    Duet 3 + SBC Lost connection. No Header
    932
      If you can still access the configuration files from the Pi you can use those same config files on a separate SD card that will then go in the Duet. You'll also need the DWC files present in the www folder.
      Here's a breakdown of the SD card contents required.
      https://duet3d.dozuki.com/Wiki/SD_Card
        A Former User
        Would most likely want to add M552 S1 to enable network for stand alone (if not already in there ofc, but it's not needed for the Pi)
        • chrishornbyundefined
          chrishornby @Phaedrux
          @Phaedrux I managed to get a M122 report eventually, it was very difficult as you see the board is resetting every fraction of a second. I have checked continuity on the reset button and it is open so should be okay. :
          7/24/2020, 10:35:00 AM Connection to Duet established
          7/24/2020, 10:35:00 AM Warning: Lost connection to Duet (Board is not available (no header))
          7/24/2020, 10:35:00 AM M122
          RepRapFirmware for Duet 3 MB6HC version 3.1.1 running on Duet 3 MB6HC v0.6 or 1.0 (SBC mode)
          Board ID: 08DJM-956L2-G43S4-6J9F4-3SJ6R-TA6AG
          Used output buffers: 1 of 40 (10 max)
          Static ram: 154604
          Dynamic ram: 161152 of which 52 recycled
          Exception stack ram used: 224
          Never used ram: 77184
          Tasks: NETWORK(ready,1980) HEAT(blocked,1464) CanReceiv(suspended,3820) CanSender(suspended,1488) CanClock(blocked,1468) TMC(blocked,204) MAIN(running,5216) IDLE(ready,76)
          Owned mutexes:
          Last reset 00:00:00 ago, cause: software
          Last software reset at 2020-07-24 10:35, reason: Terminate called, spinning module GCodes, available RAM 76840 bytes (slot 0)
          Software reset code 0x4183 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0x20417540 Task MAIN
          Stack: 0000002b 0046b487 00000000 2044d278 204178a0 0046b7ef 00000000 0046b175 20417590 004507ef 204175e0
          Error status: 0
          MCU temperature: min 25.9, current 26.0, max 26.0
          Supply voltage: min 23.2, current 23.2, max 23.3, under voltage events: 0, over voltage events: 0, power good: yes
          12V rail voltage: min 12.0, current 12.0, max 12.1, under voltage events: 0
          Driver 0: standstill, reads 1861, writes 12 timeouts 0, SG min/max 0/0
          Driver 1: standstill, reads 1862, writes 12 timeouts 0, SG min/max 0/0
          Driver 2: standstill, reads 1862, writes 12 timeouts 0, SG min/max 0/0
          Driver 3: standstill, reads 1863, writes 12 timeouts 0, SG min/max 0/0
          Driver 4: standstill, reads 1864, writes 11 timeouts 0, SG min/max 0/0
          Driver 5: standstill, reads 1865, writes 11 timeouts 0, SG min/max 0/0
          Date/time: 2020-07-24 10:35:00
          Slowest loop: 3.20ms; fastest: 0.14ms
          === Storage ===
          Free file entries: 10
          === MainDDARing ===
          Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
          === AuxDDARing ===
          Bed heaters = -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1
          Segments left: 0
          Movement lock held by null
          HTTP* is ready with "M122" in state(s) 0
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Trigger* is ready with "M201 X500.000000 Y500.000000 Z35.000000 E250.000000" in state(s) 0 0, running macro
          Queue is idle in state(s) 0
          LCD is idle in state(s) 0
          SBC is idle in state(s) 0
          Daemon is idle in state(s) 0
          Aux2 is idle in state(s) 0
          Code queue is empty.
          === Network ===
          Slowest loop: 0.80ms; fastest: 0.01ms
          HTTP sessions: 0 of 8
          • Ethernet -
            State: disabled
            Error counts: 0 0 0 0 0
            === CAN ===
            Messages sent 0, longest wait 0ms for type 0
            === Linux interface ===
            State: 0, failed transfers: 0
            Last transfer: 19ms ago
            RX/TX seq numbers: 1464/12
            SPI underruns 0, overruns 0
            Number of disconnects: 0
            Buffer RX/TX: 584/804-0
            === Duet Control Server ===
            Duet Control Server v3.1.1
            Trigger:
            Buffered code: M208 X0 Y0 Z0 S1 ; set axis minima
            Buffered code: M208 X600 Y300 Z80 S0 ; set axis maxima
            Buffered code: ; Endstops
            Buffered code: M574 X1 S1 P"io3.in" ; configure active-high endstop for low end on X via pin io3.in
            Buffered code: M574 Y1 S1 P"io4.in" ; configure active-high endstop for low end on Y via pin io4.in
            Buffered code: M574 Z0 S1 ! P " i o 2 . i n "
            Buffered code: ; Z-Probe
            Buffered code: M558 P0 H0 F120 T4800 ; disable Z probe but set dive height, probe speed and travel speed
            Buffered code: M557 X15:215 Y15:195 S20 ; define mesh grid
            Buffered code: ; Heaters
            Buffered code: M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
            Buffered code: M950 H0 C"out0" T0 ; create bed heater output on out0 and map it to sensor 0
            Buffered code: M307 H0 B1 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit
            Buffered code: M140 H0 ; map heated bed to heater 0
            Buffered code: M143 H0 S120 ; set temperature limit for heater 0 to 120C
            Buffered code: M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
            ==> 920 bytes
            Executing macro config.g, started by system
          Next stack level
          Code buffer space: 2428
          Full transfers per second: 0.02
          7/24/2020, 10:34:59 AM Warning: Controller has been reset
          7/24/2020, 10:34:59 AM Connection to Duet established
          7/24/2020, 10:34:59 AM Warning: Lost connection to Duet (Board is not available (no header))
          7/24/2020, 10:34:58 AM Warning: Controller has been reset
            chrishornby
            Looks like it was the SD card. I made a new one (for the PI, not standalone) and now it all works.
            Not sure how to mark the post as solved, thanks for all your help!
            Chris
              A Former User @chrishornby
              @chrishornby said in Duet 3 + SBC Lost connection. No Header:
              https://forum.duet3d.com/topic/7773/forum-feature-mark-as-question-solved
                Glad you figured it out. I wouldn't have immediately thought of the SD card.
                  Do you still have the SD card that didn't work? My suspicion is that you had a bad command in config.g and the firmware was failing to catch the resulting exception. I'd like to fix that.
                  chrishornbyundefined 1 Reply Last reply Reply Quote 0
                    chrishornby
                    You are absolutely right, it was an error in config.g, I was setting up an end stop and the software advised me I had to reverse the pin, or something like that. I looked up how to do it and needed to put a "!" in front of the pin number. From memory it was something like
                    M587 Z0 S1 P"Io_2"
                    so I stuck the ! before the P like:
                    M587 Z0 S1 !P"I0_2"
                    this totally trashed the setup, how do I know? I did it again!
                    It should have been
                    M587 Z0 S1 P"!Io2"
                    Forgive me if the syntax is wrong but I am not a programmer, anyway it worked this way round!
                      chrishornby @chrishornby
                      @chrishornby ...and sorry, not got the card, I re-flashed it, but didn't need to do so as deleting one character in the config file would have fixed it!
                        chrishornby @dc42
                        @dc42 I am wondering whether you received my first board and whether you need a AOZ1284 as I have one in my possession
                          Phaedrux Moderator @chrishornby
                          I think DC42 is on vacation until next week.
                            chrishornby
                            thanks very much
