Warning: the height map has a substantial Z offset
i dont use a BLTouch i attach a probe then when i am done take it off and usually dont use it again unless something changes
@downshift64 said in Warning: the height map has a substantial Z offset:
thank you i will give them a try does it matter where i put these commands in the config.g
They should NOT be part of config.g.
If you do like I do and create the height map manually by invoking the macro you would create a macro to do that.
If you wish to create the height map on every print you should invoke the code when starting a print.
As to loading the height map it should be part of the code you invoke when starting a print.
I have my slicer invoke a macro called "print_begin.g". All of the code needed to prepare for printing is in that macro.
Also In this macro I invoke the macro to load the height map.
damn i wish this was easier
Hmm...
Then I don't know how you are going to set the Z=0 datum without a Z probe.
I have found that I needed to install a BLTouch as the Z=0 setting changed as the bed assembly heated up. So each print potentially needed to have Z=0 set again - which is what I do now.
i heat the bed up then probe it and save the height map i have something that uses that each time i start a new print
If you have a Z probe AND make use of macros called via M98 it can be fairly straightforward and easy to maintain.
my slicer start g code
G90 ; use absolute coordinates
M83 ; extruder relative mode
M104 S[first_layer_temperature] T0 ; set extruder temp
M140 S[first_layer_bed_temperature] ; set bed temp
M190 S[first_layer_bed_temperature] ; wait for bed temp
M109 S[first_layer_temperature] T0; wait for extruder temp
G28 ; home all without mesh bed level
G29 S1 ; mesh bed leveling
G1 Z0.25 F2500
G1 Y0 F1000.0 ; go outside print area
G92 E0.0
G1 X60.0 E9.0 F1000.0 ; intro line
G1 X100.0 E12.5 F1000.0 ; intro line
G92 E0.0
M221 S{if layer_height<0.075}100{else}95{endif} -
The problem is the height map is referenced to the Z=0 datum when the height map is created.
When the height map is loaded it expects that Z=0 datum to be the same value.
Without a Z probe I'm not sure how to handle it other than assuming Z=0 is a fixed value and never changes.
ya once i get height map it is a fixed value and should never change really
That has not been my experience with my printers but if yours is unchanging that is great.
its an Ulitmate XL from Elite Machine Works its a solid bed
Post your home all.
The warning is a warning, it may not apply to you, but without seeing your homing files I can't say. Your slicer start gcode does a G28 to home the printer and then G29 S1 to load the heightmap. What we don't know is what homeall.g is doing to home the printer. Is it using an endstop, or a zprobe? That's where the potential for an offset lies. You probably updated the firmware from a version that didn't have the warning to one that does. If your first layer is still good, then you have no problem and you can ignore it. Or if you want to get rid of it, post your homeall so we can see what's going on with the gcode.
thank you i would like to get rid of it
G91 ; relative mode
G1 S1 Z310 F3500 ; move Z towards the switch until it triggers
G1 Z-4 F900 ; move Z back 10mm
G1 S1 Z6 F600 ; move Z slowly towards the switch until it triggers
G1 S1 Z6 F400 ; move Z slowly towards the switch until it triggersG1 X-340 F7000 S1 ;
G1 X4 F600 ; move slowly 4mm in the +X direction
G1 X-5 S1 ; move slowly 10mm in the -X direction, stopping at the homing switchG1 Y-340 F7000 S1 ; move up to 240mm in the -Y direction, stopping if the homing switch is triggered
G1 Y5 F600 ; move slowly 4mm in the +X direction
G1 Y-6 S1 ; move slowly 10mm in the -X direction, stopping at the homing switchG4 P0 ; CLEAR BUFFER IN ORDER TO PROPERLY LOAD SAVED GRID
G90
;G29 S1 ; LOAD SAVED BED GRIDG4 P0 ; CLEAR BUFFER AFTER LOADING GRID
G1 X0 Y0 F8000
I see the comment but I don't understand the purpose.
What buffer do you think needs clearing to load the height map?
I have never used G4 P0 and everything works just fine.
sorry i cant answer your question this is what i got when i purchased the printer
maybe something to do with not having to probe the bed every time before i print
G1 S1 Z6 F400 ; move Z slowly towards the switch until it triggersIt's saying you may have an offset because it's using an endstop to home the Z axis before loading the heightmap. If the endstop position is perfectly set then you don't have an issue, but it will still warn you.
@Phaedrux said in Warning: the height map has a substantial Z offset:
You sure?
I thought the offset warning was based on the contents of the height map file alone.
I tried to verify that but I couldn't figure an easy way to add a significant offset to each value in the file and then load it.
@Phaedrux so there is nothing i can do to get rid of the warning,, if not is it still using my heightmap as intended
You can get rid of the warning and any potential offset by using the z probe to home the z axis. (Provided your z probe z offset in g31 is correct).
If your first layers are good, then yes your height map is being applied and all is good.
