    New IR z probe issues
    IR Height Sensor
    3.5k
      Your trigger height in G31 is still the default 2.5. Your measured amount was closer to 1.7ish, so you need to update that. The trigger height would be more consistent if the mount was improved.
      It is triggering now though right?
      https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
      agent0810undefined 1 Reply Last reply Reply Quote 0
      • agent0810undefined
        agent0810 @Phaedrux
        @Phaedrux
        so when i do home all it goes up to the nozzle then back down a bit, then i do the G30 S-1 and it goes up to almost where i need it to be, so close. but still needs to go up a bit more. i have gone through the page alot and changed the offset and trigger heights with no luck. i tried at 1.7, 5, and now im at 0, all put it at the same place.
        here is my config currently
        ; generated by RepRapFirmware Configuration Tool v3.1.3 on Sun Jul 05 2020 20:32:26 GMT-0500 (Central Daylight Time)
        M550 P"Schaal3DPrinter" ; set printer name
        M552 S1 ; enable network
        M586 P0 S1 ; enable HTTP
        M586 P1 S1 ; enable FTP
        M586 P2 S1 ; enable Telnet
        M569 P1 S0 ; physical drive 1 goes forwards
        M569 P3 S0 ; physical drive 3 goes forwards
        M92 X80.00 Y80.00 Z800.00 E102.30 ; set steps per mm
        M84 S30 ; Set idle timeout
        M208 X225 Y225 Z300 S0 ; set axis maxima
        M574 X2 S1 P"xstop" ; configure active-high endstop for low end on X via pin xstop
        M574 Y2 S1 P"ystop" ; configure active-high endstop for low end on Y via pin ystop
        M574 Z1 S1 P"zstop" ; configure active-high endstop for high end on Z via pin zstop
        M558 P1 C"zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
        G31 P500 X50 Y0 Z0.005 ; set Z probe trigger value, offset and trigger height
        M501
          Phaedrux Moderator @agent0810
          @agent0810 said in New IR z probe issues:
          Sorry this doesn't make any sense to me.
          Are you following the instructions on jogging the nozzle to touch the bed, sending G92 Z0, raising the nozzle a bit and then sending G30 S-1? That should give you a trigger height. You then put that trigger height value into the G31 Z. Then after rebooting and homing you should be able to have Z0 just touch the bed.
            agent0810 @Phaedrux
            @Phaedrux
            Doing everything you say there, except instead of raising the nozzle i am lowering the bed. that is what has me confused, from everything im doing i feel like i should be getting the results i want.\
            and to be clear, what i put in G31 Z is the output on the console right?
            thanks again
              agent0810
              and to be clear, what i put in G31 Z is the output on the console right? so i would put in 1.501 for this?
              7/21/2020, 10:55:50 PM G30 S-1
              Stopped at height 1.501 mm
                droftarts administrators @agent0810
                Yes, that's correct. You can send G31 Z1.501 in the console, then send G31 to check it is set, eg my G31 response is:
                G31
                Z probe 0: current reading 0, threshold 500, trigger height 1.250, offsets X20.0 Y0.0
                Test that the probe is functioning correctly by homing Z, then move Z to 0 and check the nozzle is just touching the bed. Then modify your G31 line in config.g, so that the new setting persists after a reset. Change G31 line in config.g to:
                 G31 P500 X0 Y0 Z1.501 ; set Z probe trigger value, offset and trigger height
                agent0810undefined 2 Replies Last reply Reply Quote 0
                  agent0810 @droftarts
                  @droftarts thank you!
                  did as you asked and it is still a little to high, its not pushing the filament onto the glass bed.
                    @droftarts
                    i have it zeroed in the middle of the bed. this is what i see on my web interface, that normal?
                      @agent0810 Adjust with 'Z babystepping' (on the Status tab of DWC), until you're happy with how the first layer is going down. Presumably you'll need raise the bed a little, so this may be -0.1mm of babystepping, so you can reduce the G31 Z height by 0.1mm. If you do this, don't forget to reset babystepping (with M290 R0 S0) if you don't reset the printer.
                      Have you calibrated your extruder, though? If you haven't, it may be underextruding, which will also make it look like the nozzle is too far off the bed. So get that right, too.
                        What do you mean, zeroed? If you want X0 Y0 to be in the middle of the bed, you need to adjust M208. At the moment yours is set to:
                        So it's not surprising that, with the nozzle in the middle of the bed, X and Y are 120. To get X0 Y0 to be in the middle, you'll want something like:
                        M208 X-120 Y-120 Z0 S1 ; set axis minima
                        M208 X120 Y120 Z300 S0 ; set axis maxima
                        See https://duet3d.dozuki.com/Wiki/Centering_the_bed_or_setting_the_bed_origin
                          @droftarts
                          started printing and had to z babyset +.05 to 1mm to get it where i need it.
                          Current Offset: 1.00 mm
                          what do i need to do to keep it here?
                            @droftarts
                            print came out amazing, just need to have it default to the 1mm babystep.
                            • fcwiltundefined
                              fcwilt @agent0810
                              @droftarts
                              While you can change the baby step setting in code you can also adjust the the trigger height setting of your Z probe to achieve the same thing - which is what I do.
                              If you used baby stepping to move the nozzle closer to the bed increase the trigger height setting by that amount.
                              If you used baby stepping to move the nozzle away to the bed decrease the trigger height setting by that amount.
                                agent0810 @fcwilt
                                @fcwilt
                                so if im currently at
                                G31 P500 X50 Y0 Z1.501
                                and my current offset was 1 mm that i had to move the nozzle away from the bed. i need to decrease the Z from 1.501 to .501?
                                so
                                G31 P500 X50 Y0 Z.501?
                                i am fairly positive that i have tried that and it didnt work 😞
                                  A larger G31 value results in the nozzle being closer to the bed.
                                  • fcwiltundefined
                                    fcwilt @agent0810
                                    @fcwilt
                                    so
                                    If you use baby stepping to move AWAY from the bed then the trigger height setting must be decreased.
                                    If you're numbers are correct then that value is correct.
                                    You can always determine the trigger height setting through trial and error, adjusting it up or down with G31, setting the Z=0 datum with G30 and repeating the process until moving to Z=0 has the nozzle just touching the bed.
                                      agent0810 @fcwilt
                                      @fcwilt
                                      what is the P value in this line?
                                        trigger sensitivity.
                                          agent0810 @fcwilt
                                          @fcwilt
                                          i am not sure what i am doing wrong. i set it to the .501 and its still to far from the bed, filament isnt sticking. im not sure where to go from here. since it was to far away i lowered it to 0 and its still to far away.
                                          droftartsundefined jumpedwithbothfeetundefined 2 Replies Last reply Reply Quote 0
                                            Phaedrux Moderator @Phaedrux
                                            @Phaedrux said in New IR z probe issues:
                                            If it's still too far away you're going in the wrong direction. Instead of 0.5 you would need to add to the value, so 2.5.
