    Firmware update failure..
    Firmware installation
    2.1k
      Curious to see what M115 reports.
      What firmware version is on the PanelDue? Can check in the settings page.
      Helensdadundefined 1 Reply Last reply Reply Quote 0
      • Helensdadundefined
        Helensdad @Phaedrux
        @Phaedrux yat reports version 2. 02, I think, june 2019. Not near machine or computer at moment...
          Helensdad @Helensdad
          @Helensdad Paneldue still won't work properly, completely blank now....
            @Helensdad said in Firmware update failure..:
            Does it still receive power?
            How is it wired to the duet? 4-wire or ribbon cable?
              dc42 administrators @Helensdad
              Try updating the PanelDue firmware through its USB port. You may need to disconnect the PanelDue from the Duet for the firmware update to succeed.
                Helensdad @dc42
                @dc42 I have erased and reinstalled the firmware, I have been using the 4 wire cable for about 11 months, since I got it basically. I have just tried the ribbon cable with the same result. It lights up, all the buttons are there but don't have any effect. It I touch the card icon it says files on card 0. The settings tab works and I can invert, change colour scheme, contrast volume etc but it won't communicate with the Duet board. In the top right corner of the screen it says 'connecting' but it doesn't connect...
                  Phaedrux Moderator @Helensdad
                  What firmware version does it show on the PanelDue settings tab?
                  It looks like the workbee firmware is based on RRF 2.02.
                    Helensdad @Phaedrux
                    @Phaedrux 1.24
                      Have you ever updated the paneldue firmware? 1.24 is the latest released in April.
                        Helensdad @Phaedrux
                        @Phaedrux Yes, I updated it this afternoon via USB...
                          Ah I see, and no change obviously.
                          I know you're using the oozenest releases, but could you try updating the firmware to the official 2.05.1 release just to see if there's a change.
                          Also, could you link to the oozenest info and releases? I did a quick googling but wasn't able to find anything.
                            Helensdad
                            Here is the link to Ooznest firmware, I will trt the Duet firmware tomorrow, I have a job running now. All works ok from web interface, it even reads the card. It is just the Paneldue I have to sort now....
                            https://learn.ooznest.co.uk/Wiki/WorkBee_Firmware_Releases
                              Normally I would suggest to replace the 4-wire cable with a new one, but you've already tried the ribbon cable option with the same result.
                              Which version of PanelDue is it? Which PanelDue firmware did you use to flash it? Perhaps there was a mismatch.
                                after downloading the combined firmware.bin file, I tell it to update, it then drops the Wifi connection and reverts back to 1.0.3...
                                This part makes me think that the files might not be placed in the /sys folder or that there might be other files there or files not named correctly and so an older file is being used.
                                Can you provide a screenshot of the SD card directory structure?
                                  Helensdad @Phaedrux
                                  @Phaedrux said in Firmware update failure..:
                                  Which version of PanelDue is it? Which PanelDue firmware did you use to flash it? Perhaps there was a mismatch. It is a Paneldue 7i and I used 1.24 for 7i downloaded from your repository...
                                    Helensdad @Phaedrux
                                      Ok, so your screen shot of the /sys folder shows the bin file is actually a ._ file which is a metadata file used by MacOS and is normally hidden. So at some point there was a firmware bin file, but there isn't at the moment.
                                      I took a look at the workbee docs and I would try downloading the 1.0.7 full install zip, extracting it, and then trying to upload the combined firmware bin file to the /sys folder in DWC. It should detect it and update the firmware.
                                      https://ooznest.co.uk/wp-content/uploads/2019/11/WorkBee-Firmware-v1.0.7.2-Full.zip
                                      Maybe it helps, maybe not, but at least we can confirm that 1.0.7 installed correctly.
                                        Helensdad @Phaedrux
                                        @Phaedrux I have just connected the Paneldue to my Maestro board and get the same problem, when I look at the card contents, Paneldue says files on card 0, nothing works except foe settings....
                                          Alright, well that narrows it down to the PanelDue at least.
                                          I would try updating the firmware on the PanelDue again. Redownload the correct file for the 7i and check the file size.
                                          Hopefully it's just a case of a bad flash.
                                          https://duet3d.dozuki.com/Wiki/PanelDue_Firmware_update
                                            Helensdad
                                            I have uprated the firmware again and tried on Duet 2 WiFi and Duet Maestro to no avail. I even used a brand new good quality USB lead. I bought it on May 24th last year so out of warranty. Do you know if it is repairable?
