Solved Sammy-C21 CAN errors
@R3D I don't know the consequences of wrong frequency.
Also your link to the post states that the bootloader has the clock multiplier changed in it already, which I did flash to the sammy with the ICE prior to uploading firmware...
@R3D ok, then it would be ok.
@JoergS5 said in Sammy-C21 CAN errors:
i think that is not relevant when building the SAMMYC21 configuration as dc42 has taken care if it all for us.
I also loaded the firmware binary through the ICE as well, possibly overwriting the bootloader and thus removing the clock multiplier fix?
If I am following this correctly that is.
Thanks,
@R3D said in Sammy-C21 CAN errors:
use the SAMMYC21-Debug build config in that case
(edit ref: https://duet3d.dozuki.com/Wiki/Using_the_Sammy-C21_development_board_with_Duet_3#Section_Debugging_your_own_firmware) -
I did, in my previous comments I did specify this.
Thanks,
@R3D maybe you can debug sammy and check can communication. The sammy has a SWD connector (but the pins must be soldered).
So i have the ICE in the SAMMY with both powered on, I have it connected in atmel studio 7 in the device programming tab, but I am having trouble locating any information regarding the CAN bus.
Any suggestions?
Thanks,
It's been over a month since I tested the SammyC21 firmware build. I've just built and loaded the debug build through ICE and I am getting the same issue - no CAN connection. I'll fix this today if i don't run out of time.
Currently, the release build works (loaded over CAN by the bootloader), but the debug build loaded via the ICE doesn't.
I've just fixed the SammyC21 debug build and committed the fix to github. The main change was in the .cproject file, and I had to do a clean and then a build to get the change included in the binary.
Works, Thanks a million @dc42, now on to calibration.
