    Automatic Bed Leveling with Conditional Gcode Iterations
    Gcode meta commands
    7.8k
    • mwolterundefined
      mwolter @fcwilt
      @fcwilt Using that command I can be sure it raised 20mm from the previous height. Probably overkill 🙂 It was a quick add before posting this and thought it would help with changing the magnetic bed but it makes for an odd extra movement of the bed between performing the homez and bed leveling. I'll rework the macros to utilize the virtual homeall tool to skip the unnecessary bed movement and update the macros above.
      • mwolterundefined
        mwolter @Kolbi
        @Kolbi There are too many spaces before the G30 commands and it would cause issues. Would recommend doing one leveling pass before the while command. I haven't tested the following code but it should be close.
        M561                                         ; clear any bed transform
        G28                                          ; home
        G30 P0 X25 Y100 Z-99999                      ; probe near a leadscrew, half way along Y axis
        G30 P1 X235 Y100 Z-99999 S2                  ; probe near a leadscrew and calibrate 2 motors
        echo "Bed Tramming Cycle: 1 - Difference was " ^ move.calibration.initial.deviation ^ "mm"
        while move.calibration.initial.deviation >= 0.01	; perform additional tramming if previous deviation was over 0.01mm
         if iterations = 5
          abort "Too many auto tramming attempts"
         echo "Bed Tramming Cycle: " ^ iterations + 2 ^ " - Difference was " ^ move.calibration.initial.deviation ^ "mm"
         continue
        G28 Z					; home z
        Kolbiundefined 1 Reply Last reply Reply Quote 0
        • Kolbiundefined
          Kolbi @mwolter
          @mwolter Thanks for covering my 6, I just caught that and was typing this:
          !!! Please see my final code, this is not correct !!!
          ; bed.g
          ; Called to perform automatic bed compensation via G32
          G28                                                     ; home
           if iterations = 5                                      ; perform 5 checks
            abort "!!!Failed to achieve < 0.01 deviation within 5 movements. Current deviation is " ^ move.calibration.initial.deviation ^ "mm."
           G90                                                    ; back to absolute mode
           echo "Gantry deviation of " ^ move.calibration.initial.deviation ^ "mm obtained within " ^ iterations + 2 ^ " tramming cycles."
           continue
          • Kolbiundefined
            Kolbi
            @mwolter I guess the trailing code is not a hard requirement? By trailing code I'm referring to this:
             continue
            mwolterundefined 1 Reply Last reply Reply Quote 0
            • mwolterundefined
              mwolter @Kolbi
              @Kolbi nope
              • mwolterundefined
                mwolter
                Removed the following and added it to homeall.g since I typically do a home all before changing the bed.
                G1 Z{move.axes[2].userPosition+20} F1200		; move z up 20mm for magnetic bed replacement
                homeall.g
                ; homeall.g
                ; called to home all axes (G28)
                ; Warning: do not home individual axes by calling G28 X or G28 Y. It will cause errors. Instead run the macro file directly. IE M98 P"0:/sys/homex.g"
                M563 P9 S"HomeAll"		; create tool 9 to indicate homeall is in progress
                G91              		; relative positioning
                G1 Z5 F6000 H2   		; lift Z relative to current position
                M98 P"0:/sys/homey.g"	; home y
                M98 P"0:/sys/homex.g"	; home x
                G90             		; absolute positioning
                M98 P"0:/sys/homez.g"	; home z
                M563 P9 D-1 H-1			; delete tool 9 to indicate homeall is done
                G1 Z{move.axes[2].userPosition+50} F1200		; move z up 50mm for magnetic bed replacement
                • Kolbiundefined
                  Kolbi
                  Thanks @mwolter!
                  For brevity, here is my final working version:
                  ; bed.g
                  M561                                                      ; Clear any bed transform
                  G28                                                       ; Home
                  while iterations <=1                                      ; Do minimum of 2 passes
                     G30 P0 X25 Y100 Z-99999                                ; Probe near a leadscrew, half way along Y axis
                     G30 P1 X235 Y100 Z-99999 S2                            ; Probe near a leadscrew and calibrate 2 motors
                     G90
                  while move.calibration.initial.deviation >= 0.002         ; perform additional tramming if previous deviation was over 0.002mm
                     if iterations = 5                                      ; Perform 5 checks
                        M300 S3000 P500                                     ; Sound alert, required deviation could not be achieved
                        abort "!!! ABORTED !!! Failed to achieve < 0.002 deviation within 5 movements. Current deviation is " ^ move.calibration.initial.deviation ^ "mm."
                     G90                                                    ; Back to absolute mode
                  echo "Gantry deviation of " ^ move.calibration.initial.deviation ^ "mm obtained."
                  G1 H2 Z8 F2600                                            ; Raise head 8mm to ensure it is above the Z probe trigger height
                  G1 X104 Y100 F6000                                        ; Put head over the centre of the bed, or wherever you want to probe
                  G30
                  • fcwiltundefined
                    fcwilt @mwolter
                    @mwolter said in Automatic Bed Leveling with Conditional Gcode Iterations:
                    Thanks for the reply.
                    Why do you think G91 G1 Z20 doesn't do that same thing?
                    • mwolterundefined
                      mwolter @fcwilt
                      @fcwilt
                      It’s just a different way of doing it and like I mentioned, this way I can be sure it’s raised 20mm from its current position. The G30 command actually sets Z to about 3m. So G1 Z20 will only raise Z by 17mm.
                      • Kolbiundefined
                        Kolbi @Phaedrux
                        @Phaedrux said in Automatic Bed Leveling with Conditional Gcode Iterations:
                        Now you're cooking with gas!
                        Definitely cooking with gas now!
                        • fcwiltundefined
                          fcwilt @mwolter
                          I think you will find that a G91 G1 Z20 will raise Z by 20 unless it doesn't have that much room left on the axis.
                          If a G30 sets Z to 3 then a G91 G1 Z20 will take Z to 23.
                          At least that is my experience.
                          Good luck.
                          mwolterundefined Phaedruxundefined 2 Replies Last reply Reply Quote 1
                          • mwolterundefined
                            mwolter @fcwilt
                            This post is deleted!
                              Phaedrux Moderator @fcwilt
                              @fcwilt said in Automatic Bed Leveling with Conditional Gcode Iterations:
                              I think you will find that a G91 G1 Z20 will raise Z by 20 unless it doesn't have that much room left of the axis.
                              Correct. G90 moves to an absolute point, G91 is relative to the current position.
                              https://duet3d.dozuki.com/Wiki/Gcode#Section_G90_Set_to_Absolute_Positioning
                              mwolterundefined 1 Reply Last reply Reply Quote 1
                              • mwolterundefined
                                mwolter @Phaedrux
                                @Phaedrux If the command G90 G1 Z20 is used in one line, does G91 have to be used to return to absolute mode?
                                Phaedruxundefined A Former User? fcwiltundefined 3 Replies Last reply Reply Quote 1
                                  Phaedrux Moderator @mwolter
                                  @mwolter That's a good question, and I'm not sure off the top of my head. Would have to test to see if it sticks in that format or not.
                                  • Kolbiundefined
                                    Kolbi
                                    Another thing I noticed is repeatability with PindaV2 probe is not as consistent as BLTouchV3.1... So being that I use a bondtech bmg mosquito, I've made this modified version to scrap the Pinda and welcome the BLTouch. Will get it sorted on the printer and test it fully this weekend.
                                    • mwolterundefined
                                      mwolter @Kolbi
                                      @Kolbi looks good! Is that SLS or MJF printed?
                                      • Kolbiundefined
                                        Kolbi @mwolter
                                        @mwolter It was done on an HP Multijet Fusion (MJF), using Nylon PA12.
                                          A Former User @mwolter
                                          yes, g-code knows nothing about white space or line breaks
                                          (optionally you can use push and pop, M120, M121)
                                          Kolbiundefined 1 Reply Last reply Reply Quote 1
                                          • fcwiltundefined
                                            fcwilt @mwolter
                                            G90 is absolute, G91 is relative.
