                                            G90 ; absolute positioning
                                            G1 X147.5 Y167 F8000 ; go to first bed probe point and home Z
                                            M140 S50 ; Set Bed to 50DEC
                                            G10 S210 ; Set current tool temperature to 130C
                                            M116 ; Wait for the temperatures to be reached
                                            ;play sound
                                            M400
                                            G4 P200
                                            M300 P200 S523.25
                                            G4 P200
                                            M300 P200 S659.25
                                            G4 P200
                                            M300 P200 S739.99
                                            G4 P250
                                            M300 P285 S880.00
                                            G4 P450
                                            M300 P285 S880.00
                                            G4 P285
                                            M300 P625 S1108.73
                                            G4 P200
                                            G90
                                            XXXXXXXXXXXXX
                                            Vetiundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
