    Would like to have fan state accessible in Object Model
    Firmware wishlist
    317
    • fcwiltundefined
      fcwilt
      I would like to have, if possible, fan state information made part of the object model.
      OwenDundefined 1 Reply Last reply Reply Quote 0
      • OwenDundefined
        OwenD @fcwilt
        @fcwilt
        Does fans[n].actualValue not provide what you need?
        • fcwiltundefined
          fcwilt @OwenD
          @OwenD said in Would like to have fan state accessible in Object Model:
          @fcwilt
          Thanks for the reply.
          There must be a newer version of the documentation. The one I am using doesn't list that.
          https://duet3d.dozuki.com/Wiki/Object_Model_of_RepRapFirmware
          Do you have a link?
            A Former User
            you're probably best of looking at your actual object model with M409 as the docs are likely to be out of date on and off as things develop.
            iirc dc42 said RRF3.2 + DWC3.2 would have an visual interface to the object model so that'll help a lot when released.
            • fcwiltundefined
              fcwilt @A Former User
              @bearer said in Would like to have fan state accessible in Object Model:
              What threw me off was the statement
              "Values in the OM can be retrieved in the following ways"
              in the section where they mentioned M409.
              I didn't realize that it could return portions of object model and not just specific values.
              Perhaps that ability should be made a bit more prominent in that section.
              • OwenDundefined
                OwenD @fcwilt
                @fcwilt In your web browser try (during a print)
                http://your.printer.ip.address/rr_model?flags=d99fv
                Returning the entire object model has been limited in M409 as it's too much data.
                You have to do a section at a time.
                • fcwiltundefined
                  fcwilt @OwenD
                  Thanks for the feedback.
                  Yes, I found that out. It accepts the request but appears to timeout and disconnect.
                  The important feature for me is that M409 can provide more than just values but names and structure as well.
                    A Former User
                    (i think rr_model suffer the same limitation as M409 when not used with DSF)
                    • fcwiltundefined
                      fcwilt
                      How do I mark this topic of mine as solved?
                        A Former User @fcwilt
                        @fcwilt said in Would like to have fan state accessible in Object Model:
                        solved
                        https://forum.duet3d.com/topic/7773/forum-feature-mark-as-question-solved
                        edit note first "ask question" then "solved" backwards, but..
                        • fcwiltundefined
                          @bearer
                          Thanks much.
                            Phaedrux Moderator @fcwilt
                            Very Soon it will become much much easier to view and interact with the OM in DWC.
                            • fcwiltundefined
                              fcwilt @Phaedrux
                              @Phaedrux said in Would like to have fan state accessible in Object Model:
                              Very Soon
                              Sounds good but M409 solved my immediate problem once I found out it could provide information about the structure of the OM in addition to specific values.
