    Automatic Bed Leveling with Conditional Gcode Iterations
    Gcode meta commands
    6.5k
    • mwolterundefined
      mwolter
      Removed the following and added it to homeall.g since I typically do a home all before changing the bed.
      G1 Z{move.axes[2].userPosition+20} F1200		; move z up 20mm for magnetic bed replacement
      homeall.g
      ; homeall.g
      ; called to home all axes (G28)
      ; Warning: do not home individual axes by calling G28 X or G28 Y. It will cause errors. Instead run the macro file directly. IE M98 P"0:/sys/homex.g"
      M563 P9 S"HomeAll"		; create tool 9 to indicate homeall is in progress
      G91              		; relative positioning
      G1 Z5 F6000 H2   		; lift Z relative to current position
      M98 P"0:/sys/homey.g"	; home y
      M98 P"0:/sys/homex.g"	; home x
      G90             		; absolute positioning
      M98 P"0:/sys/homez.g"	; home z
      M563 P9 D-1 H-1			; delete tool 9 to indicate homeall is done
      G1 Z{move.axes[2].userPosition+50} F1200		; move z up 50mm for magnetic bed replacement
      • Kolbiundefined
        Kolbi
        Thanks @mwolter!
        For brevity, here is my final working version:
        ; bed.g
        ; Called to perform automatic bed compensation via G32
        M561                                                      ; Clear any bed transform
        G28                                                       ; Home
        while iterations <=1                                      ; Do minimum of 2 passes
           G30 P0 X25 Y100 Z-99999                                ; Probe near a leadscrew, half way along Y axis
           G30 P1 X235 Y100 Z-99999 S2                            ; Probe near a leadscrew and calibrate 2 motors
           G90
        while move.calibration.initial.deviation >= 0.002         ; perform additional tramming if previous deviation was over 0.002mm
           if iterations = 5                                      ; Perform 5 checks
              M300 S3000 P500                                     ; Sound alert, required deviation could not be achieved
              abort "!!! ABORTED !!! Failed to achieve < 0.002 deviation within 5 movements. Current deviation is " ^ move.calibration.initial.deviation ^ "mm."
           G90                                                    ; Back to absolute mode
        echo "Gantry deviation of " ^ move.calibration.initial.deviation ^ "mm obtained."
        G1 H2 Z8 F2600                                            ; Raise head 8mm to ensure it is above the Z probe trigger height
        G1 X104 Y100 F6000                                        ; Put head over the centre of the bed, or wherever you want to probe
        G30
        • fcwiltundefined
          fcwilt @mwolter
          @mwolter said in Automatic Bed Leveling with Conditional Gcode Iterations:
          @fcwilt Using that command I can be sure it raised 20mm from the previous height.
          Thanks for the reply.
          Why do you think G91 G1 Z20 doesn't do that same thing?
          mwolterundefined 1 Reply Last reply Reply Quote 0
          • mwolterundefined
            mwolter @fcwilt
            @fcwilt
            It’s just a different way of doing it and like I mentioned, this way I can be sure it’s raised 20mm from its current position. The G30 command actually sets Z to about 3m. So G1 Z20 will only raise Z by 17mm.
            • Kolbiundefined
              Kolbi @Phaedrux
              @Phaedrux said in Automatic Bed Leveling with Conditional Gcode Iterations:
              Now you're cooking with gas!
              Definitely cooking with gas now!
              • fcwiltundefined
                fcwilt @mwolter
                I think you will find that a G91 G1 Z20 will raise Z by 20 unless it doesn't have that much room left on the axis.
                If a G30 sets Z to 3 then a G91 G1 Z20 will take Z to 23.
                At least that is my experience.
                Good luck.
                mwolterundefined Phaedruxundefined 2 Replies Last reply Reply Quote 1
                • mwolterundefined
                  mwolter @fcwilt
                  This post is deleted!
                    Phaedrux Moderator @fcwilt
                    @fcwilt said in Automatic Bed Leveling with Conditional Gcode Iterations:
                    I think you will find that a G91 G1 Z20 will raise Z by 20 unless it doesn't have that much room left of the axis.
                    Correct. G90 moves to an absolute point, G91 is relative to the current position.
                    https://duet3d.dozuki.com/Wiki/Gcode#Section_G90_Set_to_Absolute_Positioning
                    mwolterundefined 1 Reply Last reply Reply Quote 1
                    • mwolterundefined
                      mwolter @Phaedrux
                      @Phaedrux If the command G90 G1 Z20 is used in one line, does G91 have to be used to return to absolute mode?
                      Phaedruxundefined A Former User? fcwiltundefined 3 Replies Last reply Reply Quote 1
                        Phaedrux Moderator @mwolter
                        @mwolter That's a good question, and I'm not sure off the top of my head. Would have to test to see if it sticks in that format or not.
                        • Kolbiundefined
                          Kolbi
                          Another thing I noticed is repeatability with PindaV2 probe is not as consistent as BLTouchV3.1... So being that I use a bondtech bmg mosquito, I've made this modified version to scrap the Pinda and welcome the BLTouch. Will get it sorted on the printer and test it fully this weekend.
                          • mwolterundefined
                            mwolter @Kolbi
                            @Kolbi looks good! Is that SLS or MJF printed?
                            Kolbiundefined 1 Reply Last reply Reply Quote 0
                            • Kolbiundefined
                              Kolbi @mwolter
                              @mwolter It was done on an HP Multijet Fusion (MJF), using Nylon PA12.
                                A Former User @mwolter
                                yes, g-code knows nothing about white space or line breaks
                                (optionally you can use push and pop, M120, M121)
                                Kolbiundefined 1 Reply Last reply Reply Quote 1
                                • fcwiltundefined
                                  fcwilt @mwolter
                                  G90 is absolute, G91 is relative.
                                  • mwolterundefined
                                    mwolter @fcwilt
                                    @fcwilt
                                    That’s why I used that command. Pulled that command from another macro and couldn’t remember why it was created. It’s used to move some amount from the current position without needing to bounce back and forth from absolute to relative and back to absolute positioning.
                                    • fcwiltundefined
                                      fcwilt @mwolter
                                      @fcwilt
                                      But there is no reason not to make use of the two positioning modes, there is no downside to using them.
                                      There is nothing to be gained by emulating relative mode using the object model as you are doing.
                                      • Kolbiundefined
                                        Kolbi @A Former User
                                        @bearer said in Automatic Bed Leveling with Conditional Gcode Iterations:
                                        @bearer I read the gcode manual but these two functions still made little sense to me - best I can derive is a save state / restore state? Could you expand a little on these and give me some use examples?
                                        Many thanks,
                                        Kolbi
                                          A Former User @Kolbi
                                          @Kolbi does https://forum.duet3d.com/topic/17854/retrieve-the-position-of-an-axis/5?_=1596130135808 help?
                                          • Kolbiundefined
                                            @bearer Maybe because I just woke or hadn't gone on my run yet - but it is not completely crystal clear to me. Given the example below:
                                            M120              ;push
                                            G0Z30             ; move Z 30mm
                                            M121              ;pop
                                            I gather that 'M120; push' saves the current kinematic control state, then the user issues G91 & G0Z30 to relatively move the Z axis, and then returns to the previous control state by issuing an M121 - meaning that no M90 command was needed as M121 sorted that out?
