    BL Touch flashes after homing z
    Firmware installation
    666
    • duttiundefined
      dutti
      hey,
      I can maka a normal homing z and after it, the BL isn´t working anymore. no m401 / m402( when pushed manually in). It is also flashing red... I can´t stop it.
      Sometimes it calls ´´already triggered´´ when trying G32
      Duet 3
      M303 H0 P1 S65
      Status
      Idle
      Mode: FFF
      Tool Position
      X
      35.0
      Y
      35.0
      Z
      232.60
      Extruder Drives
      Drive 0
      0.0
      Drive 1
      0.0
      Drive 2
      0.0
      Speeds
      Requested Speed
      0 mm/s
      Top Speed
      0 mm/s
      Sensors
      Vin
      24.0 V
      V12
      12.2 V
      MCU Temperature
      39.8 C
      Z-Probe
      1000
      Tools
      Extra
      Control All
      Tool Heater Current Active Standby
      Tool 0
      T0 - Load Filament Heater 1
      off 21.0 C
      0
      0
      Bed Heater 0
      active 20.8 C
      0
      0
      Temperature Chart
      Macros Directory
      sys
      0:/macros/sys/config.g
      ; generated by RepRapFirmware Configuration Tool v3.1.3 on Tue Jun 23 2020 22:36:44 GMT+0200 (Mitteleuropäische Sommerzeit)
      M550 P"Duet 3" ; set printer name
      M569 P0.4 S1 ; physical drive 0.4 goes forwards
      M569 P0.5 S1 ; physical drive 0.5 goes forwards
      M569 P1.0 S1 ; physical drive 1.0 goes forwards
      M569 P1.1 S1 ; physical drive 1.1 goes forwards
      M569 P1.2 S1 ; physical drive 1.2 goes forwards
      M584 X0.0 Y0.1 Z0.2:0.3:0.4:0.5 E1.0:1.1:1.2 ; set drive mapping
      M350 X16 Y16 Z16 E16:16:16:16:16:16 I1 ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z1600.00 E1600.00:1600.00:1600.00:92.70:92.70:92.70 ; set steps per mm
      M566 X900.00 Y900.00 Z12.00 E120.00:120.00:120.00:120.00:120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E3600.00:3600.00:3600.00:1200.00:1200.00:1200.00 ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z40.00 E250.00:250.00:250.00:250.00:250.00:250.00 ; set accelerations (mm/s^2)
      M906 X1200 Y1200 Z3000 E3000:3000:3000:1200:1200:1200 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X750 Y750 Z800 S0 ; set axis maxima
      M574 X2 S1 P"!io3.in" ; configure active-high endstop for high end on X via pin !io3.in
      M574 Y2 S1 P"!io0.in" ; configure active-high endstop for high end on Y via pin !io0.in
      M558 P9 C"io4.in" H15 F120 T1200 ; set Z probe type to bltouch and the dive height + speeds
      M950 S0 C"io4.out" ; create servo pin 0 for BLTouch
      G31 P500 X-20 Y-20 Z4 ; set Z probe trigger value, offset and trigger height
      M557 X15:650 Y15:650 S60 ; define mesh grid
      M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
      M307 H0 S1 ; disable bang-bang mode for the bed heater and set PWM limit
      M143 H0 S90 ; set temperature limit for heater 0 to 90C
      M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
      M950 F0 C"out3" Q500 ; create fan 0 on pin out3 and set its frequency
      M106 P0 S0.8 H-1 ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"out7" Q500 ; create fan 1 on pin out7 and set its frequency
      M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off
      M950 F2 C"out8" Q500 ; create fan 2 on pin out8 and set its frequency
      M106 P2 S1 H T45 ; set fan 2 value. Thermostatic control is turned on
      M671 X-12:92:92:-12 Y185:185:615:615 S4
      M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power
      deploy----------------------------
      ; deployprobe.g
      ; called to deploy a physical Z probe
      M280 P0 S10 ; deploy BLTouch
      retract.g--------------------------------
      ; retractprobe.g
      ; called to retract a physical Z probe
      M280 P0 S90 ; retract BLTouch
      homez.g-------------------------
      ; homez.g
      ; called to home the Z axis
      ; generated by RepRapFirmware Configuration Tool v3.1.3 on Thu Jun 25 2020 00:21:12 GMT+0200 (Mitteleuropäische Sommerzeit)
      G91 ; relative positioning
      G90 ; absolute positioning
      G1 X15 Y15 F6000 ; go to first probe point
      Duet Web Control 3.1.1
      • JoergS5undefined
        JoergS5 @dutti
        @barbarossa-cologne said in BL Touch flashes after homing z:
        I would check wiring first and whether the core has the right position (allen key on top of the BLtouch).
        I would change G31 P500 ... to P25.
        I don't know whether io4 needs a pullup resistor at the Duet3, in this case would be necessary to set the ^: M558 P9 C"^io4.in" H15 F120 T1200
        => I found an old thread where you need pullup for both M558 and M950:
        M950 S0 C"^io4.out"
        Probably nothing to do with the problem, but you have 3 mappings for E, but 6 values for E at the following settings.
        duttiundefined 1 Reply Last reply Reply Quote 0
          Using your pins in the configurator I get this:
          M558 P9 C"^io4.in" H5 F60 T6000                     ; set Z probe type to bltouch and the dive height + speeds
          G31 P25 X0 Y0 Z2.5                                   ; set Z probe trigger value, offset and trigger height
          So you may need the pullup ^ enabled on io4.in
          The other thing I notice is that your homez places the probe outside the bed if your G31 X Y offsets are correct.
          Also Z4 for a trigger height seems very high for the BLtouch.
          What is in your homeall?
          duttiundefined 2 Replies Last reply Reply Quote 0
          • JoergS5undefined
            JoergS5
            It was the thread https://forum.duet3d.com/topic/15823/duet-3-inverted-pull-up-inverted-pull-up where it was told that io4.in and io4.out should be pulled up with ^ with the Duet3.
            • duttiundefined
              dutti @JoergS5
              @JoergS5 said in BL Touch flashes after homing z:
              What do you mean with it and how can I change this?
              • duttiundefined
                dutti @Phaedrux
                This post is deleted!
                • duttiundefined
                  dutti @Phaedrux
                  • duttiundefined
                    dutti @JoergS5
                    @JoergS5
                    Yes.. thank you. But the problem is still, that the no touch flashes after doing a z probe. Z probe, but then I have to deconnect the cable and then it's working. M401 / M402.
                    Also after successfully probe the first point (G32) it's stopping,and it says ''z probe was not triggered during probing move''.
                    • JoergS5undefined
                      JoergS5 @dutti
                      @barbarossa-cologne it is some time ago, so I don't remember well.
                      First you should update to firmware 3.1.1, if you have an older version.
                      Then please make an image of the BLtouch 5-pin connector and the wiring on the Duet to check wiring.
                      In the meantime I know that
                      M558 P9 C"io4.in" H5 F60 T6000
                      doesn't need ^ because it already has pullup acticated automatically.
                        Post your homeall.g and bed.g please.
                        • duttiundefined
                          dutti @Phaedrux
                          Duet 3
                          g32
                          Status
                          Idle
                          Mode: FFF
                          Tool Position
                          X
                          35.0
                          Y
                          35.0
                          Z
                          -12.50
                          Extruder Drives
                          Drive 0
                          0.0
                          Drive 1
                          0.0
                          Drive 2
                          0.0
                          Speeds
                          Requested Speed
                          0 mm/s
                          Top Speed
                          0 mm/s
                          Sensors
                          Vin
                          24.0 V
                          V12
                          12.1 V
                          MCU Temperature
                          44.8 C
                          Z-Probe
                          0
                           Tools
                           Extra
                           Control All
                          Tool 0
                          off	25.9 C
                          0
                          0
                          Bed	Heater 0
                          fault	25.9 C
                          70
                          0
                          Temperature Chart
                          Macros Directory
                          sys
                          0:/macros/sys/homeall.g
                          ; homeall.g
                          ; called to home all axes
                          G1 H2 Z15 F2400       ; lift Z relative to current position
                          G1 H1 X805 Y805 F1200 ; move quickly to X and Y axis endstops and stop there (first pass)
                          G1 H2 X-5 Y-5 F2400   ; go back a few mm
                          G1 H1 X805 Y805 F360  ; move slowly to X and Y axis endstops once more (second pass)
                          G1 H1 Z-805 F360      ; move Z down stopping at the endstop
                          G92 Z0                ; set Z position to axis minimum (you may want to adjust this)
                          ;G91                  ; relative positioning
                          ;G1 Z15 F40           ; lift Z relative to current position
                          ;G90                  ; absolute positioning
                          • duttiundefined
                            dutti @Phaedrux
                            @Phaedrux
                            Duet 3
                            g32
                            Status
                            Idle
                            Mode: FFF
                            Tool Position
                            X
                            35.0
                            Y
                            35.0
                            Z
                            -12.50
                            Extruder Drives
                            Drive 0
                            0.0
                            Drive 1
                            0.0
                            Drive 2
                            0.0
                            Speeds
                            Requested Speed
                            0 mm/s
                            Top Speed
                            0 mm/s
                            Sensors
                            Vin
                            24.0 V
                            V12
                            12.1 V
                            MCU Temperature
                            44.8 C
                            Z-Probe
                            0
                             Tools
                             Extra
                             Control All
                            Tool 0
                            off	25.9 C
                            0
                            0
                            Bed	Heater 0
                            fault	25.9 C
                            70
                            0
                            Temperature Chart
                            Macros Directory
                            sys
                            0:/macros/sys/bed.g
                            ; bed.g
                            ; Called using G32
                            ; Called to perform True Autolevel using 4-point probe
                            G29 S3; Clear bed height map
                            ; Probe 4-point
                            G30 P0 X150 Y135 Z-9999 ; Front Right
                            G30 P1 X550 Y135 Z-9999 ; Front Left
                            G30 P2 X550 Y565 Z-9999 ; Back Left
                            G30 P3 X150 Y565 Z-9999 S4 ; Back Right
                              Let's try and keep it to a single thread please.
                              • duttiundefined
                                dutti
                                sorry
                                That was not my plan.....
                                • JoergS5undefined
                                  JoergS5 @dutti
                                  @barbarossa-cologne in the other thread you say firmware is 3.01 beta 9, you should update to 3.1.1 first before doing anything else.
