    Why use a Raspberry Pi with a Duet 3?
    68
    8.8k
    • oozeBotundefined
      oozeBot @dc42
      @dc42 @bearer I did some more experimenting with placing macros onto the Duet's SD card. It turns out that all that is needed is an empty file that is named exactly as the macro in the RPI's macro folder.. when selecting the macros from the PanelDue, it is directly calling the copy on the RPI.
      I recognize the Duet would have no way of getting the required info from the RPi, but would the RPi have knowledge of the Duet's SD card? If so, I'd think it would be trivial to sideload a copy (or null file) to the Duet's SD card..
      One other observation is that something I've done has made the macros stop showing up on the right hand side of the Control tab of the PanelDue - they are only accessible from the Macro tab. Any thoughts?
        I ordered this screen. Seems similar to the one Danal posted, and was reasonably priced in Canada.
        https://www.amazon.ca/gp/product/B07ZH6L9L4/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
        garyd9undefined 1 Reply Last reply Reply Quote 0
        • garyd9undefined
          garyd9 @Phaedrux
          @Phaedrux said in Why use a Raspberry Pi with a Duet 3?:
          Pretty far off topic, but I followed that link and immediately started laughing. Considering it's showing a 7 inch diagonal screen, how tiny is the hand in the picture?
          Phaedruxundefined spllgundefined 2 Replies Last reply Reply Quote 1
            Phaedrux Moderator @garyd9
            @garyd9 I know, right?!
              dc42 administrators @oozeBot
              @gfisher said in Why use a Raspberry Pi with a Duet 3?:
              If this is important, I think the real answer is to implement a call from RRF to the Pi to get the list of files in a folder, so that RRF can implement M20. I don't think it should be hard. If M36 was implemented in the same way then it would also be possible to start print jobs from PanelDue.
              Have you tried resetting the PanelDue?
              oozeBotundefined garyd9undefined 2 Replies Last reply Reply Quote 0
              • oozeBotundefined
                oozeBot @dc42
                @dc42 said in Why use a Raspberry Pi with a Duet 3?:
                I agree - everything else is just a hack. We are in the process of evaluating the integration of the Duet 3 / PanelDue into our next generation of printers. This has been a stumbling block and was the reason for my original question. I would like to move forward with the RPi+Duet3 combo, but need some level of assurance that the the PanelDue will be able to become fully functional as it is with your other products.
                Do you want me to submit this as an enhancement request in some way? For clarity, after your explanation, yes - I'd like to see both M20 and M36 implemented.
                Thank you for your consideration..
                • chrishammundefined
                  chrishamm administrators
                  M20 and M36 are already implemented in DSF (including emulation support). So what I'd like to do in the future is to move the whole SBC interface in the firmware to a separate task and to send all but a few certain codes (like M112/M999) from RRF to DSF for further processing. So when you execute a code from serial USB or PanelDue, DSF would process it in the first place and return a proper response where applicable.
                  @spllg cancel.g isn't processed yet because that macro file is optional and followed by a request to stop.g. So currently stop.g overrides the first macro request. I'll fix this bug in the firmware soon - probably when the Linux interface has been moved to its own task.
                  Duet software engineer
                  oozeBotundefined 1 Reply Last reply Reply Quote 2
                  • oozeBotundefined
                    oozeBot @chrishamm
                    @chrishamm
                    Thank you for looking into this. I understand the Duet 3 is quite new - I was just afraid to move forward with the Duet3+RPi combo if the PanelDue would have limitations. I feel the functionality provided by the PanelDue is the correct amount for direct control at the printer (with the addition of macros and jobs, etc). The web interface can be used standalone for the rest.. I did not want to go down the road of adding a monitor to the RPi as that adds complexity we do not want to support.
                    If you need/want anyone to help you beta test any changes around this, please let me know.
                    • zaptaundefined
                      zapta @dc42
                      In my office, with good WiFi signal strength, I get around 800kbytes/sec to both Duet WiFi and Duet Ethernet, if CRC checking is disabled.
                      I am getting about 250KiB/s. Doesn't help if I move the computer and printer near the wifi router. This is with default settings. I am not familiar with the CRC settings and its implication on data integrity. Will search for it.
                      Waiting a few more seconds should not be a problem except that Prusa Slicer times out on larger files so I need to transfer them 'manually' via DWC.
                      • garyd9undefined
                        garyd9 @dc42
                        I just would like to add my positive vote for this. It would give much more flexibility in setting up duet 3 boards.
                        While it's possible to run both HDMI and USB cables to a small screen, the simple fact is that the wiring for the PanelDue is much smaller. There's also the fact that the PanelDue UI is a mature, well designed, simple small screen touch interface that's proven.
                        • spllgundefined
                          spllg @garyd9
                          @garyd9 apparently one of these tiny chinese hands which are capable of handling smallest screws at hidden places.
                          • garyd9undefined
                            garyd9
                            Perhaps I'm over-simplifying, but...
                            Is it correct that the PanelDue just uses serial communication with the duet board? Is it also correct that the PanelDue just uses gcode commands and responses to display data and take actions (in a manner very similar to how DWC works)?
                            If so, would it be possible to just connect the PanelDue directly to the SBC and add serial code support to the daemon on the SBC?
                            dc42undefined A Former User? 2 Replies Last reply Reply Quote 0
                              dc42 administrators @garyd9
                              @garyd9 said in Why use a Raspberry Pi with a Duet 3?:
                              If so, would it be possible to just connect the PanelDue to the SBC and add serial code support to the daemon on the SBC?
                              Yes. But we plan to change RRF to send file-related commands received locally by the Duet to the Pi anyway.
                                A Former User @garyd9
                                No need to add anything. Search forum for socat
                                • BeosDocundefined
                                  BeosDoc
                                  I've been trying to justify using rPi with Duet3 myself, and its not the cost :-). If you want wifi, you can always use a router in bridge mode and plug Duet3 into it.
                                  Using rPi I see as have a few concerns: It's adds another possible point of failure. Maybe needing additional cooling, not to mention the extra space needed in the box for the board. What about power? rPi is a computer and should be shutdown properly. If you turn the power supply off you also cut power to rPi, or you have it setup another separate power supply to keep it running. Or you have to do a lot of rigging to have the rPi shut down properly then shutting off the noisy power supply.
                                  It's nice that it's easier to update the system. If you have a spare rPi laying around doing nothing, then maybe or you want to experiment. You can always add one later on down the road. I don't foresee anything coming down the pike, as a plugin, for a long time. So far I haven't even seen anyone with a great idea for a plugin and I can't think of any except maybe display the model that's in the stl file(s).
                                    A Former User
                                    In the near term it offers greater choice in touch screen interfaces and easier customization of the touch interaface compared to the PanelDue.
                                    BeosDocundefined 2 Replies Last reply Reply Quote 0
                                    • BeosDocundefined
                                      BeosDoc @A Former User
                                      @bearer
                                      I'm using an iPad and I can walk away from the printer and still have control 😄 . PanelDue I manly use to home or to remove filament, which I could do on the iPad too, just a matter of convenience.
                                      • BeosDocundefined
                                        @bearer
                                        Unless your telling me it has a better and more information on the web interface on the rPi then it does on the duet3
                                          A Former User @BeosDoc
                                          @BeosDoc said in Why use a Raspberry Pi with a Duet 3?:
                                          @bearer
                                          If the PanelDue servers your needs then it clearly doesn't apply to you. But for printer manufacturerse etc that want to customzie things the rPi makes it easier.
                                          Using an iPad has all the downsides of the rPi at a greater cost less the customization options. But again, if it servers your needs, then you're all good.
                                          @bearer
                                          Again, if you don't want to customize what is available on the PanelDue and DuetWebControl then no; but for CNC users something like DueUi greatly simplifies tailoring the interface to CNC use etc.
                                          edit: actually some users have been rather keen to adopt using Rapsberry Pi with existing Duet 2 to improve the upload speed, and my limited testing shows a significant difference. Unsure how Duet3 stand alone uploads compare as i never tired but I recon there is yet room for improvement.
                                          • Dad003undefined
                                            Dad003
                                            ive been running my duet 3 in standalone so far , i have a extra rooter so my duet has it own lan network that i can access via my PC or my phone when him at home , thinking in the future to maybe use a cheap tablet for it as well ,
