    Why use a Raspberry Pi with a Duet 3?
    68
    8.8k
    • chrishammundefined
      chrishamm administrators
      M20 and M36 are already implemented in DSF (including emulation support). So what I'd like to do in the future is to move the whole SBC interface in the firmware to a separate task and to send all but a few certain codes (like M112/M999) from RRF to DSF for further processing. So when you execute a code from serial USB or PanelDue, DSF would process it in the first place and return a proper response where applicable.
      @spllg cancel.g isn't processed yet because that macro file is optional and followed by a request to stop.g. So currently stop.g overrides the first macro request. I'll fix this bug in the firmware soon - probably when the Linux interface has been moved to its own task.
      Duet software engineer
      oozeBotundefined 1 Reply Last reply Reply Quote 2
      • oozeBotundefined
        oozeBot @chrishamm
        @chrishamm
        Thank you for looking into this. I understand the Duet 3 is quite new - I was just afraid to move forward with the Duet3+RPi combo if the PanelDue would have limitations. I feel the functionality provided by the PanelDue is the correct amount for direct control at the printer (with the addition of macros and jobs, etc). The web interface can be used standalone for the rest.. I did not want to go down the road of adding a monitor to the RPi as that adds complexity we do not want to support.
        If you need/want anyone to help you beta test any changes around this, please let me know.
        • zaptaundefined
          zapta @dc42
          @dc42 said in Why use a Raspberry Pi with a Duet 3?:
          In my office, with good WiFi signal strength, I get around 800kbytes/sec to both Duet WiFi and Duet Ethernet, if CRC checking is disabled.
          I am getting about 250KiB/s. Doesn't help if I move the computer and printer near the wifi router. This is with default settings. I am not familiar with the CRC settings and its implication on data integrity. Will search for it.
          Waiting a few more seconds should not be a problem except that Prusa Slicer times out on larger files so I need to transfer them 'manually' via DWC.
          • garyd9undefined
            garyd9 @dc42
            If this is important, I think the real answer is to implement a call from RRF to the Pi to get the list of files in a folder, so that RRF can implement M20. I don't think it should be hard. If M36 was implemented in the same way then it would also be possible to start print jobs from PanelDue.
            I just would like to add my positive vote for this. It would give much more flexibility in setting up duet 3 boards.
            While it's possible to run both HDMI and USB cables to a small screen, the simple fact is that the wiring for the PanelDue is much smaller. There's also the fact that the PanelDue UI is a mature, well designed, simple small screen touch interface that's proven.
            • spllgundefined
              spllg @garyd9
              @garyd9 apparently one of these tiny chinese hands which are capable of handling smallest screws at hidden places.
              • garyd9undefined
                garyd9
                Perhaps I'm over-simplifying, but...
                Is it correct that the PanelDue just uses serial communication with the duet board? Is it also correct that the PanelDue just uses gcode commands and responses to display data and take actions (in a manner very similar to how DWC works)?
                If so, would it be possible to just connect the PanelDue directly to the SBC and add serial code support to the daemon on the SBC?
                dc42undefined A Former User? 2 Replies Last reply Reply Quote 0
                  dc42 administrators @garyd9
                  @garyd9 said in Why use a Raspberry Pi with a Duet 3?:
                  If so, would it be possible to just connect the PanelDue to the SBC and add serial code support to the daemon on the SBC?
                  Yes. But we plan to change RRF to send file-related commands received locally by the Duet to the Pi anyway.
                    A Former User @garyd9
                    No need to add anything. Search forum for socat
                    • BeosDocundefined
                      BeosDoc
                      I've been trying to justify using rPi with Duet3 myself, and its not the cost :-). If you want wifi, you can always use a router in bridge mode and plug Duet3 into it.
                      Using rPi I see as have a few concerns: It's adds another possible point of failure. Maybe needing additional cooling, not to mention the extra space needed in the box for the board. What about power? rPi is a computer and should be shutdown properly. If you turn the power supply off you also cut power to rPi, or you have it setup another separate power supply to keep it running. Or you have to do a lot of rigging to have the rPi shut down properly then shutting off the noisy power supply.
                      It's nice that it's easier to update the system. If you have a spare rPi laying around doing nothing, then maybe or you want to experiment. You can always add one later on down the road. I don't foresee anything coming down the pike, as a plugin, for a long time. So far I haven't even seen anyone with a great idea for a plugin and I can't think of any except maybe display the model that's in the stl file(s).
                        A Former User
                        In the near term it offers greater choice in touch screen interfaces and easier customization of the touch interaface compared to the PanelDue.
                        BeosDocundefined 2 Replies Last reply Reply Quote 0
                        • BeosDocundefined
                          BeosDoc @A Former User
                          @bearer
                          I'm using an iPad and I can walk away from the printer and still have control 😄 . PanelDue I manly use to home or to remove filament, which I could do on the iPad too, just a matter of convenience.
                          • BeosDocundefined
                            @bearer
                            Unless your telling me it has a better and more information on the web interface on the rPi then it does on the duet3
                              A Former User @BeosDoc
                              @BeosDoc said in Why use a Raspberry Pi with a Duet 3?:
                              @bearer
                              If the PanelDue servers your needs then it clearly doesn't apply to you. But for printer manufacturerse etc that want to customzie things the rPi makes it easier.
                              Using an iPad has all the downsides of the rPi at a greater cost less the customization options. But again, if it servers your needs, then you're all good.
                              @bearer
                              Again, if you don't want to customize what is available on the PanelDue and DuetWebControl then no; but for CNC users something like DueUi greatly simplifies tailoring the interface to CNC use etc.
                              edit: actually some users have been rather keen to adopt using Rapsberry Pi with existing Duet 2 to improve the upload speed, and my limited testing shows a significant difference. Unsure how Duet3 stand alone uploads compare as i never tired but I recon there is yet room for improvement.
                              • Dad003undefined
                                Dad003
                                ive been running my duet 3 in standalone so far , i have a extra rooter so my duet has it own lan network that i can access via my PC or my phone when him at home , thinking in the future to maybe use a cheap tablet for it as well ,
