    How to upgrade from 2.05.1 to 3.1.1?
    Firmware installation
    2.6k
    • zaptaundefined
      zapta @A Former User
      Thank you everybody for the response. I uploaded and applied the two zip files and now I think I am at 3.1.1 (still need to update config files)
      Board: Duet 2 WiFi (2WiFi)
      Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.1.1 (2020-05-19b2)
      Duet WiFi Server Version: 1.23
      I wonder about the files in the sys and www directories (list below), do I have a lot of leftover from previous versions or is it more or less what I should have? Can I delete anything?
      Alternatively, is there a way to install RRF3 from scratch? This upgrade requires a lot of manual work anyway so I don't mind a little bit more.
      www and sys content
      $ find www sys
      www
      www/css
      www/css/Lumen.theme.css.gz
      www/css/._Lumen.theme.css.gz
      www/css/Superhero.theme.css.gz
      www/css/._Superhero.theme.css.gz
      www/css/United.theme.css.gz
      www/css/._United.theme.css.gz
      www/css/Slate.theme.css.gz
      www/css/._Slate.theme.css.gz
      www/css/dwc.css.gz
      www/css/._dwc.css.gz
      www/css/bootstrap.theme.css.gz
      www/css/._bootstrap.theme.css.gz
      www/css/Sandstone.theme.css.gz
      www/css/._Sandstone.theme.css.gz
      www/css/app.ab1d3899.js.map.gz
      www/css/app.db918b7e.css.gz
      www/css/app.c3eac487.css.gz
      www/._css
      www/js
      www/js/dwc.js.gz
      www/js/._dwc.js.gz
      www/js/app.ab1d3899.js.map.gz
      www/js/app.ab1d3899.js.gz
      www/js/app.289e2336.js.map.gz
      www/js/app.289e2336.js.gz
      www/._js
      www/favicon.ico.gz
      www/._favicon.ico.gz
      www/reprap.htm.gz
      www/._reprap.htm.gz
      www/language.xml.gz
      www/._language.xml.gz
      www/fonts
      www/fonts/glyphicons.ttf.gz
      www/fonts/._glyphicons.ttf.gz
      www/fonts/glyphicons.woff2.gz
      www/fonts/._glyphicons.woff2.gz
      www/fonts/glyphicons.eot.gz
      www/fonts/._glyphicons.eot.gz
      www/fonts/glyphicons.svg.gz
      www/fonts/._glyphicons.svg.gz
      www/fonts/glyphicons.woff.gz
      www/fonts/._glyphicons.woff.gz
      www/fonts/materialdesignicons-webfont.27cb2cf1.woff2
      www/fonts/materialdesignicons-webfont.043774d1.woff
      www/fonts/materialdesignicons-webfont.9bfeb985.ttf.gz
      www/fonts/materialdesignicons-webfont.e971abae.eot.gz
      www/fonts/materialdesignicons-webfont.2dcce271.woff
      www/fonts/materialdesignicons-webfont.3e2c1c79.eot.gz
      www/fonts/materialdesignicons-webfont.a323c28e.woff2
      www/fonts/materialdesignicons-webfont.e7dec9c5.ttf.gz
      www/._fonts
      www/html404.htm
      www/._html404.htm
      www/dwc.json
      www/index.html.gz
      sys
      sys/stop.g
      sys/._stop.g
      sys/sleep.g
      sys/._sleep.g
      sys/DuetMaestroFirmware.bin
      sys/Duet2CombinedFirmware.bin
      sys/._Duet2CombinedFirmware.bin
      sys/resume.g
      sys/._resume.g
      sys/config.g
      sys/._config.g
      sys/retractprobe.g
      sys/._retractprobe.g
      sys/DuetWiFiServer.bin
      sys/._DuetWiFiServer.bin
      sys/homez.g
      sys/._homez.g
      sys/RepRapFirmware.bin
      sys/mode_normal.g
      sys/tpre0.g
      sys/._tpre0.g
      sys/tfree0.g
      sys/._tfree0.g
      sys/pause.g
      sys/._pause.g
      sys/bed.g
      sys/._bed.g
      sys/heightmap.csv
      sys/homey.g
      sys/._homey.g
      sys/homeall.g
      sys/._homeall.g
      sys/config_g.swp
      sys/homex.g
      sys/._homex.g
      sys/dwc2settings.json
      sys/tpost0.g
      sys/._tpost0.g
      sys/iap4s.bin
      sys/mode_stall.g
      sys/deployprobe.g
      sys/._deployprobe.g
      sys/iap4e.bin
      sys/filaments.csv
      sys/Duet3Firmware_EXP3HC.bin
      sys/Duet2CombinedIAP.bin
      sys/Duet3_SDiap_MB6HC.bin
      sys/DuetMaestroIAP.bin
      sys/Duet3Firmware_MB6HC.bin
      sys/Duet3Firmware_TOOL1LC.bin
        A Former User @zapta
        @zapta said in How to upgrade from 2.05.1 to 3.1.1?:
        you have at least 3 different versions of DWC, and a selection of binaries from old versions and different boards.
        simplest way to clean up DWC is to enable ftp or pull the SD card delete /www and replace with a freshly extracted DWC 3.1.1 (you may want to keep dwc.json as I believe some DWC settings are stored here)
        The only binaries you need are Duet2CombinedIAP.bin, Duet2CombinedFirmware.bin and DuetWiFiServer.bin
        the files that start with ._ seems redundant as well
        optionally clear out the SD card, get new config, RRF release and DWC from the config tool by selecting
        Get the latest stable Duet Web Control version and
        Get the latest stable RepRapFirmware version in the last step. you already have the firmware loaded in flash, so all that remains is the SD card that can be reconstructed from the files from the config tool.
        zaptaundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
        • zaptaundefined
          @bearer said in How to upgrade from 2.05.1 to 3.1.1?:
          optionally clear out the SD card...
          I cleared the SD card and repopulated. Does this file structure look right?
          $ find www sys
          www
          www/css
          www/css/._app.c3eac487.css.gz
          www/favicon.ico.gz
          www/fonts
          www/index.html.gz
          www/js
          sys
          sys/bed.g
          sys/config.g
          sys/config.json
          sys/deployprobe.g
          sys/homeall.g
          sys/homex.g
          sys/homey.g
          sys/homez.g
          sys/pause.g
          sys/resume.g
          sys/retractprobe.g
          sys/sleep.g
          sys/stop.g
          sys/tfree0.g
          sys/tpost0.g
          sys/tpre0.g
            Phaedrux Moderator @A Former User
            Lemme guess, opened the SD card on a Mac?
              looks good to me (https://duet3d.dozuki.com/Wiki/SD_Card is a little outdated with respect to RRF3.1.1)
              • zaptaundefined
                Thanks @bearer.
                I am now in the process of commissioning the various functionalities, one at a time. This will take some time.
                One problem I noticed is that when issue emergency stop from the PanelDue I get an error message like the one below (with a few other numbers, not just 255). The emergency stop work well otherwise, and when I issue it from DWC I don't see this message on the PanelDue.
                Any idea what it is? Never encounter it before with the older RRF. Upgrading PanelDue from 1.23.2 to 1.24 didn't help.
                Edit: my config files are here https://github.com/zapta/misc/tree/master/hevo/duet3 (still a work in progress)
                  Error: Bad command: 205
                  From the looks of it RRF thinks it receives a command 205 which isn't valid g-code.
                  I'd look over configs and triggers for syntax errors or linebreaks on the loose.
                  (just to verify, you're getting the same message on USB/WEB right?)
                  edit: cloned git and no results when grepping for 205 so thats odd. could you have gotten a bonus config-override.g that is misformatted? would be interesting to know if it comes before or after the e-stop (i.e. in config.g or not). I'd add some echo to the top and bottom of config.g and look at the USB console.
                  • zaptaundefined
                    Not getting it on the WEB, just on PanelDue when issuing the command from PanelDue. Didn't try the USB connection, will give it a try, including with planted messages.
                    BTW, I got also other codes, not just 255. E.g. 204, 44, 247 so I think it's at lower level than just bad gcode in a file.
                      Can you send M98 P"config.g" in the console and report any errors? I'm guessing that's where the bad command is coming from. It's showing up on the paneldue after an emergency stop because the board is up and running when you issue it and the paneldue is able to catch the error which otherwise might get missed on a cold boot.
                      • zaptaundefined
                        zapta @Phaedrux
                        @Phaedrux said in How to upgrade from 2.05.1 to 3.1.1?:
                        M98 P"config.g"
                        When I issue this command from the DWC I don't see the error message, just this which looks normal:
                        7/28/2020, 4:38:43 PM M98 P"config.g"
                        HTTP is enabled on port 80
                        FTP is enabled on port 21
                        TELNET is disabled
                        Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 262C
                        Warning: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 528C
                        I also hooked a logic analyze to the duet's tx/rx lines to the paneldue and it seems that it's the paneldue sends the bad command which results in the error message. Will try to describe it here, hopefully it's clear.
                        This is the dump from the logic analyzer. TX=duet->paneldue, RX=paneldue->duet.
                        capture.csv
                        At one point, after issuing the restart, the paneldue sends this and gets back the error 198 message. The actual number changes, not always 198.
                        Any idea what the problem is? Am I the only one that experience it?
                        1.179844000000000,RX,N (0x4E)
                        1.180016000000000,RX,1 (0x31)
                        1.180189000000000,RX,2 (0x32)
                        1.180361000000000,RX,0 (0x30)
                        1.180534000000000,RX,' ' (0x20)
                        1.180706000000000,RX,M (0x4D)
                        1.180879000000000,RX,1 (0x31)
                        1.181051000000000,RX,1 (0x31)
                        1.181224000000000,RX,2 (0x32)
                        1.181396000000000,RX,' ' (0x20)
                        1.181569000000000,RX,; (0x3B)
                        1.181741000000000,RX,'240' (0xF0)
                        1.181914000000000,RX,'15' (0x0F)
                        1.182086000000000,RX,* (0x2A)
                        1.182259000000000,RX,1 (0x31)     <---
                        1.182431000000000,RX,9 (0x39)     <---
                        1.182482000000000,TX,{
                        1.182604000000000,RX,8 (0x38)     <---
                        1.182656000000000,TX,"
                        1.182776000000000,RX,\n (0x0A)
                          was worried about when the bad commands varied and wasn't present in any file. does it do the same if you only connect power and no rx/tx to the paneldue?
                          • zaptaundefined
                            I will give it a try, assuming it will let me issue a Stop without being able to connect to the duet.
                            I think this is the relevant code, and it seems that the data the paneldue sends after the 0xf0 0x0f is corrupted.
                            https://github.com/Duet3D/PanelDueFirmware/blob/master/src/UserInterface.cpp#L1671
                              A Former User
                              Just don't see how updating RRF would affect the PanelDue firmware; interesting issue if nothing else:/
                              • zaptaundefined
                                One explanation is that the PanelDue behaved the same but RRF2 didn't detect and response to the bad command, for example if it took longer time to reboot. (this is a speculation). I may try to restore RRF2 and look again with the logic analyzer.
                                  4 wire or ribbon cable for the Panel?
                                  • zaptaundefined
                                    zapta @Phaedrux
                                    @Phaedrux , 4 wires.
                                      I might try a different 4 wire cable. I had some bad command and the panel being stuck on "connecting" occasionally and it turned out to be a bad 4 wire cable. I also braided the replacement since it runs along with some stepper wires. Haven't had an issue since.
                                      zaptaundefined 2 Replies Last reply Reply Quote 0
                                      • zaptaundefined
                                        zapta @Phaedrux
                                        The problem was very consistent. I just reverted my printer to RRF 2 and the problem disappeared. I will check tomorrow with logic analyzer if the transmission from the PanelDue is corrupted the same and possibly RRF2 is just more tolerant somehow.
                                        • zaptaundefined
                                          zapta @Phaedrux
                                          @Phaedrux, I use a logic analyzer to capture the duet/paneldue serial traffic under RRF2 and RRF3. In both cases the results are very consistent, with same hardware, same cables, etc, always works cleanly with RRF2 and always giving an error message with RRF3.]
                                          Looking at the capture signal, RRF3 behaves differently from RRF2. With RRF2, the duet lets the paneldue sending the entire M112 message with no response, with RRF3, the duet response immediately with an error message.
                                          https://github.com/Duet3D/PanelDueFirmware/blob/master/src/UserInterface.cpp#L1674
                                          This is how it looks under RRF2:
                                          And this is under RRF3
                                          This is from the rrf3.csv, it shows how the the duet response (TX) before the paneldue completes its transmision (RX):
                                          3.274821000000000,TX,1
                                          3.274994000000000,TX,}
                                          3.275168000000000,TX,\n
                                          3.476848000000000,RX,N (0x4E)
                                          3.477020000000000,RX,4 (0x34)
                                          3.477193000000000,RX,9 (0x39)
                                          3.477365000000000,RX,3 (0x33)
                                          3.477538000000000,RX,4 (0x34)
                                          3.477710000000000,RX,' ' (0x20)
                                          3.477883000000000,RX,M (0x4D)
                                          3.478055000000000,RX,1 (0x31)
                                          3.478228000000000,RX,1 (0x31)
                                          3.478400000000000,RX,2 (0x32)
                                          3.478573000000000,RX,' ' (0x20)
                                          3.478745000000000,RX,; (0x3B)
                                          3.478918000000000,RX,'240' (0xF0)
                                          3.479090000000000,RX,'15' (0x0F)
                                          3.479263000000000,RX,* (0x2A)
                                          3.479435000000000,RX,2 (0x32)
                                          3.479608000000000,RX,5 (0x35)
                                          3.479685000000000,TX,{   <<-- RRF3 doesn't like the M112 message
                                          3.479780000000000,RX,5 (0x35)
                                          3.479858000000000,TX,"
                                          3.479953000000000,RX,\n (0x0A)
                                          3.480032000000000,TX,s
                                          3.480205000000000,TX,e
                                          3.480378000000000,TX,q
                                          This is the corresponding section from RRF2:
                                          4.297585000000000,TX,1
                                          4.297759000000000,TX,}
                                          4.297932000000000,TX,\n
                                          5.048296000000000,RX,N (0x4E)
                                          5.048468000000000,RX,1 (0x31)
                                          5.048641000000000,RX,8 (0x38)
                                          5.048813000000000,RX,8 (0x38)
                                          5.048986000000000,RX,' ' (0x20)
                                          5.049158000000000,RX,M (0x4D)
                                          5.049331000000000,RX,1 (0x31)
                                          5.049503000000000,RX,1 (0x31)
                                          5.049676000000000,RX,2 (0x32)
                                          5.049848000000000,RX,' ' (0x20)
                                          5.050021000000000,RX,; (0x3B)
                                          5.050194000000000,RX,'240' (0xF0)
                                          5.050366000000000,RX,'15' (0x0F)
                                          5.050539000000000,RX,* (0x2A)
                                          5.050711000000000,RX,1 (0x31)
                                          5.050884000000000,RX,9 (0x39)
                                          5.051056000000000,RX,6 (0x36)
                                          5.051229000000000,RX,\n (0x0A)
                                          // 1 sec later, per the 1000ms in the source code
                                          6.050462000000000,RX,N (0x4E)
                                          6.050635000000000,RX,1 (0x31)
                                          6.050807000000000,RX,8 (0x38)
                                          6.050980000000000,RX,9 (0x39)
                                          6.051152000000000,RX,' ' (0x20)
                                          6.051325000000000,RX,M (0x4D)
                                          6.051497000000000,RX,9 (0x39)
                                          6.051670000000000,RX,9 (0x39)
                                          6.051842000000000,RX,9 (0x39)
                                          6.052015000000000,RX,* (0x2A)
                                          6.052187000000000,RX,4 (0x34)
                                          6.052360000000000,RX,2 (0x32)
                                          Any idea why the RRF3 doesn't like the M112 message and responds immediately instead of waiting for the M999 ?
                                          rrf2_capture.csv
                                          rrf3_capture.csv
                                            i think the 0xf0 0x0f is a special case to reset immediately without getting stuck in the queue; so the difference must be in how RRF3 reacts to this? time to put up the bat dc42 signal?
