    Warning: the height map has a substantial Z offset
    2.2k
    • fcwiltundefined
      fcwilt
      I also have a macro for loading the height map. The macro I have for starting a print invokes this file.
      Notice here that I am showing the invoking of the macros for configuring the probe and setting the Z=0 datum.
      The code that performs these function, that I included the previous post, is essentially what is in these two macros.
      M98 P"configprobe.g"		; configure Z probe
      M98 P"probeZ.g"			; set Z=0 Datum
      G29 S1                          ; load height map
      M376 H10		        ; set bed compensation taper
      • downshift64undefined
        downshift64
        thank you i will give them a try does it matter where i put these commands in the config.g
          downshift64
          i dont use a BLTouch i attach a probe then when i am done take it off and usually dont use it again unless something changes
          • fcwiltundefined
            fcwilt @downshift64
            @downshift64 said in Warning: the height map has a substantial Z offset:
            They should NOT be part of config.g.
            If you do like I do and create the height map manually by invoking the macro you would create a macro to do that.
            If you wish to create the height map on every print you should invoke the code when starting a print.
            As to loading the height map it should be part of the code you invoke when starting a print.
            I have my slicer invoke a macro called "print_begin.g". All of the code needed to prepare for printing is in that macro.
            Also In this macro I invoke the macro to load the height map.
              downshift64
              damn i wish this was easier
              • fcwiltundefined
                fcwilt @downshift64
                Hmm...
                Then I don't know how you are going to set the Z=0 datum without a Z probe.
                I have found that I needed to install a BLTouch as the Z=0 setting changed as the bed assembly heated up. So each print potentially needed to have Z=0 set again - which is what I do now.
                  downshift64
                  i heat the bed up then probe it and save the height map i have something that uses that each time i start a new print
                  • fcwiltundefined
                    fcwilt @downshift64
                    If you have a Z probe AND make use of macros called via M98 it can be fairly straightforward and easy to maintain.
                      downshift64
                      my slicer start g code
                      G90 ; use absolute coordinates
                      M83 ; extruder relative mode
                      M104 S[first_layer_temperature] T0 ; set extruder temp
                      M140 S[first_layer_bed_temperature] ; set bed temp
                      M190 S[first_layer_bed_temperature] ; wait for bed temp
                      M109 S[first_layer_temperature] T0; wait for extruder temp
                      G28 ; home all without mesh bed level
                      G29 S1 ; mesh bed leveling
                      G1 Z0.25 F2500
                      G1 Y0 F1000.0 ; go outside print area
                      G92 E0.0
                      G1 X60.0 E9.0 F1000.0 ; intro line
                      G1 X100.0 E12.5 F1000.0 ; intro line
                      G92 E0.0
                      M221 S{if layer_height<0.075}100{else}95{endif}
                      • fcwiltundefined
                        fcwilt @downshift64
                        The problem is the height map is referenced to the Z=0 datum when the height map is created.
                        When the height map is loaded it expects that Z=0 datum to be the same value.
                        Without a Z probe I'm not sure how to handle it other than assuming Z=0 is a fixed value and never changes.
                          downshift64
                          ya once i get height map it is a fixed value and should never change really
                          • fcwiltundefined
                            fcwilt @downshift64
                            That has not been my experience with my printers but if yours is unchanging that is great.
                              downshift64
                              its an Ulitmate XL from Elite Machine Works its a solid bed
                                Post your home all.
                                The warning is a warning, it may not apply to you, but without seeing your homing files I can't say. Your slicer start gcode does a G28 to home the printer and then G29 S1 to load the heightmap. What we don't know is what homeall.g is doing to home the printer. Is it using an endstop, or a zprobe? That's where the potential for an offset lies. You probably updated the firmware from a version that didn't have the warning to one that does. If your first layer is still good, then you have no problem and you can ignore it. Or if you want to get rid of it, post your homeall so we can see what's going on with the gcode.
                                  downshift64
                                  thank you i would like to get rid of it
                                  G91 ; relative mode
                                  G1 S1 Z310 F3500 ; move Z towards the switch until it triggers
                                  G1 Z-4 F900 ; move Z back 10mm
                                  G1 S1 Z6 F600 ; move Z slowly towards the switch until it triggers
                                  G1 S1 Z6 F400 ; move Z slowly towards the switch until it triggers
                                  G1 X-340 F7000 S1 ;
                                  G1 X4 F600 ; move slowly 4mm in the +X direction
                                  G1 X-5 S1 ; move slowly 10mm in the -X direction, stopping at the homing switch
                                  G1 Y-340 F7000 S1 ; move up to 240mm in the -Y direction, stopping if the homing switch is triggered
                                  G1 Y5 F600 ; move slowly 4mm in the +X direction
                                  G1 Y-6 S1 ; move slowly 10mm in the -X direction, stopping at the homing switch
                                  G4 P0 ; CLEAR BUFFER IN ORDER TO PROPERLY LOAD SAVED GRID
                                  G90
                                  ;G29 S1 ; LOAD SAVED BED GRID
                                  G4 P0 ; CLEAR BUFFER AFTER LOADING GRID
                                  G1 X0 Y0 F8000
                                  fcwiltundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                                  • fcwiltundefined
                                    fcwilt @downshift64
                                    I see the comment but I don't understand the purpose.
                                    What buffer do you think needs clearing to load the height map?
                                    I have never used G4 P0 and everything works just fine.
                                      downshift64
                                      sorry i cant answer your question this is what i got when i purchased the printer
                                        downshift64
                                        maybe something to do with not having to probe the bed every time before i print
                                          Phaedrux Moderator @downshift64
                                          It's saying you may have an offset because it's using an endstop to home the Z axis before loading the heightmap. If the endstop position is perfectly set then you don't have an issue, but it will still warn you.
                                          fcwiltundefined downshift64undefined 2 Replies Last reply Reply Quote 0
                                          • fcwiltundefined
                                            fcwilt @Phaedrux
                                            @Phaedrux said in Warning: the height map has a substantial Z offset:
                                            You sure?
                                            I thought the offset warning was based on the contents of the height map file alone.
                                            I tried to verify that but I couldn't figure an easy way to add a significant offset to each value in the file and then load it.
