    Customising the splash screen
    PanelDue
    • Aitorundefined
      Aitor
      I am trying to change the main logo of my PanelDue-5i.
      I upload the firmware with the logo that I want to show in the PanelDue but I think something is wrong.
      • I use bmp2c-escher3d.exe myimage.bmp myimage.bin -b-c to compress the file, but is always 751kb, and the original is 13kb.
      • I also try to compress a white picture and also is 751kb.
      In both cases, when you combine firmware and logo, it is too heavy.
      I have also tried a combination with firmware copy / b PanelDue-5.0i-7.0i-nologo.bin + myimage.bmp PanelDueFirmware.bin, this was OK, 131kb, but when I upload it the logo does not appear.
      Must the logo have a special name? Something that i am doing wrong maybe?
      The picture of the logo is 800x480 pixel in format .bmp of 24bits.
      I use the commands with a .bat file.
      I made with other picture sizes and formats and the same problem.
        A Former User
        @Aitor said in Customising the splash screen:
        try dropping the colour depth significantly?
        • Simonjbundefined
          Simonjb
          Try making sure you have a space between the two command line switches
          bmp2c-escher3d.exe myimage.bmp myimage.bin -b -c and not -b-c.
          I have successfully converted a 1126kb 24 bit bmp file to a 106kb bin. My firmware bin after the binary copy is 224kb. The bmp file needs to have large blocks of colour. Too much detail will not convert successfully.
          I presume you are following the instructions on github for the PanelDue firmware.
          Anet A8 (lots of mods...). Hypercube Evolution with DuetWifi and 5" PanelDue
          Aitorundefined 1 Reply Last reply Reply Quote 1
          • Aitorundefined
            Aitor @Simonjb
            @Simonjb said in Customising the splash screen:
            Thank you so much. That was the problem, the space.
            It was driving me crazy
            Thanks a lot again!
            • Simonjbundefined
              Simonjb
              Glad I spotted it! Falling back on my original DOS 2 and 3 experience!
