    New IR z probe issues
    IR Height Sensor
    3.7k
      Yes you'll need to modify your M557 command to keep the probe within the bed area bearing in mind the probe offset. That is to say, you need to position the nozzle so that the probe is in the right place.
      agent0810undefined 1 Reply Last reply Reply Quote 0
      • agent0810undefined
        agent0810 @Phaedrux
        @Phaedrux
        that is what my currently, what do you recommend changing it to?
          @agent0810 said in New IR z probe issues:
          G31 P500 X50 Y0 Z0.005 ; set Z probe trigger value, offset and trigger height
          Is that probe offset correct?
            agent0810 @Phaedrux
            @Phaedrux
            i believe so.
              https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
              https://duet3d.dozuki.com/Wiki/Using_mesh_bed_compensation#main
              To optimize the mesh size you'll need to subtract the offset from the full axis length so that you're only asking it to probe areas of the bed the probe can physically reach. Otherwise the firmware will just skip the areas that it can't get to.
              So if the probe is 50mm to the right of the nozzle, and the nozzle can only go to x0, then the probe can only reach x50. So that's the minimum on the X side for M557. Make sense?
                agent0810 @Phaedrux
                @Phaedrux
                the probe is on the left of the nozzle when im looking at it. so should it be -50?
                  @Phaedrux said in New IR z probe issues:
                  There's a really good method for measuring the offset described in there.
                    agent0810 @Phaedrux
                    Here is an easy way to measure the offset:
                    Tape down a piece of paper onto the bed.
                    Bring the nozzle down to the bed surface and lower it until the nozzle starts to depress into the paper, making a small impression.
                    Mark the impression with a marker tip to make it more visible.
                    Now jog X and Y until the probe is directly over the spot where the nozzle was.
                    Take the amount you jogged as your X and Y offset to use in G31.
                    i did exactly this step right here and got the 50, didnt think that since its to the left of the nozzle it would be -50.
                      That's kind of how the cartesian coordinate system used by 3d printers works.
                        Phaedrux Moderator @agent0810
                        I'll add a note about negative values there.
                          agent0810 @Phaedrux
                          @Phaedrux
                          sorry, just new to this and trying to take in a lot, im def a noob.
                          so would this be right:
                          M557 X-50:165 Y15:195 S20 ?
                            Not exactly. M557 defines the area of the bed you want probed, so negative values would mean outside of the bed area.
                            M557 X10:175 Y10:215 P8 Should probably work.
                            X175 because the probe can only reach 50mm away from the right edge of the bed which you've got defined as 225. So 225-50 = 175.
                            P8 means try to fit 8 points in both X and Y directions.
                            S20 you had before means space the points 20mm apart.
                            We're all noobs at some point.
                            agent0810undefined 2 Replies Last reply Reply Quote 0
                              agent0810 @Phaedrux
                              @Phaedrux
                              alright ill give that a shot. see what happens. thank you
                                agent0810 @Phaedrux
                                @Phaedrux
                                why do i get the feeling this isnt good lol
                                  Well it's a good start.
                                  The offset would likely be because the Z axis was homed with an endstop rather than the probe.
                                  It's actually getting quite difficult to navigate this thread since it's getting so long. Might I suggest creating a new thread with your new issues. Include your full config.g and homing files. The results of M122 never hurt to include either. Having all those details in the first post makes it a lot easier to refer to.
                                    agent0810 @Phaedrux
                                    @Phaedrux
                                    done. thank you again for all your help.
                                    https://forum.duet3d.com/topic/17871/issues-with-ir-probe-offset
                                    • Saurabhundefined
                                      Saurabh
                                      Hi @Phaedrux , Where can I get the kicad schematic file of Mini Height sensor board. I can see .png files of schematics and board on Github Here.
                                        Phaedrux Moderator @Saurabh
                                        @Saurabh Please start a new thread.
