    MK3S Filament sensor style Maestro?
    Third-party add-ons
    444
    • cabal2000undefined
      cabal2000
      Hi guys
      What is the proper g-code for a MK3S filament sensor? I do have it hooked to a 5v source, took it off the Panel display!!
      Thanks
        cabal2000
        G591 D0 P1 Ce0stop S1? 2.02 firmware E0 (only one extruder)
          cabal2000
          no help?
          Kolbiundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
          • Kolbiundefined
            Kolbi @cabal2000
            @cabal2000 I'm not sure if this helps, because I have a duet2wifi RRF311, but here is my config.g line for it:
            ; Filament Sensor
            M591 D0 P2 C"e0stop" S1                                    ; Filament Runout Sensor
            D0: Dnn Extruder drive number (0, 1, 2...),
            P2: Pnn Type of sensor: 2=simple sensor (low signal when filament present)
            S1: Sn 1 = enable filament monitoring when printing from SD card.
            C"e0stop" Pin name the filament sensor is connected to (RRF_3 only), see Pin Names
            The wiring guide I made might help, you can find it here:
            https://github.com/rkolbi/RRF-machine-config-files/tree/master/Prusa MK3s
            Cheers,
            Kolbi
            cabal2000undefined 1 Reply Last reply Reply Quote 1
              cabal2000 @Kolbi
              @Kolbi said in MK3S Filament sensor style Maestro?:
              ; Filament Sensor M591 D0 P2 C"e0stop" S1 ; Filament Runout Sensor
              THANK YOU VERY MUCH!!!!
              Is there anything else that I need in the start gcode?
              Kolbiundefined 1 Reply Last reply Reply Quote 0
              • Kolbiundefined
                Kolbi @cabal2000
                @cabal2000 That's all you need in your config.g to get it working. You can take a look at my sd-card dump to see how it's used in other files here: 17AUG2020-dump.pdf or on my GitHub.
                cabal2000undefined 1 Reply Last reply Reply Quote 0
                  cabal2000 @Kolbi
                  @Kolbi Thank you so much, I REALLY do appreciate it.
                  • Kolbiundefined
                    Kolbi @cabal2000
                    @cabal2000 No worries at all, glad I could help!
                      Phaedrux Moderator @cabal2000
                      @cabal2000 said in MK3S Filament sensor style Maestro?:
                      no help?
                      Sorry you got missed. Thanks for bumping it. Glad you got it sorted out.
                        cabal2000 @Phaedrux
                        @Phaedrux All working!!! Thanks
