    Acceleration Speeds
    • NoSkillzEngineerundefined
      NoSkillzEngineer
      I believe this is M201 X1000 Y1000 Z1000
      What are recommended maximum travel settings?
      • elmoretundefined
        elmoret
        Depends entirely on motors/printer. Varies widely.
          T3P3Tony administrators
          You can play with the maximum settings until you see the motors start to skip steps, then back off from that maximum. Be aware that the movement is constrained by the slowest axis so if you are using a cartesian and command X100 Y100, starting from X0 Y0 then the axis with the slowest acceleration will dominate so that the move is coordinated.
            NoSkillzEngineer
            Okay, thank you. That should be enough to figure it out. Much appreciated.
