    G32 Error:´´ Z probe was not triggered during probing move´´
    Firmware installation
    4.7k
    • duttiundefined
      dutti @fcwilt
      @fcwilt
      I can´t send the zip here, rigth?
      There comes a message with ´´invalid file type´´
      • duttiundefined
        dutti @fcwilt
        config-override.g config.g bed.g tpre0.g tpost0.g tfree0.g stop.g sleep.g retractprobe.g resume.g pause.g homez.g homey.g homex.g homeall.g deployprobe.g
        • duttiundefined
          dutti @fcwilt
          @fcwilt
          Thanks a lot!!!!!! and take your time.
          • fcwiltundefined
            fcwilt @dutti
            @barbarossa-cologne said in G32 Error:´´ Z probe was not triggered during probing move´´:
            @fcwilt
            I will try to look at them tonight after dinner on in the morning.
            However I have to assist my wife who is having surgery on Wednesday and I will be with her from noon Tuesday until Thursday or Friday.
            duttiundefined 1 Reply Last reply Reply Quote 0
            • duttiundefined
              dutti @fcwilt
              @fcwilt
              No stress. take your time.
              Maybe you´ll first find out whats causing the ´´Error: Failed to enable endstops´´.
              But take your time. Your family is more important! 🙂
              Guten Appetit!
                I'll try to catch up on this thread later today/tomorrow.
                fcwiltundefined duttiundefined 2 Replies Last reply Reply Quote 0
                • fcwiltundefined
                  fcwilt @Phaedrux
                  @Phaedrux said in G32 Error:´´ Z probe was not triggered during probing move´´:
                  Thanks. I might not have time.
                  I suspect that it is just a question of errors in the files.
                  A quick check of config.g showed some garbage at the end.
                  • duttiundefined
                    dutti @Phaedrux
                    @Phaedrux Thanks and no stress.
                    I´m not the only one who needs help.
                      Phaedrux Moderator @dutti
                      Ok, I've got caught up. Thanks very much to @fcwilt for all the troubleshooting. Well done. Turned out it was a case of the old config files in the wrong place.
                      So let's start from the top and see if we can get things up and running finally.
                      Duet 3 MB6HC version 3.01-RC9
                      You should update the firmware before we go any further.
                      Download this zip file and upload it AS IS to the /sys folder in DWC. Do not extract it.
                      https://github.com/Duet3D/RepRapFirmware/releases/download/3.1.1/Duet2and3Firmware-3.1.1.zip
                      It should detect the firmware upload and install it. After it will reboot. Then send M115 in the gcode console to verify that it was successfully applied.
                      As for the config files, I think you should go through the config tool and create a fresh set of config files. Try and choose everything as accurately as possible. Then download the config zip file and upload it to the /sys folder as is as well. That should place your new config set in the correct place.
                      https://configtool.reprapfirmware.org/Start
                      Also upload those files here so that we can double check them.
                      Please provide the following details here as well so that we can compare to what is in the config.
                      How big is the printer area?
                      What kind of endstops do you have?
                      Where are the endstops located on the printer and where are they connected?
                      What are your heaters and how are the connected?
                      What are your fans and how are they connected?
                      What are your motors and how are they connected?
                      How is the BLtouch connected?
                      Once we have the basics up and running. Motors. Homing. Heaters. Fans. We can make the changes needed for automatic bed leveling.
                      • duttiundefined
                        dutti @Phaedrux
                        that is an old issue.... now it´s not possible to start z probe. the message ´´Error: Failed to enable endstops´´ is shown.....
                        ok.... to all these questions. everything was working ONLY the true auto level not.
                        please give me time. I haven´t expected that much work again...
                        • duttiundefined
                          dutti
                          Spam???????
                          • duttiundefined
                            dutti @dutti
                            @barbarossa-cologne
                            I´m sorry but I took a look in the configuration tool via the systems page in the DWC and decided that I just posting the g.codes that you need exactly. Because everything was working or IS working except the Bl-Touch / Z Probe.
                            After one month having the same problem ONLY with the BL I just want to try fixing it like this. I hope its ok.
                            Time is rare....
                            ; generated by RepRapFirmware Configuration Tool v3.1.3 on Tue Jun 23 2020 22:36:44 GMT+0200 (Mitteleuropäische Sommerzeit)
                            M550 P"Duet 3" ; set printer name
                            M569 P0.4 S1 ; physical drive 0.4 goes forwards
                            M569 P0.5 S1 ; physical drive 0.5 goes forwards
                            M569 P1.0 S1 ; physical drive 1.0 goes forwards
                            M569 P1.1 S1 ; physical drive 1.1 goes forwards
                            M569 P1.2 S1 ; physical drive 1.2 goes forwards
                            M584 X0.0 Y0.1 Z0.2:0.3:0.4:0.5 E1.0:1.1:1.2 ; set drive mapping
                            M350 X16 Y16 Z16 E16:16:16:16:16:16 I1 ; configure microstepping with interpolation
                            M92 X80.00 Y80.00 Z1600.00 E1600.00:1600.00:1600.00:92.70:92.70:92.70 ; set steps per mm
                            M566 X900.00 Y900.00 Z12.00 E120.00:120.00:120.00:120.00:120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
                            M203 X6000.00 Y6000.00 Z180.00 E3600.00:3600.00:3600.00:1200.00:1200.00:1200.00 ; set maximum speeds (mm/min)
                            M201 X500.00 Y500.00 Z40.00 E250.00:250.00:250.00:250.00:250.00:250.00 ; set accelerations (mm/s^2)
                            M906 X1200 Y1200 Z3000 E3000:3000:3000:1200:1200:1200 I30 ; set motor currents (mA) and motor idle factor in per cent
                            M84 S30 ; Set idle timeout
                            M208 X700 Y700 Z800 S0 ; set axis maxima
                            M574 X2 S1 P"!io3.in" ; configure active-high endstop for high end on X via pin !io3.in
                            M574 Y2 S1 P"!io0.in" ; configure active-high endstop for high end on Y via pin !io0.in
                            M558 P9 C"io4.in" H10 F200 T1800 ; set Z probe type to bltouch and the dive height + speeds
                            M950 S0 C"io4.out" ; create servo pin 0 for BLTouch
                            G31 P25 X-20 Y-20 Z2.5 ; set Z probe trigger value, offset and trigger height
                            M557 X15:650 Y15:650 S200 ; define mesh grid
                            M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
                            M307 H1 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit
                            M143 H0 S90 ; set temperature limit for heater 0 to 90C
                            M308 S1 P"temp1" Y"thermistor" T100000 B4138                                     ; configure sensor 1 as thermistor on pin temp1
                            M950 H1 C"out1" T1                                                               ; create nozzle heater output on out1 and map it to sensor 1
                            M307 H1 B0 S1.00        ; disable bang-bang mode for heater  and set PWM limit
                            M950 F0 C"out3" Q500 ; create fan 0 on pin out3 and set its frequency
                            M106 P0 S0.8 H-1 ; set fan 0 value. Thermostatic control is turned off
                            M950 F1 C"out7" Q500 ; create fan 1 on pin out7 and set its frequency
                            M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off
                            M950 F2 C"out8" Q500 ; create fan 2 on pin out8 and set its frequency
                            M106 P2 S1 H T45 ; set fan 2 value. Thermostatic control is turned on
                            M671 X-12:92:92:-12 Y185:185:615:615 S2.5
                            M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power
                            deploy----------------------------
                            ; deployprobe.g
                            ; called to deploy a physical Z probe
                            M280 P0 S10 ; deploy BLTouch
                            retract.g--------------------------------
                            ; retractprobe.g
                            ; called to retract a physical Z probe
                            M280 P0 S90 ; retract BLTouch
                            homez.g-------------------------
                            ; homez.g
                            ; called to home the Z axis
                            ; generated by RepRapFirmware Configuration Tool v3.1.3 on Thu Jun 25 2020 00:21:12 GMT+0200 (Mitteleuropäische Sommerzeit)
                            G91 ; relative positioning
                            G90 ; absolute positioning
                            G1 X15 Y15 F6000 ; go to first probe point
                            ; bed.g
                            ; Called using G32
                            ; Called to perform True Autolevel using 4-point probe
                            G29 S2; Clear bed height map
                            ; Probe 4-point
                            G30 P0 X150 Y135 Z-9999 ; Front Right
                            G30 P1 X550 Y135 Z-9999 ; Front Left
                            G30 P2 X550 Y565 Z-9999 ; Back Left
                            G30 P3 X150 Y565 Z-9999 S4 ; Back Right
                            ; homez.g
                            G1 H2 Z15 F2400   ; lift Z relative to current position
                            G1 H1 Z-805 F1200 ; move Z down until the endstop is triggered
                            G92 Z0            ; set Z position to axis minimum (you may want to adjust this)
                            ;G91              ; relative positioning
                            ;G1 Z15 F40       ; lift Z relative to current position
                            ;G90              ; absolute positioning
                            • duttiundefined
                              dutti
                              this are codes from the systems page.... NOT a macro. I´m sorry for beeing stupid in this thread and posting macros. I was tired after working much.
                              I hope somebody can help me in this way
                                droftarts administrators @dutti
                                @barbarossa-cologne you have posted two homez.g files; one on the end of the config.g (also deploy and retract on there), and one separate. Which is the right one? One uses G30 to home Z, the other uses a maximum Z endstop, which isn’t defined in config.g.
                                • duttiundefined
                                  dutti @droftarts
                                  @droftarts
                                  the G30 configuration should be the rigth one. Should I copy that to the home z file?
                                  Or how should I handle it?
                                    @barbarossa-cologne does your config.g contain deploy.g, retract.g and homez.g? These should not be in config.g, they should be separate files in the sys folder, which probably already exist. The homeall.g is run when you press the “Home all” button in DWC, and homez.g is run if you press the “home Z” button, so it is important that both these files are correct. Similarly, pressing “Home X” or “Home Y” runs homex.g or homey.g respectively. Post your homeall.g file, too.
                                    So yes, copy the G30 version to the homez.g and homeall.g files, and also update the deploy.g and retract.g files, then delete from config.g everything after the “Miscellaneous” section.
                                    duttiundefined 4 Replies Last reply Reply Quote 0
                                    • duttiundefined
                                      dutti @droftarts
                                      @droftarts
                                      ; homeall.g
                                      ; called to home all axes
                                      G1 H1 X805 Y805 F1200 ; move quickly to X and Y axis endstops and stop there (first pass)
                                      G1 H2 X-5 Y-5 F2400   ; go back a few mm
                                      G1 H1 X805 Y805 F360  ; move slowly to X and Y axis endstops once more (second pass)
                                      G1 H1 Z-805 F360      ; move Z down stopping at the endstop
                                      • duttiundefined
                                        dutti @droftarts
                                        @droftarts
                                        G32 is working perfect. Also the normal Z probe with the BL Touch!!!
                                        Thank you a lot!!!! 🙂
                                        • duttiundefined
                                          dutti @droftarts
                                          This post is deleted!
                                          • duttiundefined
                                            dutti @droftarts
                                            @droftarts
                                            now. when I start printing it comes to this error.
                                            10.8.2020, 19:25:13 Error: G0/G1: insufficient axes homed
                                            M557 X10:600 Y10:600 S200 ; define mesh grid
                                            M671 X-19.5:99.5:99.5:-19.5 Y110:110:540:540 S2.5
                                            home all-- >
                                            ; homez.g
