    Controlling a Cetus3D with Duet3D 0.8.5
    61
    8.9k
    • Peter120undefined
      Peter120
      After a bunch of tuning I converged on a few variables that might be useful to others.
      I choose 256 micro stepping without interpolation. Extrusion steps for the original MK2 extruder mechanism that has a filament release lever is 1650 steps/mm. I also have the warranty replacement MK3 style but the prints were just not as good so I eventually repaired the original.
      The steps/mm is the iterative result is from a printing nuts and bolts sliced with prusa. It’s like a micrometer in that it measures the clearance between the printed nut and bolt threads. Measuring thread geometry is a good extrusion test and it quickly reveals temperature, layer height, filament brand, colour etc. all change the steps/mm. https://www.thingiverse.com/thing:3983705
      The axis motor currents can be 450ma any lower does not improve the print finish and at 475ma they start making noise.
      The extruder motor rotor is shorter and scaling the axis motor current you get a drive current of about 333ma. Any lower does not improve the print finish and higher adds an annoying minor washboard texture to the print surface.
      I find that with 0.1mm layers the washboard surface texture increases while it is very hard to see when printing with 0.15 and thicker layers.
      My 200W 24V silicone bed heater needed a lower duty cycle and higher PWM frequency to not trip the 120W Cetus AC adapter’s internal short detection circuit. M307 H0 B0 S0.45 F200 it heats to 55C at the same time as the nozzle get to 215C. The upper bed temperature is limited to the 80s and after a long warm up using the stock Cetus power supply.
      All in all a very satisfying conversion.
      -Peter
      skezoundefined 1 Reply Last reply Reply Quote 0
      • skezoundefined
        skezo @Peter120
        @Peter120
        Thanks for this information. Very helpful. I have been working on moving my Cetus MK2 to a Duet Maestro as well but running into issues with things like instantaneous speed changes and accelerations etc. What steps did you take to dial these numbers in?
        • Peter120undefined
          Peter120
          Motor acceleration settings are an accuracy vs vibration trade off and you just pick your poison. The stock Z axis on a Cetus shakes whenever the extruder accelerates. If you add a steel bracket and tie the Z stepper face to the aluminum base it improves dramatically. I upgraded to a 24V power supply and in the config.g below I turn off the steppers when the print finishes. If your Z axis brake/clutch slips fix or increase the stepper idle current so the extruder linear rail does not fall on the print!
          The belts have glass cords and they establish the printer motion accuracy together with the steppers so no calibration is even possible aside from axis tramming.
          ; ****** X&Y axis swapped May 6 2020 origin now front left
          M550 P"Duet" ; Set machine name
          M552 S1 ; Enable network
          M587 S"xxxxx" P"xxxxxxxxxxxx" ; Configure access point. You can delete this line once connected
          M586 P0 S1 ; Enable HTTP
          M586 P1 S0 ; Disable FTP
          M586 P2 S0 ; Disable Telnet
          M569 P0 S0 ; X Physical drive 0 goes backwards
          M569 P1 S1 ; Y Physical drive 1 goes forwards
          M569 P2 S1 ; Z Physical drive 2 goes forwards
          M569 P3 S1 ; E Physical drive 3 goes forwards
          M350 X256 Y256 Z256 E256 I0 ; Configure micro stepping with no interpolation
          M92 X1280.00 Y1280.00 Z1280.00 E1650 ; Set steps per mm, extruder calibrated white PLA
          M566 X900.00 Y900.00 Z900.00 E120.00 ; set maximum instantaneous speed changes (mm/min), speed threshold for executing next gcode move
          M203 X12000.00 Y12000.00 Z12000.00 E7000 ;E1200.00 ; Set maximum speeds (mm/min) about 200mm/s
          ;M201 X3200.00 Y7000.00 Z3200.00 E12000.00 ; Set accelerations (mm/s^2) for 1Kg,350gr,100gr X skipped a few steps
          M201 X1500.00 Y1500.00 Z1500.00 E1000.00 ; Set accelerations(mm/s^2)for 1Kg,350gr,100gr https://wilriker.github.io/maximum-acceleration-calculator/
          M906 X450.00 Y450.00 Z450.00 E400.00 I0 ; Set motor currents (mA) and motor idle factor in per cent, Z&Y steppers not quiet at 475ma PSU19.4V
          M84 S30 ; Set idle timeout
          M208 X190 Y191 Z277 S0 ; reversed X&Y axis May6 2020
          M574 X1 Y1 Z2 S0 ; reversed X&Y axis May6 2020 X low end, Y low end, Z high end, S0 endstop triggered active low Vout
          M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
          M557 X15:175 Y15:175 S20 ; define mesh grid
          M307 H0 B0 S0.66 F400 ; disable heater bed bang-bang mode set max PWM, up Hz, 120W peak with extruder heater Amps jumping around
          M305 P0 T50000 B2718 R4700 ; set thermistor + ADC parameters for heater 0 50K bed
          M143 H0 S122 ; set temperature limit for heater 0 to 122C
          M305 P1 X501 R47000 ; configure PT1000 for heater... per dc42 administrator suggestion with cetus PT100
          M143 H1 S285 ; set temperature limit for heater 1 to 285C ....can be 300C
          M106 P0 S0.25 I0 F500 H0 T45 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on bed
          M106 P1 S1 I0 F500 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on extruder
          ; Automatic power saving
          M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
          fotomasundefined skezoundefined 2 Replies Last reply Reply Quote 1
          • fotomasundefined
            fotomas @Peter120
            @Peter120
            I have designed a smal but effective bracket that supports the Z-axis on the Cetus.
            The fit may vary sepending on the version of Cetus and when it was manufactured.
            But it is pretty easy to draw one, if it does not fit.
            [https://www.thingiverse.com/thing:2712095]
            Peter120undefined 1 Reply Last reply Reply Quote 1
            • Peter120undefined
              Peter120 @fotomas
              @fotomas
              Thanks good tip.
              If you have some sheet metal capability, an excellent mod is a bracket to stabilize the nozzle cold end to the extruder. This reduces/eliminates any nozzle height change with extrusion pressure caused by filament temperature, layer thickness, filament retraction etc. Missing in my pic is a spacer washer between the cold end top and the printed part bottom.
              • skezoundefined
                skezo @Peter120
                @Peter120
                Many thanks for this. Going to test it out over the weekend.
                I notice you are not setting tpwmthrs on M569. Are you motors noisy?
                Peter120undefined 1 Reply Last reply Reply Quote 0
                • Peter120undefined
                  Peter120 @skezo
                  @skezo
                  I am no expert just hacked away until I was satisfied.
                  Switching between stepper driving modes has the potential of a slipped step so I decided to not test changing modes on the fly.
                  The steppers loudness changes depending on the commanded micro step (static) position. It sounds like white noise, my guess is the stepper winding is microphonic and the noise source is the TMC switching driver current. The bed behaves somewhat like a speaker so its stepper is the most noticeable sound. For totally silent printing I would plan on building a heated enclosure.
                  • skezoundefined
                    skezo @Peter120
                    @Peter120
                    Thanks again for the config file it has helped a lot. I think I am in a place now that I can start tuning and tweaking.
                    Do you have any recommendations on slicers?
                    • Peter120undefined
                      Peter120 @skezo
                      @skezo
                      Again no expert but all the slicers that I have tested have quirks.
                      The Tiertime software environment/slicer is good for beginners and a clever advanced user can work around most limitations. I briefly tested the beta Catfish slicer attempting to get around a bug. Finally reported the bug in detail but it was never fixed. They say Catfish will eventually generate Gcode for other printers but I have moved on.
                      A good friend who purchased a slicer says don't waste the money.
                      Tested Cura for two months and was disappointed.
                      Tested PrusaSlicer for many months. I like it well enough and continue to use it. It is not perfect but believe it currently has the most development momentum.
                      I design with fusion 360 but have only looked at the fusion 360 slicer. It has the great potential of using finite element analysts to tailor the infill for minimum weight with maximum strength. This is not something that I need but for industrial printed parts this feature would be a winner.
                      • skezoundefined
                        skezo @Peter120
                        @Peter120 thanks for the help. I have managed to get a few decent prints.
                        After running some test I now understand why the bracket to stabilize the nozzle cold end to the extruder mod would be excellent. I can see the nozzle lift considerably during the print.
                        Do you have any more photos or details you would be willing to share on how to set up this mod?
                        • Peter120undefined
                          Peter120
                          A quick simple build and not fancy, honestly it is a prototype that worked fine.
                          Made from scrap steel 1mm thick that I had laying around. It was cut to size with a hack saw then clamped in a vice and bent using a hammer. The bolts are long because I had them and the bracket is tapped for them. A cordless drill made all the holes. If the sheet metal were a bit thicker say 1.75mm the extra bends I made to stiffen the bracket would not be needed. I cut a 2mm wide slot to the top and bottom filament feed holes so the bracket can be removed to clean the filament drive gear. I used a bunch small washers stacked to make the spacer between the nozzle top to the extruder bottom and for convince glued them together.
                          Have fun.
