    Duet 3 Heated Bed config
    668
    • rothundefined
      roth
      • rothundefined
        roth
        Is that ok that the Red: Diagnosis LED blinks ?
        Ok i see its ok :
        https://forum.duet3d.com/topic/17287/duet-3-diagnosis-led-will-not-stop-blinking/4
          Phaedrux Moderator @roth
          @roth said in Duet 3 Heated Bed config:
          Left V_OUTO +
          OUTO- Ground
          Note where is says out0 power in? You need to provide power there either from the PSU directly or jumped over from vin.
          Alternatively since you are using an external relay you may be able to use a low current output instead of the high current out0.
          The diagnosis light is fine.
          • rothundefined
            roth
            So that's why it doesn't work. You didn't have to do that with Duet wifi.
            thank you !
            Then I'll just mount a cable bridge.
            • rothundefined
              roth
              Ok
              Ok after I added the cable the heating bed heats up a little but only a few seconds.
              Then again :
              Error: Heater 0 fault: temperature rising much more slowly than the expected 1.7°C/sec
              It cannot heat up quickly at 1.7 ° C / sec
              Where can you judge that?
                In RRF3 there is no longer a default heater model assumption used for the bed. Therefore, you must perform a PID auto tuning to give the firmware a model for bed heater performance. Failure to do so will result in an error message that the heater temperature is not rising fast enough and therefore triggering thermal protection. Running the PID auto tune for the bed and saving the results should resolve the error.
                https://duet3d.dozuki.com/Wiki/Tuning_the_heater_temperature_control?revisionid=HEAD#Section_Setting_the_model_parameters_by_auto_tuning
                • rothundefined
                  roth
                  Ok
                  Then I'll read that.
                  There is a lot to read.
                  • rothundefined
                    roth
                    I once tested the hotend. it works that way too.
                    Should you also do auto tune there?
                      Yes pid auto tune is recommended for all heaters
                      • rothundefined
                        roth
                        @Phaedrux said in Duet 3 Heated Bed config:
                        RRF3
                        I have to say I think RRF3 and the new Duet 3 are very good.
                        The connections are better. Clamp larger ones ..
                        12 V at 24 power supply now possible ...
                        And PID auto tune.
                        I can connect different sensors or panel due to IO_3 - IO_7 ..
                        Everything has become more flexible.
                        A very nice advance to Duet Wifi with RRF2
