    G32 Error:´´ Z probe was not triggered during probing move´´
    Firmware installation
    4.7k
    • duttiundefined
      dutti @fcwilt
      @fcwilt
      for your question:
      • duttiundefined
        dutti @fcwilt
        @fcwilt something to do with this code in config.g?
        M558 P9 C"io4.in" H10 F200 T1800 ; set Z probe type to bltouch and the dive height + speeds
        M950 S0 C"io4.out" ; create servo pin 0 for BLTouch
        G31 P25 X-20 Y-20 Z2.5 ; set Z probe trigger value, offset and trigger height
        M557 X15:650 Y15:650 S200 ; define mesh grid
        • fcwiltundefined
          fcwilt
          Now we are getting somewhere I think.
          Notice on the left hand side you have MACROS selected.
          Is that correct?
          If so the files there are not the system files the firmware is using.
          Those file are in the SYSTEM directory - the item below the MACROS item.
          Select the SYSTEM item and take a look and see what is there.
          duttiundefined 1 Reply Last reply Reply Quote 1
          • duttiundefined
            dutti @fcwilt
            @fcwilt
            ahhhh I know what you mean.... at the systems page my bed.g is:
            ; bed.g
            ; generated by RepRapFirmware Configuration Tool v3.1.3 on Tue Jun 23 2020 22:36:44 GMT+0200 (Mitteleuropäische Sommerzeit)
            G29  ; probe the bed and enable compensation
            • fcwiltundefined
              fcwilt
              Well there is the G29 that G32 has been invoking.
              I think you have a problem with files being in the MACROS directory rather than the SYSTEM directory.
              You are going to have to determine if the some or all files in the MACROS directory need to be moved to the SYSTEMS directory.
              If the files in the SYSTEMS directory are the ones you want to keep you should delete the files in the MACROS directory that have the same name.
              For example - you should have homeall.g in your SYSTEMS directory. You should NOT have homeall.g in your MACROS directory.
              Think you can get this sorted out?
              • duttiundefined
                dutti
                yes.. I know. It was stupid....
                Now I took every code into the systems page.
                Now, I have the message ´´failed to enable endstops´´when I make a single z probe. 😞
                • duttiundefined
                  dutti
                  M550 P"Duet 3" ; set printer name
                  M569 P0.4 S1 ; physical drive 0.4 goes forwards
                  M569 P0.5 S1 ; physical drive 0.5 goes forwards
                  M569 P1.0 S1 ; physical drive 1.0 goes forwards
                  M569 P1.1 S1 ; physical drive 1.1 goes forwards
                  M569 P1.2 S1 ; physical drive 1.2 goes forwards
                  M584 X0.0 Y0.1 Z0.2:0.3:0.4:0.5 E1.0:1.1:1.2 ; set drive mapping
                  M350 X16 Y16 Z16 E16:16:16:16:16:16 I1 ; configure microstepping with interpolation
                  M92 X80.00 Y80.00 Z1600.00 E1600.00:1600.00:1600.00:92.70:92.70:92.70 ; set steps per mm
                  M566 X900.00 Y900.00 Z12.00 E120.00:120.00:120.00:120.00:120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
                  M203 X6000.00 Y6000.00 Z180.00 E3600.00:3600.00:3600.00:1200.00:1200.00:1200.00 ; set maximum speeds (mm/min)
                  M201 X500.00 Y500.00 Z40.00 E250.00:250.00:250.00:250.00:250.00:250.00 ; set accelerations (mm/s^2)
                  M906 X1200 Y1200 Z3000 E3000:3000:3000:1200:1200:1200 I30 ; set motor currents (mA) and motor idle factor in per cent
                  M84 S30 ; Set idle timeout
                  M208 X700 Y700 Z800 S0 ; set axis maxima
                  M574 X2 S1 P"!io3.in" ; configure active-high endstop for high end on X via pin !io3.in
                  M574 Y2 S1 P"!io0.in" ; configure active-high endstop for high end on Y via pin !io0.in
                  M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
                  M307 H1 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit
                  M143 H0 S90 ; set temperature limit for heater 0 to 90C
                  M308 S1 P"temp1" Y"thermistor" T100000 B4138                                     ; configure sensor 1 as thermistor on pin temp1
                  M950 H1 C"out1" T1                                                               ; create nozzle heater output on out1 and map it to sensor 1
                  M307 H1 B0 S1.00        ; disable bang-bang mode for heater  and set PWM limit
                  M950 F0 C"out3" Q500 ; create fan 0 on pin out3 and set its frequency
                  M106 P0 S0.8 H-1 ; set fan 0 value. Thermostatic control is turned off
                  M950 F1 C"out7" Q500 ; create fan 1 on pin out7 and set its frequency
                  M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off
                  M950 F2 C"out8" Q500 ; create fan 2 on pin out8 and set its frequency
                  M106 P2 S1 H T45 ; set fan 2 value. Thermostatic control is turned on
                  M671 X-12:92:92:-12 Y185:185:615:615 S2.5
                  M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power
                  deploy----------------------------
                  ; deployprobe.g
                  ; called to deploy a physical Z probe
                  M280 P0 S10 ; deploy BLTouch
                  retract.g--------------------------------
                  ; retractprobe.g
                  ; called to retract a physical Z probe
                  M280 P0 S90 ; retract BLTouch
                  homez.g-------------------------
                  ; homez.g
                  ; called to home the Z axis
                  ; generated by RepRapFirmware Configuration Tool v3.1.3 on Thu Jun 25 2020 00:21:12 GMT+0200 (Mitteleuropäische Sommerzeit)
                  G91 ; relative positioning
                  G90 ; absolute positioning
                  G1 X15 Y15 F6000 ; go to first probe point
                  • fcwiltundefined
                    fcwilt @dutti
                    @barbarossa-cologne
                    Did you overwrite any files already in the SYSTEMS directory that were the correct ones?
                    For example if you moved a file config.g and overwrote the config.g file already in the SYSTEMS directory the file you moved may not be correct.
                    • fcwiltundefined
                      fcwilt
                      Hi again.
                      The config.g file you just posted - does it seem to be correct?
                      At the bottom there is the word "deploy" which is not a valid command.
                      duttiundefined 2 Replies Last reply Reply Quote 0
                      • duttiundefined
                        dutti @fcwilt
                        @fcwilt
                        I don´t know if it´s correct. In general I used the configuration tool.. Only the option for true auto leveling I manaully placed in the g.codes. I have 4 z axis..
                        That´s my first printer and up to now (since one month) nobody could help me that much, that I can start print. It is sad and I´m a bloody beginner with a big printer 😕
                        • duttiundefined
                          dutti @fcwilt
                          @fcwilt
                          the word ´´deploy´´ and everything around it in the g.code is made by the configuration tool of!!!! how can it be wrong?
                          • fcwiltundefined
                            fcwilt @dutti
                            @barbarossa-cologne said in G32 Error:´´ Z probe was not triggered during probing move´´:
                            @fcwilt
                            I don't know. I've only used the config tool one and that was to generate a basic printer file for my kind of printer.
                            Then I looked at the generated code to learn how v3 firmware does things.
                            Then I edited my v2 files to meet the requirements of v3 firmware.
                            Not to worry - we determined the basic problem - your files were a bit messed up.
                            Do you know who to select all files in the SYSTEMS directory and use the "Download as ZIP" feature to get all of the files into a single ZIP file?
                            If you know how to do that do so and post the ZIP file here. I will download it and examine the files.
                            That will take a while so I won't be able to get right back to you.
                            duttiundefined 3 Replies Last reply Reply Quote 0
                            • duttiundefined
                              dutti @fcwilt
                              @fcwilt
                              I can´t send the zip here, rigth?
                              There comes a message with ´´invalid file type´´
                              • duttiundefined
                                dutti @fcwilt
                                config-override.g config.g bed.g tpre0.g tpost0.g tfree0.g stop.g sleep.g retractprobe.g resume.g pause.g homez.g homey.g homex.g homeall.g deployprobe.g
                                • duttiundefined
                                  dutti @fcwilt
                                  @fcwilt
                                  Thanks a lot!!!!!! and take your time.
                                  • fcwiltundefined
                                    fcwilt @dutti
                                    @fcwilt
                                    I will try to look at them tonight after dinner on in the morning.
                                    However I have to assist my wife who is having surgery on Wednesday and I will be with her from noon Tuesday until Thursday or Friday.
                                    duttiundefined 1 Reply Last reply Reply Quote 0
                                    • duttiundefined
                                      dutti @fcwilt
                                      @fcwilt
                                      No stress. take your time.
                                      Maybe you´ll first find out whats causing the ´´Error: Failed to enable endstops´´.
                                      But take your time. Your family is more important! 🙂
                                      Guten Appetit!
                                        I'll try to catch up on this thread later today/tomorrow.
                                        fcwiltundefined duttiundefined 2 Replies Last reply Reply Quote 0
                                        • fcwiltundefined
                                          fcwilt @Phaedrux
                                          @Phaedrux said in G32 Error:´´ Z probe was not triggered during probing move´´:
                                          Thanks. I might not have time.
                                          I suspect that it is just a question of errors in the files.
                                          A quick check of config.g showed some garbage at the end.
                                          • duttiundefined
                                            dutti @Phaedrux
                                            @Phaedrux Thanks and no stress.
                                            I´m not the only one who needs help.
